Functions
ParaViewTranslations.cmake File Reference
Functions
function paraview_generate_translation_header ()
 Generate a C++ header with input XML labels and UI strings that can be parsed by Qt Linguist tools. More...
function paraview_create_translation ()
 Generate a Qt translation source file from the given source files. More...
Function Documentation
◆ paraview_generate_translation_header()
function paraview_generate_translation_header ( )
It is using a python utility at Utilities/Localization/XML_translations_header_generator.py
TARGET <name>
INPUT_FILES <file>...
RESULT_FILE <file>)
  • TARGET: (Required) The name of the target that generate the translation header file.
  • INPUT_FILES: (Required) The absolute path of the input files.
  • RESULT_FILE: (Required) The absolute path of the desired result file.
Definition at line 20 of file ParaViewTranslations.cmake.
◆ paraview_create_translation()
function paraview_create_translation ( )
TARGET <name>
INPUT_FILES <files...>
OUTPUT_TS <file>
  • TARGET: (Required) The name of the target that generate the translation source file.
  • INPUT_FILES: (Required) The source files to search translatable strings in.
  • OUTPUT_TS: (Required) The absolute path of the desired result file.
Definition at line 64 of file ParaViewTranslations.cmake.
function paraview_generate_translation_header()
Definition: ParaViewTranslations.cmake:20
function paraview_create_translation()
Definition: ParaViewTranslations.cmake:64
