Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqPythonMacroSupervisor Class Reference
#include <pqPythonMacroSupervisor.h>
Inherits QObject.
Public Slots
void addMacro (const QString &macroName, const QString &fileName)
 Add an action with the given name and fileName. More...
void addMacro (const QString &fileName)
void removeMacro (const QString &fileName)
 Remove an action from the UI, with the given fileName (absolute path of macro file). More...
void updateMacroList ()
 Update Macro list widgets and actions... More...
Signals
void executeScriptRequested (const QString &fileName)
 Emitted when a macro has been triggered. More...
void onAddedMacro ()
 Emitted when a macro has been added. More...
void onEditMacro (const QString &fileName)
 Emitted when a macro has to be edited. More...
 pqPythonMacroSupervisor (QObject *p=nullptr)
 ~pqPythonMacroSupervisor () override
void addWidgetForRunMacros (QWidget *widget)
 Add a widget to be given macro actions. More...
void addWidgetForEditMacros (QWidget *widget)
void addWidgetForDeleteMacros (QWidget *widget)
QAction * getMacro (const QString &fileName)
 Lookup and return a macro action by fileName (absolute path of macro file). More...
static QMap< QString, QString > getStoredMacros ()
 Get macros from known macro directories (see getMacrosFilePaths) In the returned map, the keys are fileNames and values are macro names. More...
static void removeStoredMacro (const QString &fileName)
 Hide file by prepending a . More...
static void hideFile (const QString &fileName)
static QString macroNameFromFileName (const QString &fileName)
 Get a macro name from the fileName (absolute path of macro file). More...
static QString iconPathFromFileName (const QString &fileName)
 Get an icon path from the fileName (absolute path of macro file). More...
static QStringList getMacrosFilePaths ()
 Get a list a "*.py" files from macro directories. More...
static QStringList getSupportedIconFormats ()
Protected Slots
void onMacroTriggered ()
 If the sender is a QAction managed by this class, the fileName will be looked up and the signal requestExecuteScript will be emitted. More...
void onDeleteMacroTriggered ()
 If the sender is a QAction managed by this class, the fileName will be moved (deleted), and the macro will be removed. More...
void onEditMacroTriggered ()
 If the sender is a QAction managed by this class, the macro file will be open in a python edit. More...
void addWidgetForMacros (QWidget *widget, int actionType)
void resetActions ()
 Removes all actions and re-adds actions for each macro stored. More...
Definition at line 19 of file pqPythonMacroSupervisor.h.
◆ pqPythonMacroSupervisor()
pqPythonMacroSupervisor::pqPythonMacroSupervisor ( QObject *  p = nullptr)
◆ ~pqPythonMacroSupervisor()
pqPythonMacroSupervisor::~pqPythonMacroSupervisor ( )
override
◆ addWidgetForRunMacros()
void pqPythonMacroSupervisor::addWidgetForRunMacros ( QWidget *  widget)
QActions representing script macros will be added to the widget. This could be a QToolBar, QMenu, or other type of widget.
◆ addWidgetForEditMacros()
void pqPythonMacroSupervisor::addWidgetForEditMacros ( QWidget *  widget)
◆ addWidgetForDeleteMacros()
void pqPythonMacroSupervisor::addWidgetForDeleteMacros ( QWidget *  widget)
◆ getMacro()
QAction* pqPythonMacroSupervisor::getMacro ( const QString &  fileName)
If it does not exist, return null.
◆ getStoredMacros()
static QMap<QString, QString> pqPythonMacroSupervisor::getStoredMacros ( )
◆ removeStoredMacro()
static void pqPythonMacroSupervisor::removeStoredMacro ( const QString &  fileName)
to its name. Hidden file in macro directory are not loaded.
◆ hideFile()
static void pqPythonMacroSupervisor::hideFile ( const QString &  fileName)
◆ macroNameFromFileName()
static QString pqPythonMacroSupervisor::macroNameFromFileName ( const QString &  fileName)
◆ iconPathFromFileName()
static QString pqPythonMacroSupervisor::iconPathFromFileName ( const QString &  fileName)
If no corresponding icon, return an empty string.
◆ getMacrosFilePaths()
static QStringList pqPythonMacroSupervisor::getMacrosFilePaths ( )
◆ getSupportedIconFormats()
static QStringList pqPythonMacroSupervisor::getSupportedIconFormats ( )
inlinestatic
Definition at line 88 of file pqPythonMacroSupervisor.h.
◆ executeScriptRequested
void pqPythonMacroSupervisor::executeScriptRequested ( const QString &  fileName)
signal
◆ onAddedMacro
void pqPythonMacroSupervisor::onAddedMacro ( )
signal
◆ onEditMacro
void pqPythonMacroSupervisor::onEditMacro ( const QString &  fileName)
signal
◆ addMacro [1/2]
void pqPythonMacroSupervisor::addMacro ( const QString &  macroName,
slot
If there is already a macro with the given fileName it's macroname will be updated to the one given. Macro names do not have to be unique.
◆ addMacro [2/2]
void pqPythonMacroSupervisor::addMacro ( const QString &  fileName)
slot
◆ removeMacro
void pqPythonMacroSupervisor::removeMacro ( const QString &  fileName)
slot
Note, this does not remove the macro from a future load, you must call hideFile yourself (or manually remove the file from the settings dir).
◆ updateMacroList
void pqPythonMacroSupervisor::updateMacroList ( )
slot
◆ onMacroTriggered
void pqPythonMacroSupervisor::onMacroTriggered ( )
protectedslot
◆ onDeleteMacroTriggered
void pqPythonMacroSupervisor::onDeleteMacroTriggered ( )
protectedslot
◆ onEditMacroTriggered
void pqPythonMacroSupervisor::onEditMacroTriggered ( )
protectedslot
◆ addWidgetForMacros()
void pqPythonMacroSupervisor::addWidgetForMacros ( QWidget *  widget,
int  actionType
◆ resetActions()
void pqPythonMacroSupervisor::resetActions ( )
