2 cmake_policy(SET CMP0057 NEW)
4 set(_ParaViewPlugin_cmake_dir
"${CMAKE_CURRENT_LIST_DIR}")
7 # ParaView Plugin CMake API
14 ## Conditionally output debug statements
17 controlled by the `_paraview_plugin_log` variable which contains a list of
24 If the `domain` is
enabled for debugging, the `format` argument is configured
25 and printed. It should contain `@` variable expansions to
replace rather than
26 it being done outside. This helps to avoid the cost of generating large strings
27 when debugging is disabled.
30 if (NOT _paraview_plugin_log STREQUAL
"ALL" AND
31 NOT domain IN_LIST _paraview_plugin_log)
35 string(CONFIGURE "${format}
" _paraview_plugin_debug_msg)
36 if (_paraview_plugin_debug_msg)
38 "ParaView plugin debug ${domain}: ${_paraview_plugin_debug_msg}
45 Similar to VTK modules, plugins first have to be discovered. The
46 `paraview_plugin_find_plugins` function does this. The output variable is the
47 list of discovered `paraview.plugin` files.
50 paraview_plugin_find_plugins(<output> [<directory>...])
53 function (paraview_plugin_find_plugins output)
54 set(_paraview_find_plugins_all)
55 foreach (_paraview_find_plugins_directory IN LISTS ARGN)
56 file(GLOB_RECURSE _paraview_find_plugins_plugins
57 "${_paraview_find_plugins_directory}/paraview.plugin
58 list(APPEND _paraview_find_plugins_all
59 ${_paraview_find_plugins_plugins})
61 set("${output}
" ${_paraview_find_plugins_all} PARENT_SCOPE)
67 The `paraview.plugin` file is parsed and used as arguments to a CMake function.
77 Pixie file reader using ADIOS
82 The supported arguments are:
84 * `NAME`: (Required) The name of the plugin.
85 * `DESCRIPTION`: (Recommended) Short text describing what the plugin does.
86 * `CONDITION`: Arguments to CMake's `if` command which may be used to hide
87 the plugin for certain platforms or other reasons. If the expression is
88 false, the module is completely ignored.
89 * `REQUIRES_MODULES`: If the plugin is enabled, these modules will be listed
90 as those required to build the enabled plugins.
92 macro (_paraview_plugin_parse_args name_output)
93 cmake_parse_arguments("_name
101 "A ParaView plugin requires a
name (from ${_paraview_scan_plugin_file}).
103 set("${name_output}
" "${_name_NAME}
105 cmake_parse_arguments("${_name_NAME}
108 "DESCRIPTION;REQUIRES_MODULES;CONDITION
111 if (${_name_NAME}_UNPARSED_ARGUMENTS)
113 "Unparsed arguments
for ${_name_NAME}:
114 "${${_name_NAME}_UNPARSED_ARGUMENTS}
117 if (NOT ${_name_NAME}_DESCRIPTION)
118 message(WARNING "The ${_name_NAME} module should have a
description")
120 string(REPLACE ";
" " " "${_name_NAME}_DESCRIPTION
" "${${_name_NAME}_DESCRIPTION}
126 Once the `paraview.plugin` files have been found, they need to be scanned to
127 determine which should be built. Generally, plugins should be scanned first in
128 order to use the `REQUIRES_MODULES` list to enable them during the scan for
129 their required modules.
132 paraview_plugin_scan(
133 PLUGIN_FILES <file>...
134 PROVIDES_PLUGINS <variable>
135 [ENABLE_BY_DEFAULT <ON|OFF>]
136 [HIDE_PLUGINS_FROM_CACHE <ON|OFF>]
137 [REQUIRES_MODULES <module>...])
140 * `PLUGIN_FILES`: (Required) The list of plugin files to scan.
141 * `PROVIDES_PLUGINS`: (Required) This variable contains a list of the plugins
143 * `ENABLE_BY_DEFAULT`: (Defaults to `OFF`) Whether to enable plugins by
145 * `HIDE_PLUGINS_FROM_CACHE`: (Defaults to `OFF`) Whether to display options
146 to enable and disable plugins in the cache or not.
