Public Slots | Signals | Public Member Functions | Protected Slots | List of all members
pqVCRController Class Reference
pqVCRController is the QObject that encapsulates the VCR control functionality. More...
#include <pqVCRController.h>
Inherits QObject.
Public Slots
virtual void setAnimationScene (pqAnimationScene *)
 Set the animation scene. More...
virtual void onTimeRangesChanged ()
 Called when timeranges change. More...
virtual void onFirstFrame ()
 Connect these signals to appropriate VCR buttons. More...
virtual void onPreviousFrame ()
virtual void onNextFrame ()
virtual void onLastFrame ()
virtual void onPlay ()
virtual void onReverse ()
virtual void onPause ()
virtual void onLoop (bool checked)
Signals
void timestepChanged ()
 Emitted for each tick. More...
void playing (bool)
void playing (bool, bool)
 Emitted as playing(true, reversed) when playback begins and playing(false, reversed) when playback ends. More...
void enabled (bool)
 Fired when the enable state of the VCR control changes and each time setAnimationScene() is called. More...
void loop (bool)
 Emitted to update the check state of the loop. More...
void timeRanges (double, double)
 Emitted when the time ranges is updated. More...
 pqVCRController (QObject *parent=nullptr)
 ~pqVCRController () override
pqAnimationScene * getAnimationScene () const
 Get the animation scene currently used in the VCR control. More...
Protected Slots
void onTick ()
void onLoopPropertyChanged ()
void onBeginPlay (vtkObject *caller, unsigned long, void *, void *reversed)
void onEndPlay (vtkObject *caller, unsigned long, void *, void *reversed)
It provides a slot to set the scene that this object is using for animation. Typically, one would connect this slot to a pqAnimationManager like object which keeps track of the active animation scene.
Definition at line 23 of file pqVCRController.h.
◆ pqVCRController()
pqVCRController::pqVCRController ( QObject *  parent = nullptr)
◆ ~pqVCRController()
pqVCRController::~pqVCRController ( )
override
◆ getAnimationScene()
pqAnimationScene* pqVCRController::getAnimationScene ( ) const
◆ timestepChanged
void pqVCRController::timestepChanged ( )
signal
◆ playing [1/2]
void pqVCRController::playing ( bool  )
signal
Deprecated:
in 5.11.0.
Use playing(bool, bool) instead.
◆ playing [2/2]
void pqVCRController::playing ( bool  ,
bool
signal
The value of reversed argument is true if playback was requested in backward direction
◆ enabled
void pqVCRController::enabled ( bool  )
signal
If called when a valid scene, enabled(true) is fired, else enabled(false).
◆ loop
void pqVCRController::loop ( bool  )
signal
◆ timeRanges
void pqVCRController::timeRanges ( double  ,
double
signal
◆ setAnimationScene
virtual void pqVCRController::setAnimationScene ( pqAnimationScene *  )
virtualslot
If null, the VCR control is disabled (emits enabled(false)).
◆ onTimeRangesChanged
virtual void pqVCRController::onTimeRangesChanged ( )
virtualslot
(emits timeRanges(first, last))
◆ onFirstFrame
virtual void pqVCRController::onFirstFrame ( )
virtualslot
◆ onPreviousFrame
virtual void pqVCRController::onPreviousFrame ( )
virtualslot
◆ onNextFrame
virtual void pqVCRController::onNextFrame ( )
virtualslot
◆ onLastFrame
virtual void pqVCRController::onLastFrame ( )
virtualslot
◆ onPlay
virtual void pqVCRController::onPlay ( )
virtualslot
◆ onReverse
virtual void pqVCRController::onReverse ( )
virtualslot
◆ onPause
virtual void pqVCRController::onPause ( )
virtualslot
◆ onLoop
virtual void pqVCRController::onLoop ( bool  checked)
virtualslot
◆ onTick
void pqVCRController::onTick ( )
protectedslot
◆ onLoopPropertyChanged
void pqVCRController::onLoopPropertyChanged ( )
protectedslot
◆ onBeginPlay
void pqVCRController::onBeginPlay ( vtkObject *  caller,
unsigned long  ,
void *  ,
void *  reversed
protectedslot
◆ onEndPlay
void pqVCRController::onEndPlay ( vtkObject *  caller,
unsigned long  ,
void *  ,
void *  reversed
protectedslot
