Public Slots | Signals | Public Member Functions | Protected Member Functions | List of all members
pqChooseColorPresetReaction Class Reference
Reaction to pop up a color palette chooser dialog. More...
#include <pqChooseColorPresetReaction.h>
Inheritance diagram for pqChooseColorPresetReaction:
Collaboration diagram for pqChooseColorPresetReaction:
Public Slots
bool choosePreset (const char *presetName=nullptr)
 Choose color preset for the representation set using setRepresentation(). More...
void setRepresentation (pqDataRepresentation *repr)
 Set the data representation explicitly when track_active_objects is false. More...
void setTransferFunction (vtkSMProxy *lut)
 Set the transfer function proxy. More...
void updateEnableState () override
 Updates the enabled state. More...
void setAllowsRegexpMatching (bool allow)
 Show/hide widget in the dialog. More...
QRegularExpression regularExpression ()
 Return the regular expression specified in the Dialog. More...
bool loadAnnotations ()
 Return if annotations should be loaded. More...
Signals
void presetApplied (const QString &)
 fired every time a preset is applied. More...
 pqChooseColorPresetReaction (QAction *parent, bool track_active_objects=true)
 ~pqChooseColorPresetReaction () override
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 Constructor. More...
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
void onTriggered () override
 Called when the action is triggered. More...
- Protected Slots inherited from pqReaction
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
- Protected Attributes inherited from pqReaction
bool IsMaster
pqChooseColorPresetReaction is used by pqColorEditorPropertyWidget (for example) allow the user to change the color palette. It pops up a modal dialog with color presets to select and apply. There are three ways of using this reaction:
In all modes, the reaction will fire the presetApplied() signal to indicate a new preset has been applied. Typically one can hook that signal up to render affected views.
Definition at line 43 of file pqChooseColorPresetReaction.h.
◆ pqChooseColorPresetReaction()
pqChooseColorPresetReaction::pqChooseColorPresetReaction ( QAction *  parent,
bool  track_active_objects = true
◆ ~pqChooseColorPresetReaction()
pqChooseColorPresetReaction::~pqChooseColorPresetReaction ( )
override
◆ choosePreset
bool pqChooseColorPresetReaction::choosePreset ( const char *  presetName = nullptr)
slot
Returns false if representation cannot be located or its is not using scalar coloring.
◆ setRepresentation
void pqChooseColorPresetReaction::setRepresentation ( pqDataRepresentation *  repr)
slot
◆ setTransferFunction
void pqChooseColorPresetReaction::setTransferFunction ( vtkSMProxy *  lut)
slot
This can be used, instead of setRepresentation() when track_active_objects was false to directly set the transfer function proxy on which to apply the preset.
◆ updateEnableState
void pqChooseColorPresetReaction::updateEnableState ( )
overrideslot
◆ setAllowsRegexpMatching
void pqChooseColorPresetReaction::setAllowsRegexpMatching ( bool  allow)
inlineslot
Allows a regexp as user entry to do the matching between data values and preset. Intended to be used for series preset.
Definition at line 82 of file pqChooseColorPresetReaction.h.
◆ regularExpression
QRegularExpression pqChooseColorPresetReaction::regularExpression ( )
slot
◆ loadAnnotations
bool pqChooseColorPresetReaction::loadAnnotations ( )
slot
◆ presetApplied
void pqChooseColorPresetReaction::presetApplied ( const QString &  )
signal
◆ onTriggered()
void pqChooseColorPresetReaction::onTriggered ( )
overrideprotectedvirtual
