Public Types | Public Slots | Public Member Functions | Static Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqRescaleScalarRangeReaction Class Reference
#include <pqRescaleScalarRangeReaction.h>
Inheritance diagram for pqRescaleScalarRangeReaction:
Collaboration diagram for pqRescaleScalarRangeReaction:
enum  Modes { DATA, CUSTOM, TEMPORAL, VISIBLE }
Public Slots
void updateEnableState () override
 Updates the enabled state. More...
void setRepresentation (pqDataRepresentation *repr)
 Set the data representation explicitly when track_active_objects is false. More...
 pqRescaleScalarRangeReaction (QAction *parent, bool track_active_objects=true, Modes mode=DATA)
 if track_active_objects is false, then the reaction will not track pqActiveObjects automatically. More...
 ~pqRescaleScalarRangeReaction () override
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 Constructor. More...
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static bool rescaleScalarRangeToData (pqPipelineRepresentation *repr=nullptr)
 Rescale to current data range. More...
static pqRescaleScalarRangeToCustomDialog * rescaleScalarRangeToCustom (pqPipelineRepresentation *repr=nullptr)
 Rescale range to a custom range. More...
static pqRescaleScalarRangeToCustomDialog * rescaleScalarRangeToCustom (vtkSMProxy *tfProxy, bool separateOpacity=false)
static pqRescaleScalarRangeToDataOverTimeDialog * rescaleScalarRangeToDataOverTime (pqPipelineRepresentation *repr=nullptr)
 Rescale range to data range over time. More...
static bool rescaleScalarRangeToVisible (pqPipelineRepresentation *repr=nullptr)
 Rescale range to data range for data visible in the view. More...
Protected Slots
virtual void onServerAdded (pqServer *server)
virtual void onAboutToRemoveServer (pqServer *server)
- Protected Slots inherited from pqReaction
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
void onTriggered () override
 Called when the action is triggered. More...
- Protected Attributes inherited from pqReaction
bool IsMaster
Reaction to rescale the active lookup table's range to match the active representation. You can disable tracking of the active representation, instead explicitly provide one using setRepresentation() by pass track_active_objects as false to the constructor.
Definition at line 27 of file pqRescaleScalarRangeReaction.h.
◆ Modes
Enumerator
DATA
CUSTOM
TEMPORAL
VISIBLE
Definition at line 33 of file pqRescaleScalarRangeReaction.h.
◆ pqRescaleScalarRangeReaction()
pqRescaleScalarRangeReaction::pqRescaleScalarRangeReaction ( QAction *  parent,
bool  track_active_objects = true,
Modes  mode = DATA
◆ ~pqRescaleScalarRangeReaction()
pqRescaleScalarRangeReaction::~pqRescaleScalarRangeReaction ( )
override
◆ rescaleScalarRangeToData()
static bool pqRescaleScalarRangeReaction::rescaleScalarRangeToData ( pqPipelineRepresentation *  repr = nullptr)
Parameters
[in]reprThe data representation to use to determine the data range. If nullptr, then the active representation is used, if available.
Returns
true if the operation was successful, otherwise false.
◆ rescaleScalarRangeToCustom() [1/2]
static pqRescaleScalarRangeToCustomDialog* pqRescaleScalarRangeReaction::rescaleScalarRangeToCustom ( pqPipelineRepresentation *  repr = nullptr)
Parameters
[in]reprThe representation used to determine the transfer function to change range on. If repr is nullptr, then the active representation is used, if available.
Returns
a pointer to the dialog if the operation was successful, otherwise nullptr.
◆ rescaleScalarRangeToCustom() [2/2]
static pqRescaleScalarRangeToCustomDialog* pqRescaleScalarRangeReaction::rescaleScalarRangeToCustom ( vtkSMProxy *  tfProxy,
bool  separateOpacity = false
Parameters
[in]tfProxyThe transfer function proxy to rescale the range on.
[in]separateOpacityShow controls for setting the opacity function range separately from the color transfer function.
Returns
◆ rescaleScalarRangeToDataOverTime()
static pqRescaleScalarRangeToDataOverTimeDialog* pqRescaleScalarRangeReaction::rescaleScalarRangeToDataOverTime ( pqPipelineRepresentation *  repr = nullptr)
Parameters
Returns
◆ rescaleScalarRangeToVisible()
static bool pqRescaleScalarRangeReaction::rescaleScalarRangeToVisible ( pqPipelineRepresentation *  repr = nullptr)
Parameters
Returns
◆ updateEnableState
void pqRescaleScalarRangeReaction::updateEnableState ( )
overrideslot
◆ setRepresentation
void pqRescaleScalarRangeReaction::setRepresentation ( pqDataRepresentation *  repr)
slot
◆ onTriggered()
void pqRescaleScalarRangeReaction::onTriggered ( )
overrideprotectedvirtual
◆ onServerAdded
virtual void pqRescaleScalarRangeReaction::onServerAdded ( pqServer *  server)
protectedvirtualslot
◆ onAboutToRemoveServer
virtual void pqRescaleScalarRangeReaction::onAboutToRemoveServer ( pqServer *  server)