147 * `REQUIRES_MODULES`: The list of modules required by the enabled plugins.
150 function (paraview_plugin_scan)
151 cmake_parse_arguments(_paraview_scan
153 "ENABLE_BY_DEFAULT;HIDE_PLUGINS_FROM_CACHE;REQUIRES_MODULES;PROVIDES_PLUGINS
157 if (_paraview_scan_UNPARSED_ARGUMENTS)
160 "${_paraview_scan_UNPARSED_ARGUMENTS}
163 if (NOT DEFINED _paraview_scan_ENABLE_BY_DEFAULT)
164 set(_paraview_scan_ENABLE_BY_DEFAULT OFF)
167 if (NOT DEFINED _paraview_scan_HIDE_PLUGINS_FROM_CACHE)
168 set(_paraview_scan_HIDE_PLUGINS_FROM_CACHE OFF)
171 if (NOT DEFINED _paraview_scan_PROVIDES_PLUGINS)
173 "The `PROVIDES_PLUGINS` argument is required.
176 if (NOT _paraview_scan_PLUGIN_FILES)
178 "No plugin files given to scan.
181 set(_paraview_scan_option_default_type BOOL)
182 if (_paraview_scan_HIDE_PLUGINS_FROM_CACHE)
183 set(_paraview_scan_option_default_type INTERNAL)
186 set(_paraview_scan_provided_plugins)
187 set(_paraview_scan_required_modules)
189 foreach (_paraview_scan_plugin_file IN LISTS _paraview_scan_PLUGIN_FILES)
190 if (NOT IS_ABSOLUTE "${_paraview_scan_plugin_file}
191 set(_paraview_scan_plugin_file
192 "${CMAKE_CURRENT_SOURCE_DIR}/${_paraview_scan_plugin_file}
195 set_property(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}
" APPEND
197 CMAKE_CONFIGURE_DEPENDS "${_paraview_scan_plugin_file}
199 file(READ "${_paraview_scan_plugin_file}
" _paraview_scan_plugin_args)
201 string(REGEX REPLACE "#[^\n]*\n
" "\n
" _paraview_scan_plugin_args "${_paraview_scan_plugin_args}
202 # Use argument splitting.
203 string(REGEX REPLACE "( |\n)+
204 _paraview_plugin_parse_args(_paraview_scan_plugin_name ${_paraview_scan_plugin_args})
205 _paraview_plugin_debug(plugin "@_paraview_scan_plugin_name@ declared by @_paraview_scan_plugin_file
207 list(APPEND _paraview_scan_all_plugins
208 "${_paraview_scan_plugin_name}
210 set(_paraview_scan_plugin_default "${_paraview_scan_ENABLE_BY_DEFAULT}
211 if (DEFINED "_paraview_plugin_default_${_paraview_scan_plugin_name}
212 set(_paraview_scan_plugin_default "${_paraview_plugin_default_${_paraview_scan_plugin_name}}
214 option("PARAVIEW_PLUGIN_ENABLE_${_paraview_scan_plugin_name}
215 "Enable the ${_paraview_scan_plugin_name} plugin. ${${_paraview_scan_plugin_name}_DESCRIPTION}
216 "${_paraview_scan_plugin_default}
217 set("_paraview_scan_enable_${_paraview_scan_plugin_name}
218 "${PARAVIEW_PLUGIN_ENABLE_${_paraview_scan_plugin_name}}
220 set_property(CACHE "PARAVIEW_PLUGIN_ENABLE_${_paraview_scan_plugin_name}
222 TYPE "${_paraview_scan_option_default_type}
224 if (DEFINED ${_paraview_scan_plugin_name}_CONDITION)
225 if (NOT (${${_paraview_scan_plugin_name}_CONDITION}))
226 if (DEFINED "PARAVIEW_PLUGIN_ENABLE_${_paraview_scan_plugin_name}
227 set_property(CACHE "PARAVIEW_PLUGIN_ENABLE_${_paraview_scan_plugin_name}
231 _paraview_plugin_debug(plugin "@_paraview_scan_plugin_name@ hidden by its `CONDITION`
236 if (_paraview_scan_enable_${_paraview_scan_plugin_name})
237 _paraview_plugin_debug(plugin "@_paraview_scan_plugin_name@ requested via cache
value")
238 list(APPEND _paraview_scan_provided_plugins
239 "${_paraview_scan_plugin_name}
