Public Slots | Signals | Public Member Functions | Protected Attributes | List of all members
pqPropertyManager Class Reference
Manages links between Qt properties and unchecked proxy properties This is useful if more than one QWidget exposes a single proxy property In which case the server manager will not keep the widgets synchronized Also provides a mechanims for accepting or rejecting changes for unchecked properties. More...
#include <pqPropertyManager.h>
Inherits QObject.
Collaboration diagram for pqPropertyManager:
Public Slots
void accept ()
 accept property changes by pushing them all down to the server manager More...
void reject ()
 reject property changes and revert all QObject properties More...
void propertyChanged ()
 Called whenever a property changes from the GUI side. More...
Signals
void modified ()
 Signal emitted when there are possible properties to send down to the server manager. More...
void aboutToAccept ()
 Signal emitted when the user has accepted changes. More...
void accepted ()
void rejected ()
 Signal emitted when the user has rejected changes. More...
 pqPropertyManager (QObject *p=nullptr)
 constructor More...
 ~pqPropertyManager () override
 destructor More...
void registerLink (QObject *qObject, const char *qProperty, const char *signal, vtkSMProxy *Proxy, vtkSMProperty *Property, int Index=-1)
 register a QObject property to link with the server manager More...
void unregisterLink (QObject *qObject, const char *qProperty, const char *signal, vtkSMProxy *Proxy, vtkSMProperty *Property, int Index=-1)
 unregister a QObject property to link with the server manager More...
bool isModified () const
 returns whether there are modified properties to send to the server manager More...
void removeAllLinks ()
pqPropertyLinks * Links
bool Modified
Definition at line 24 of file pqPropertyManager.h.
◆ pqPropertyManager()
pqPropertyManager::pqPropertyManager ( QObject *  p = nullptr)
constructor
◆ ~pqPropertyManager()
pqPropertyManager::~pqPropertyManager ( )
override
destructor
◆ registerLink()
void pqPropertyManager::registerLink ( QObject *  qObject,
const char *  qProperty,
const char *  signal,
vtkSMProxy *  Proxy,
vtkSMProperty *  Property,
int  Index = -1
◆ unregisterLink()
void pqPropertyManager::unregisterLink ( QObject *  qObject,
vtkSMProxy *  Proxy,
int  Index = -1
◆ isModified()
bool pqPropertyManager::isModified ( ) const
◆ removeAllLinks()
void pqPropertyManager::removeAllLinks ( )
◆ modified
void pqPropertyManager::modified ( )
signal
◆ aboutToAccept
void pqPropertyManager::aboutToAccept ( )
signal
◆ accepted
void pqPropertyManager::accepted ( )
signal
◆ rejected
void pqPropertyManager::rejected ( )
signal
◆ accept
void pqPropertyManager::accept ( )
slot
◆ reject
void pqPropertyManager::reject ( )
slot
◆ propertyChanged
void pqPropertyManager::propertyChanged ( )
slot
◆ Links
pqPropertyLinks* pqPropertyManager::Links
Definition at line 92 of file pqPropertyManager.h.
◆ Modified
bool pqPropertyManager::Modified
Definition at line 93 of file pqPropertyManager.h.
