Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | Protected Attributes | List of all members
pqProxyGroupMenuManager Class Reference
pqProxyGroupMenuManager is a menu-populator that fills up a menu with proxies defined in an XML configuration file. More...
#include <pqProxyGroupMenuManager.h>
Inherits QObject.
Collaboration diagram for pqProxyGroupMenuManager:
Public Slots
void loadConfiguration (vtkPVXMLElement *)
 Load a configuration XML. More...
void lookForNewDefinitions ()
 Look for new proxy definition to add inside the menu. More...
void removeProxyDefinitionUpdateObservers ()
 Remove all ProxyDefinitionUpdate observers to active server. More...
void addProxyDefinitionUpdateObservers ()
 Update the list of ProxyDefinitionUpdate observers to server. More...
void setEnabled (bool enable)
 Enable/disable the menu and the actions. More...
virtual void populateMenu ()
 Forces a re-population of the menu. More...
Signals
void triggered (const QString &group, const QString &name)
void menuPopulated ()
 fired when the menu gets repopulated,typically means that the actions have been updated. More...
 pqProxyGroupMenuManager (QMenu *menu, const QString &resourceTagName, bool supportsQuickLaunch=true)
 Constructor. More...
 ~pqProxyGroupMenuManager () override
QMenu * menu () const
 Access the menu. More...
void setRecentlyUsedMenuSize (unsigned int val)
 When size>0 a recently used category will be added to the menu. More...
unsigned int recentlyUsedMenuSize () const
QWidget * widgetActionsHolder () const
 returns the widget that hold actions created by this menu manager. More...
QList< QAction * > actions () const
 returns the actions holds by the widgetActionsHolder More...
vtkSMProxy * getPrototype (QAction *action) const
 Returns the prototype proxy for the action. More...
void addProxy (const QString &xmlgroup, const QString &xmlname)
 Provides mechanism to explicitly add a proxy to the menu. More...
void removeProxy (const QString &xmlgroup, const QString &xmlname)
 Provides mechanism to explicitly remove a proxy to the menu. More...
QStringList getToolbarCategories () const
 Returns a list of categories that have the "show_in_toolbar" attribute set to 1. More...
QList< QAction * > actions (const QString &category)
 Returns the list of actions in a category. More...
QList< QAction * > actionsInToolbars ()
 Returns this list of actions that appear in toolbars. More...
bool hideForTests (const QString &category) const
 Returns whether or not the category's toolbar should be hidden initially. More...
void addProxyDefinitionUpdateListener (const QString &proxyGroupName)
 Attach an observer to proxy manager to monitor any proxy definition update The detected proxy have to own a hint: More...
void removeProxyDefinitionUpdateListener (const QString &proxyGroupName)
bool supportsQuickLaunch () const
 Returns true if the pqProxyGroupMenuManager has been registered with quick-launch mechanism maintained by pqApplicationCore. More...
void setEnableFavorites (bool enable)
QMenu * getFavoritesMenu ()
QString categoryLabel (const QString &category)
 Given a category name, return the category label. More...
Protected Slots
void triggered ()
void quickLaunch ()
void switchActiveServer ()
void updateMenuStyle ()
void populateRecentlyUsedMenu ()
 called when "recent" menu is being shown. More...
void populateFavoritesMenu ()
 called when "favorites" menu is being shown. More...
void loadRecentlyUsedItems ()
void saveRecentlyUsedItems ()
void loadFavoritesItems ()
 Load the favorites from settings. More...
QAction * getAction (const QString &pgroup, const QString &proxyname)
 Returns the action for a given proxy. More...
QAction * getAddToCategoryAction (const QString &path)
QString ResourceTagName
vtkPVXMLElement * MenuRoot
int RecentlyUsedMenuSize
bool Enabled
bool EnableFavorites
This is use to automatically build the sources and filters menu in ParaView.
Definition at line 18 of file pqProxyGroupMenuManager.h.
◆ pqProxyGroupMenuManager()
pqProxyGroupMenuManager::pqProxyGroupMenuManager ( QMenu *  menu,
const QString &  resourceTagName,
bool  supportsQuickLaunch = true
Constructor.
menu is the Menu to be populated. resourceTagName is the tag name eg. "ParaViewSources" in the client configuration files which contains lists the items shown by this menu. supportsQuickLaunch, set to false if quick-launch is not to be supported for this menu.
◆ ~pqProxyGroupMenuManager()
pqProxyGroupMenuManager::~pqProxyGroupMenuManager ( )
override
◆ menu()
QMenu* pqProxyGroupMenuManager::menu ( ) const
inline
Access the menu.
Definition at line 39 of file pqProxyGroupMenuManager.h.
◆ setRecentlyUsedMenuSize()
void pqProxyGroupMenuManager::setRecentlyUsedMenuSize ( unsigned int  val)
inline
One must call update() or initialize() after changing this value.
Definition at line 45 of file pqProxyGroupMenuManager.h.
◆ recentlyUsedMenuSize()
unsigned int pqProxyGroupMenuManager::recentlyUsedMenuSize ( ) const
inline
Definition at line 47 of file pqProxyGroupMenuManager.h.
