Public Types | Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqRenderViewSelectionReaction Class Reference
pqRenderViewSelectionReaction handles various selection modes available on RenderViews. More...
#include <pqRenderViewSelectionReaction.h>
Inheritance diagram for pqRenderViewSelectionReaction:
Collaboration diagram for pqRenderViewSelectionReaction:
enum  SelectionMode {
  SELECT_SURFACE_CELLS, SELECT_SURFACE_POINTS, SELECT_FRUSTUM_CELLS, SELECT_FRUSTUM_POINTS,
  SELECT_SURFACE_CELLS_POLYGON, SELECT_SURFACE_POINTS_POLYGON, SELECT_BLOCKS, SELECT_CUSTOM_BOX,
  SELECT_CUSTOM_POLYGON, ZOOM_TO_BOX, CLEAR_SELECTION, GROW_SELECTION,
  SHRINK_SELECTION, SELECT_SURFACE_POINTDATA_INTERACTIVELY, SELECT_SURFACE_CELLDATA_INTERACTIVELY, SELECT_SURFACE_CELLS_INTERACTIVELY,
  SELECT_SURFACE_POINTS_INTERACTIVELY, SELECT_SURFACE_POINTS_TOOLTIP, SELECT_SURFACE_CELLS_TOOLTIP
Signals
void selectedCustomBox (int xmin, int ymin, int xmax, int ymax)
 Signals emitted when the event happens. More...
void selectedCustomBox (const int region[4])
void selectedCustomPolygon (vtkIntArray *polygon)
 pqRenderViewSelectionReaction (QAction *parentAction, pqRenderView *view, SelectionMode mode, QActionGroup *modifierGroup=nullptr)
 If view is nullptr, this reaction will track the active-view maintained by pqActiveObjects. More...
 ~pqRenderViewSelectionReaction () override
 Call CleanupObservers on destruction. More...
- Public Member Functions inherited from pqSelectionReaction
 pqSelectionReaction (QAction *parent, QActionGroup *modifierGroup=nullptr)
 Constructor. More...
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
Protected Slots
virtual void actionTriggered (bool val)
 For checkable actions, this calls this->beginSelection() or this->endSelection() is val is true or false, respectively. More...
void updateEnableState () override
 Handles enable state for the CLEAR_SELECTION, GROW_SELECTION, and SHRINK_SELECTION modes. More...
virtual void setView (pqView *view)
 Called when this object was created with nullptr as the view and the active view changes. More...
void setRepresentation (pqDataRepresentation *representation)
 Called when the active representation changes. More...
virtual void beginSelection ()
 starts the selection i.e. More...
virtual void endSelection ()
 finishes the selection. More...
virtual void preSelection ()
 makes the pre-selection. More...
virtual void fastPreSelection ()
 makes fast pre-selection. More...
virtual void onMouseStop ()
 callback called for mouse stop events when in 'interactive selection' modes. More...
virtual void clearSelectionCache ()
 clears the selection cache. More...
- Protected Slots inherited from pqSelectionReaction
virtual void modifiersChanged ()
 called when modifier group is changed. More...
- Protected Slots inherited from pqReaction
virtual void onTriggered ()
 Called when the action is triggered. More...
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
virtual void selectionChanged (vtkObject *, unsigned long, void *calldata)
 callback called when the vtkPVRenderView is done with selection. More...
virtual void onMouseMove ()
 callback called for mouse move events when in 'interactive selection' modes. More...
int getSelectionModifier () override
 Get the current state of selection modifier. More...
virtual bool isCompatible (SelectionMode mode)
 Check this selection is compatible with another type of selection. More...
virtual void UpdateTooltip ()
 Display/hide the tooltip of the selected point in mode SELECT_SURFACE_POINTS_TOOLTIP. More...
virtual void cleanupObservers ()
 cleans up observers. More...
virtual void onLeftButtonRelease ()
 callback called for click events when in 'interactive selection' modes. More...
virtual void onWheelRotate ()
virtual void onRightButtonPressed ()
virtual void onRightButtonRelease ()
- Protected Member Functions inherited from pqSelectionReaction
virtual void uncheckSelectionModifiers ()
 Uncheck selection modifiers, if any. More...
virtual void disableSelectionModifiers (bool disable)
 Disable/Enable selection modifiers, if any. More...