240 list(APPEND _paraview_scan_required_modules
241 ${${_paraview_scan_plugin_name}_REQUIRES_MODULES})
246 "_paraview_plugin_${_paraview_scan_plugin_name}_file
" "${_paraview_scan_plugin_file}
249 "_paraview_plugin_${_paraview_scan_plugin_name}_description
" "${${_paraview_scan_plugin_name}_DESCRIPTION}
252 "_paraview_plugin_${_paraview_scan_plugin_name}_required_modules
" "${${_paraview_scan_plugin_name}_REQUIRES_MODULES}
255 if (DEFINED _paraview_scan_REQUIRES_MODULES)
256 set("${_paraview_scan_REQUIRES_MODULES}
257 ${_paraview_scan_required_modules}
261 set("${_paraview_scan_PROVIDES_PLUGINS}
262 ${_paraview_scan_provided_plugins}
266 function (_paraview_plugin_check_destdir variable)
267 if (NOT DEFINED "${variable}
269 "It appears as though ${variable} is not defined, but is needed to
270 "default a destination directory
for build artifacts. Usually
this is
271 "resolved by `include(GNUInstallDirs)` at the
top of the project.
278 Once all plugins have been scanned, they need to be built.
281 paraview_plugin_build(
283 [AUTOLOAD <plugin>...]
284 [PLUGINS_COMPONENT <component>]
287 [INSTALL_EXPORT <export>]
288 [CMAKE_DESTINATION <destination>]
289 [TARGET_COMPONENT <component>]
290 [INSTALL_HEADERS <ON|OFF>]
292 [HEADERS_DESTINATION <destination>]
293 [RUNTIME_DESTINATION <destination>]
294 [LIBRARY_DESTINATION <destination>]
295 [LIBRARY_SUBDIRECTORY <subdirectory>]
296 [ADD_INSTALL_RPATHS <ON|OFF>]
298 [PLUGINS_FILE_NAME <filename>]
299 [DISABLE_XML_DOCUMENTATION <ON|OFF>])
301 [GENERATE_SPDX <ON|OFF>]
302 [SPDX_DOCUMENT_NAMESPACE <uri>]
303 [SPDX_DOWNLOAD_LOCATION <url>]
306 * `PLUGINS`: (Required) The list of plugins to build. May be empty.
307 * `AUTOLOAD`: A list of plugins to mark for autoloading.
308 * `PLUGINS_COMPONENT`: (Defaults to `paraview_plugins`) The installation
309 component to use for installed plugins.
310 * `TARGET`: (Recommended) The name of an interface target to generate. This
311 provides. an initialization function `<TARGET>_initialize` which
312 initializes static plugins. The function is provided, but is a no-op for
313 shared plugin builds.
314 * `INSTALL_EXPORT`: If provided, the generated target will be added to the
316 * `CMAKE_DESTINATION`: If provided, the plugin target's properties will be
317 written to a file named `<TARGET>-paraview-plugin-properties.cmake` in the
318 specified destination.
319 * `TARGET_COMPONENT`: (Defaults to `development`) The component to use for
321 * `INSTALL_HEADERS`: (Defaults to `ON`) Whether to install headers or not.
322 * `HEADERS_DESTINATION`: (Defaults to `${CMAKE_INSTALL_INCLUDEDIR}`) Where to
323 install include files.
324 * `RUNTIME_DESTINATION`: (Defaults to `${CMAKE_INSTALL_BINDIR}`) Where to
325 install runtime files.
326 * `LIBRARY_DESTINATION`: (Defaults to `${CMAKE_INSTALL_LIBDIR}`) Where to
327 install modules built by plugins.
328 * `LIBRARY_SUBDIRECTORY`: (Defaults to `""`) Where to install the plugins
329 themselves. Each plugin lives in a directory of its name in
330 `<RUNTIME_DESTINATION>/<LIBRARY_SUBDIRECTORY>` (for Windows) or
331 `<LIBRARY_DESTINATION>/<LIBRARY_SUBDIRECTORY>` for other platforms.
