1 set(_ParaViewTranslations_cmake_dir
"${CMAKE_CURRENT_LIST_DIR}")
4 @brief Generate a C++ header with input XML labels and UI strings that can be parsed by
5 Qt Linguist tools. It is
using a python utility at
6 Utilities/Localization/XML_translations_header_generator.py
15 * `TARGET`: (Required) The name of the target that generate the translation
17 * `INPUT_FILES`: (Required) The absolute path of the input files.
18 * `RESULT_FILE`: (Required) The absolute path of the desired result file.
21 cmake_parse_arguments(PARSE_ARGV 0 _pv_generate_tr_h
25 if (_pv_generate_tr_h_UNPARSED_ARGUMENTS)
27 "Unrecognized arguments for paraview_generate_translation_header: "
28 "${_pv_generate_tr_h_UNPARSED_ARGUMENTS}.")
30 if (NOT DEFINED _pv_generate_tr_h_RESULT_FILE)
32 "The `RESULT_FILE` argument is required.")
34 if (NOT DEFINED _pv_generate_tr_h_INPUT_FILES)
36 "The `INPUT_FILES` argument is required.")
38 if (NOT DEFINED _pv_generate_tr_h_TARGET)
40 "The `TARGET` argument is required.")
42 find_package(Python3 QUIET REQUIRED COMPONENTS Interpreter)
43 add_custom_command(OUTPUT ${_pv_generate_tr_h_RESULT_FILE}
44 COMMAND
"$<TARGET_FILE:Python3::Interpreter>" "${_ParaViewTranslations_cmake_dir}/XML_translations_header_generator.py" -o
"${_pv_generate_tr_h_RESULT_FILE}" ${_pv_generate_tr_h_INPUT_FILES} -s
"${CMAKE_SOURCE_DIR}/")
45 add_custom_target(
"${_pv_generate_tr_h_TARGET}"
46 DEPENDS
"${_pv_generate_tr_h_RESULT_FILE}")
55 INPUT_FILES <files...>
59 * `TARGET`: (Required) The name of the target that generate the translation
61 * `INPUT_FILES`: (Required) The source files to search translatable strings in.
62 * `OUTPUT_TS`: (Required) The absolute path of the desired result file.
65 cmake_parse_arguments(PARSE_ARGV 0 _pv_create_tr
69 if (_pv_create_tr_UNPARSED_ARGUMENTS)
71 "Unrecognized arguments for paraview_create_translation: "
72 "${_pv_create_tr_UNPARSED_ARGUMENTS}.")
74 if (NOT DEFINED _pv_create_tr_TARGET)
76 "The `TARGET` argument is required.")
78 if (NOT DEFINED _pv_create_tr_FILES)
80 "The `FILES` argument is required.")
82 if (NOT DEFINED _pv_create_tr_OUTPUT_TS)
84 "The `OUTPUT_TS` argument is required.")
87 # Transforms all relative paths in the provided
88 # FILES by their absolute paths.
89 set(_pv_create_tr_files)
90 foreach (_pv_create_tr_in_file IN LISTS _pv_create_tr_FILES)
91 if (NOT IS_ABSOLUTE
"${_pv_create_tr_in_file}")
92 string(PREPEND _pv_create_tr_in_file
93 "${CMAKE_CURRENT_SOURCE_DIR}/")
95 list(APPEND _pv_create_tr_files ${_pv_create_tr_in_file})
97 find_package(
"Qt${PARAVIEW_QT_MAJOR_VERSION}" REQUIRED QUIET COMPONENTS LinguistTools)
98 get_filename_component(_pv_create_tr_directory ${_pv_create_tr_OUTPUT_TS} DIRECTORY)
99 file(MAKE_DIRECTORY
"${_pv_create_tr_directory}")
100 # List of files is stored in a .pro file because the command can reach the Windows limit of character
101 set(_pv_create_tr_pro_file
"${CMAKE_CURRENT_BINARY_DIR}/${_pv_create_tr_TARGET}.pro")
102 string(REPLACE
";" " \\\n" _translations_files_list
"${_pv_create_tr_files}")
104 "${CMAKE_SOURCE_DIR}/CMake/paraview_translation_files_list.pro.in"
105 "${_pv_create_tr_pro_file}")
107 OUTPUT
"${_pv_create_tr_OUTPUT_TS}"
108 COMMAND
"$<TARGET_FILE:Qt${PARAVIEW_QT_MAJOR_VERSION}::lupdate>" ${_pv_create_tr_pro_file}
109 DEPENDS ${_pv_create_tr_files})
110 add_custom_target(
"${_pv_create_tr_TARGET}"
111 DEPENDS
"${_pv_create_tr_OUTPUT_TS}")