- Protected Attributes inherited from pqSelectionReaction
QPointer< QActionGroup > ModifierGroup
- Protected Attributes inherited from pqReaction
bool IsMaster
Simply create multiple instances of pqRenderViewSelectionReaction to handle selection modes for that RenderView. pqRenderViewSelectionReaction uses internal static members to ensure that at most 1 view (and 1 type of selection) is in selection-mode at any given time.
Definition at line 30 of file pqRenderViewSelectionReaction.h.
◆ SelectionMode
Enumerator
SELECT_BLOCKS
SELECT_CUSTOM_BOX
ZOOM_TO_BOX
CLEAR_SELECTION
GROW_SELECTION
SHRINK_SELECTION
Definition at line 36 of file pqRenderViewSelectionReaction.h.
◆ pqRenderViewSelectionReaction()
pqRenderViewSelectionReaction::pqRenderViewSelectionReaction ( QAction *  parentAction,
pqRenderView *  view,
SelectionMode  mode,
QActionGroup *  modifierGroup = nullptr
◆ ~pqRenderViewSelectionReaction()
pqRenderViewSelectionReaction::~pqRenderViewSelectionReaction ( )
override
◆ selectedCustomBox [1/2]
void pqRenderViewSelectionReaction::selectedCustomBox ( int  xmin,
int  ymin,
int  xmax,
int  ymax
signal
◆ selectedCustomBox [2/2]
void pqRenderViewSelectionReaction::selectedCustomBox ( const int  region[4])
signal
◆ selectedCustomPolygon
void pqRenderViewSelectionReaction::selectedCustomPolygon ( vtkIntArray *  polygon)
signal
◆ actionTriggered
virtual void pqRenderViewSelectionReaction::actionTriggered ( bool  val)
protectedvirtualslot
For non-checkable actions, this call this->beginSelection() and this->endSelection() in that order.
◆ updateEnableState
void pqRenderViewSelectionReaction::updateEnableState ( )
overrideprotectedslot
◆ setView
virtual void pqRenderViewSelectionReaction::setView ( pqView *  view)
Please note that this method will cast the pqView to a pqRenderView.
◆ setRepresentation
void pqRenderViewSelectionReaction::setRepresentation ( pqDataRepresentation *  representation)
protectedslot
◆ beginSelection
virtual void pqRenderViewSelectionReaction::beginSelection ( )
setup render view in selection mode.
◆ endSelection
virtual void pqRenderViewSelectionReaction::endSelection ( )
Doesn't cause the selection, just returns the render view to previous interaction mode.
◆ preSelection
virtual void pqRenderViewSelectionReaction::preSelection ( )
◆ fastPreSelection
virtual void pqRenderViewSelectionReaction::fastPreSelection ( )
◆ onMouseStop
virtual void pqRenderViewSelectionReaction::onMouseStop ( )
◆ clearSelectionCache
virtual void pqRenderViewSelectionReaction::clearSelectionCache ( )
◆ selectionChanged()
virtual void pqRenderViewSelectionReaction::selectionChanged ( vtkObject *  ,
unsigned long  ,
void *  calldata
protectedvirtual
◆ onMouseMove()
virtual void pqRenderViewSelectionReaction::onMouseMove ( )
protectedvirtual
◆ onLeftButtonRelease()
virtual void pqRenderViewSelectionReaction::onLeftButtonRelease ( )
protectedvirtual
◆ onWheelRotate()
virtual void pqRenderViewSelectionReaction::onWheelRotate ( )
protectedvirtual
◆ onRightButtonPressed()
virtual void pqRenderViewSelectionReaction::onRightButtonPressed ( )
protectedvirtual
◆ onRightButtonRelease()
virtual void pqRenderViewSelectionReaction::onRightButtonRelease ( )
protectedvirtual
◆ getSelectionModifier()
int pqRenderViewSelectionReaction::getSelectionModifier ( )
overrideprotectedvirtual
Reimplemented from pqSelectionReaction.
◆ isCompatible()
virtual bool pqRenderViewSelectionReaction::isCompatible ( SelectionMode  mode)
protectedvirtual
◆ UpdateTooltip()
virtual void pqRenderViewSelectionReaction::UpdateTooltip ( )
protectedvirtual
◆ cleanupObservers()
virtual void pqRenderViewSelectionReaction::cleanupObservers ( )
protectedvirtual