332 * `ADD_INSTALL_RPATHS`: (Defaults to `ON`) If specified, an RPATH to load
333 dependent libraries from the `LIBRARY_DESTINATION` from the plugins will be
335 * `PLUGINS_FILE_NAME`: The name of the XML plugin file to generate for the
336 built plugins. This file will be placed under
337 `<LIBRARY_DESTINATION>/<LIBRARY_SUBDIRECTORY>`. It will be installed with
338 the `plugin` component.
339 * `DISABLE_XML_DOCUMENTATION`: (Defaults to `OFF`) Whether to forcefully
340 disable XML documentation or not.
341 * ``GENERATE_SPDX``: (Defaults to ``OFF``) Whether or not to generate and install
342 SPDX file for each modules.
343 * ``SPDX_DOCUMENT_NAMESPACE``: (Defaults to ``""``) Document namespace to use when
344 generating SPDX files.
345 * ``SPDX_DOWNLOAD_LOCATION``: (Defaults to ``""``) Download location to use when
346 generating SPDX files.
348 function (paraview_plugin_build)
349 cmake_parse_arguments(_paraview_build
351 "HEADERS_DESTINATION;RUNTIME_DESTINATION;LIBRARY_DESTINATION;LIBRARY_SUBDIRECTORY;TARGET;PLUGINS_FILE_NAME;INSTALL_EXPORT;CMAKE_DESTINATION;PLUGINS_COMPONENT;TARGET_COMPONENT;ADD_INSTALL_RPATHS;INSTALL_HEADERS;DISABLE_XML_DOCUMENTATION;GENERATE_SPDX;SPDX_DOCUMENT_NAMESPACE;SPDX_DOWNLOAD_LOCATION
355 if (_paraview_build_UNPARSED_ARGUMENTS)
358 "${_paraview_build_UNPARSED_ARGUMENTS}
361 if (NOT DEFINED _paraview_build_HEADERS_DESTINATION)
362 _paraview_plugin_check_destdir(CMAKE_INSTALL_INCLUDEDIR)
363 set(_paraview_build_HEADERS_DESTINATION "${CMAKE_INSTALL_INCLUDEDIR}
366 if (NOT DEFINED _paraview_build_RUNTIME_DESTINATION)
367 _paraview_plugin_check_destdir(CMAKE_INSTALL_BINDIR)
368 set(_paraview_build_RUNTIME_DESTINATION "${CMAKE_INSTALL_BINDIR}
371 if (NOT DEFINED _paraview_build_LIBRARY_DESTINATION)
372 _paraview_plugin_check_destdir(CMAKE_INSTALL_LIBDIR)
373 set(_paraview_build_LIBRARY_DESTINATION "${CMAKE_INSTALL_LIBDIR}
376 if (NOT DEFINED _paraview_build_LIBRARY_SUBDIRECTORY)
377 set(_paraview_build_LIBRARY_SUBDIRECTORY "")
380 if (NOT _paraview_build_DISABLE_XML_DOCUMENTATION)
381 set(_paraview_build_DISABLE_XML_DOCUMENTATION OFF)
384 if (NOT DEFINED _paraview_build_GENERATE_SPDX)
385 set(_paraview_build_GENERATE_SPDX OFF)
388 if (NOT _paraview_build_SPDX_DOCUMENT_NAMESPACE)
389 set(_paraview_build_SPDX_DOCUMENT_NAMESPACE "")
392 if (NOT _paraview_build_SPDX_DOWNLOAD_LOCATION)
393 set(_paraview_build_SPDX_DOWNLOAD_LOCATION "")
396 if (NOT DEFINED _paraview_build_INSTALL_HEADERS)
397 set(_paraview_build_INSTALL_HEADERS ON)
400 if (NOT DEFINED _paraview_build_ADD_INSTALL_RPATHS)
401 set(_paraview_build_ADD_INSTALL_RPATHS ON)
403 if (_paraview_build_ADD_INSTALL_RPATHS)
404 if (NOT _paraview_build_LIBRARY_SUBDIRECTORY STREQUAL "")
405 file(RELATIVE_PATH _paraview_build_relpath
406 "/prefix/${_paraview_build_LIBRARY_DESTINATION}/${_paraview_build_LIBRARY_SUBDIRECTORY}/plugin
407 "/prefix/${_paraview_build_LIBRARY_DESTINATION}
409 file(RELATIVE_PATH _paraview_build_relpath
410 "/prefix/${_paraview_build_LIBRARY_DESTINATION}/plugin
411 "/prefix/${_paraview_build_LIBRARY_DESTINATION}
414 list(APPEND CMAKE_INSTALL_RPATH
415 "@loader_path/${_paraview_build_relpath}
417 list(APPEND CMAKE_INSTALL_RPATH
418 "$ORIGIN/${_paraview_build_relpath}
422 if (DEFINED _paraview_build_INSTALL_EXPORT
423 AND NOT DEFINED _paraview_build_TARGET)
425 "The `INSTALL_EXPORT` argument requires the `TARGET` argument.