◆ widgetActionsHolder()
QWidget* pqProxyGroupMenuManager::widgetActionsHolder ( ) const
◆ actions() [1/2]
QList<QAction*> pqProxyGroupMenuManager::actions ( ) const
◆ getPrototype()
vtkSMProxy* pqProxyGroupMenuManager::getPrototype ( QAction *  action) const
◆ addProxy()
void pqProxyGroupMenuManager::addProxy ( const QString &  xmlgroup,
const QString &  xmlname
◆ removeProxy()
void pqProxyGroupMenuManager::removeProxy ( const QString &  xmlgroup,
◆ getToolbarCategories()
QStringList pqProxyGroupMenuManager::getToolbarCategories ( ) const
◆ actions() [2/2]
QList<QAction*> pqProxyGroupMenuManager::actions ( const QString &  category)
◆ actionsInToolbars()
QList<QAction*> pqProxyGroupMenuManager::actionsInToolbars ( )
◆ hideForTests()
bool pqProxyGroupMenuManager::hideForTests ( const QString &  category) const
◆ addProxyDefinitionUpdateListener()
void pqProxyGroupMenuManager::addProxyDefinitionUpdateListener ( const QString &  proxyGroupName)
<ShowInMenu category="" icon=""/>
where all the attribute are fully optional.
◆ removeProxyDefinitionUpdateListener()
void pqProxyGroupMenuManager::removeProxyDefinitionUpdateListener ( const QString &  proxyGroupName)
◆ supportsQuickLaunch()
bool pqProxyGroupMenuManager::supportsQuickLaunch ( ) const
inline
Definition at line 110 of file pqProxyGroupMenuManager.h.
◆ setEnableFavorites()
void pqProxyGroupMenuManager::setEnableFavorites ( bool  enable)
inline
Definition at line 112 of file pqProxyGroupMenuManager.h.
◆ getFavoritesMenu()
QMenu* pqProxyGroupMenuManager::getFavoritesMenu ( )
◆ categoryLabel()
QString pqProxyGroupMenuManager::categoryLabel ( const QString &  category)
◆ loadConfiguration
void pqProxyGroupMenuManager::loadConfiguration ( vtkPVXMLElement *  )
slot
It will find the elements with resourceTagName in the XML and populate the menu accordingly. Applications do not need to call this method directly, it's by default connected to pqApplicationCore::loadXML()
◆ lookForNewDefinitions
void pqProxyGroupMenuManager::lookForNewDefinitions ( )
slot
◆ removeProxyDefinitionUpdateObservers
void pqProxyGroupMenuManager::removeProxyDefinitionUpdateObservers ( )
slot
◆ addProxyDefinitionUpdateObservers
void pqProxyGroupMenuManager::addProxyDefinitionUpdateObservers ( )
slot
◆ setEnabled
void pqProxyGroupMenuManager::setEnabled ( bool  enable)
slot
◆ populateMenu
virtual void pqProxyGroupMenuManager::populateMenu ( )
virtualslot
Any need to call this only after addProxy() has been used to explicitly add entries.
◆ triggered [1/2]
void pqProxyGroupMenuManager::triggered ( const QString &  group,
const QString &  name
signal
◆ menuPopulated
void pqProxyGroupMenuManager::menuPopulated ( )
signal
◆ triggered [2/2]
void pqProxyGroupMenuManager::triggered ( )
protectedslot
◆ quickLaunch
void pqProxyGroupMenuManager::quickLaunch ( )
protectedslot
◆ switchActiveServer
void pqProxyGroupMenuManager::switchActiveServer ( )
protectedslot
◆ updateMenuStyle
void pqProxyGroupMenuManager::updateMenuStyle ( )
protectedslot
◆ populateRecentlyUsedMenu
void pqProxyGroupMenuManager::populateRecentlyUsedMenu ( )
protectedslot
updates the menu with actions for the filters in the recent list.
◆ populateFavoritesMenu
void pqProxyGroupMenuManager::populateFavoritesMenu ( )
protectedslot
create the menu (and submenu) with actions for the filters in the favorites list.
◆ loadRecentlyUsedItems()
void pqProxyGroupMenuManager::loadRecentlyUsedItems ( )
◆ saveRecentlyUsedItems()
void pqProxyGroupMenuManager::saveRecentlyUsedItems ( )
◆ loadFavoritesItems()
void pqProxyGroupMenuManager::loadFavoritesItems ( )
◆ getAction()
QAction* pqProxyGroupMenuManager::getAction ( const QString &  pgroup,
const QString &  proxyname
◆ getAddToCategoryAction()
QAction* pqProxyGroupMenuManager::getAddToCategoryAction ( const QString &  path)
◆ ResourceTagName
QString pqProxyGroupMenuManager::ResourceTagName
Definition at line 184 of file pqProxyGroupMenuManager.h.
◆ MenuRoot
vtkPVXMLElement* pqProxyGroupMenuManager::MenuRoot
Definition at line 185 of file pqProxyGroupMenuManager.h.
◆ RecentlyUsedMenuSize
int pqProxyGroupMenuManager::RecentlyUsedMenuSize
Definition at line 186 of file pqProxyGroupMenuManager.h.
◆ Enabled
bool pqProxyGroupMenuManager::Enabled
Definition at line 187 of file pqProxyGroupMenuManager.h.
◆ EnableFavorites
bool pqProxyGroupMenuManager::EnableFavorites
Definition at line 188 of file pqProxyGroupMenuManager.h.