428 if (DEFINED _paraview_build_INSTALL_EXPORT
429 AND NOT DEFINED _paraview_build_CMAKE_DESTINATION)
431 "The `INSTALL_EXPORT` argument requires the `CMAKE_DESTINATION` argument.
434 set(_paraview_build_extra_destinations)
435 if (DEFINED _paraview_build_CMAKE_DESTINATION)
436 list(APPEND _paraview_build_extra_destinations
438 if (NOT DEFINED _paraview_build_TARGET)
440 "The `CMAKE_DESTINATION` argument requires the `TARGET` argument.
444 if (DEFINED _paraview_build_TARGET)
445 _vtk_module_split_module_name("${_paraview_build_TARGET}
" _paraview_build)
446 string(REPLACE "::
" "_
" _paraview_build_target_safe "${_paraview_build_TARGET}
449 _vtk_module_check_destinations(_paraview_build_
454 ${_paraview_build_extra_destinations})
456 if (NOT CMAKE_RUNTIME_OUTPUT_DIRECTORY)
457 set(CMAKE_RUNTIME_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${_paraview_build_RUNTIME_DESTINATION}
459 if (NOT CMAKE_LIBRARY_OUTPUT_DIRECTORY)
460 set(CMAKE_LIBRARY_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${_paraview_build_LIBRARY_DESTINATION}
462 if (NOT CMAKE_ARCHIVE_OUTPUT_DIRECTORY)
463 set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${_paraview_build_LIBRARY_DESTINATION}
467 set(_paraview_build_plugin_destination "${_paraview_build_RUNTIME_DESTINATION}
469 set(_paraview_build_plugin_destination "${_paraview_build_LIBRARY_DESTINATION}
471 if (NOT _paraview_build_LIBRARY_SUBDIRECTORY STREQUAL "")
472 string(APPEND _paraview_build_plugin_destination "/${_paraview_build_LIBRARY_SUBDIRECTORY}
475 foreach (_paraview_build_plugin IN LISTS _paraview_build_PLUGINS)
476 get_property(_paraview_build_plugin_file GLOBAL
477 PROPERTY "_paraview_plugin_${_paraview_build_plugin}_file
478 if (NOT _paraview_build_plugin_file)
480 "The requested ${_paraview_build_plugin} plugin is not a ParaView plugin.
483 _paraview_plugin_debug(building "@_paraview_build_plugin@ is being built
485 # Make a variable for where the plugin should go.
486 set(_paraview_build_plugin_directory
487 "${_paraview_build_plugin_destination}/${_paraview_build_plugin}
489 # TODO: Support external plugins?
490 get_filename_component(_paraview_build_plugin_dir "${_paraview_build_plugin_file}
" DIRECTORY)
491 file(RELATIVE_PATH _paraview_build_plugin_subdir "${CMAKE_SOURCE_DIR}
" "${_paraview_build_plugin_dir}
493 "${CMAKE_SOURCE_DIR}/${_paraview_build_plugin_subdir}
494 "${CMAKE_BINARY_DIR}/${_paraview_build_plugin_subdir}
497 if (DEFINED _paraview_build_TARGET)
498 add_library("${_paraview_build_TARGET_NAME}
" INTERFACE)
499 if (_paraview_build_NAMESPACE)
500 add_library("${_paraview_build_TARGET}
" ALIAS "${_paraview_build_TARGET_NAME}
502 target_include_directories("${_paraview_build_TARGET_NAME}
504 "$<BUILD_INTERFACE:${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_paraview_build_target_safe}>
505 "$<INSTALL_INTERFACE:${_paraview_build_HEADERS_DESTINATION}>
506 set(_paraview_build_include_file
507 "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_paraview_build_target_safe}/${_paraview_build_target_safe}.h
509 set(_paraview_static_plugins)
510 foreach (_paraview_build_plugin IN LISTS _paraview_build_PLUGINS)
511 get_property(_paraview_build_plugin_type
512 TARGET "${_paraview_build_plugin}
514 if (_paraview_build_plugin_type STREQUAL "STATIC_LIBRARY
515 list(APPEND _paraview_static_plugins
516 "${_paraview_build_plugin}
520 if (_paraview_static_plugins)
521 target_link_libraries("${_paraview_build_TARGET_NAME}
523 ParaView::RemotingCore
524 ${_paraview_static_plugins})
526 set(_paraview_build_declarations)
527 set(_paraview_build_calls)
528 set(_paraview_build_names)
529 foreach (_paraview_build_plugin IN LISTS _paraview_static_plugins)
530 string(APPEND _paraview_build_declarations
531 "PV_PLUGIN_IMPORT_INIT(${_paraview_build_plugin});\n
532 string(APPEND _paraview_build_calls
533 " if (sname == \
"${_paraview_build_plugin}\")
537 static bool loaded = false;
540 loaded = PV_PLUGIN_IMPORT(${_paraview_build_plugin});
545 string(APPEND _paraview_build_names
546 " names.emplace_back(\"${_paraview_build_plugin}\");\n")
549 set(_paraview_build_include_content
550 "
#ifndef ${_paraview_build_target_safe}_h
551 #define ${_paraview_build_target_safe}_h
553 #define PARAVIEW_BUILDING_PLUGIN
554 #define PARAVIEW_PLUGIN_BUILT_SHARED 0
555 #include \"vtkPVPlugin.h\"
556 #include \"vtkPVPluginLoader.h\"
557 #include \"vtkPVPluginTracker.h\"
560 ${_paraview_build_declarations}
561 static bool ${_paraview_build_target_safe}_static_plugins_load(
const char* name);
562 static bool ${_paraview_build_target_safe}_static_plugins_search(
const char* name);
563 static void ${_paraview_build_target_safe}_static_plugins_list(
const char* appname, std::vector<std::string>& names);
565 static void ${_paraview_build_target_safe}_initialize()
572 static bool ${_paraview_build_target_safe}_static_plugins_func(
const char* name,
bool load);
574 static bool ${_paraview_build_target_safe}_static_plugins_load(
const char* name)
576 return ${_paraview_build_target_safe}_static_plugins_func(name,
true);
579 static bool ${_paraview_build_target_safe}_static_plugins_search(
const char* name)
581 return ${_paraview_build_target_safe}_static_plugins_func(name,
false);
584 static void ${_paraview_build_target_safe}_static_plugins_list(
586 ${_paraview_build_names}
591 static bool ${_paraview_build_target_safe}_static_plugins_func(
const char* name,
bool load)
593 std::string
const sname =
name;
595 ${_paraview_build_calls}
601 set(_paraview_build_include_content
602 "#ifndef ${_paraview_build_target_safe}_h
603 #define ${_paraview_build_target_safe}_h
605 static void ${_paraview_build_target_safe}_initialize()
613 OUTPUT "${_paraview_build_include_file}
614 CONTENT "${_paraview_build_include_content}
615 if (_paraview_build_INSTALL_HEADERS)
617 FILES "${_paraview_build_include_file}
618 DESTINATION "${_paraview_build_HEADERS_DESTINATION}
619 COMPONENT "${_paraview_build_TARGET_COMPONENT}
622 if (DEFINED _paraview_build_INSTALL_EXPORT)
624 TARGETS "${_paraview_build_TARGET_NAME}
625 EXPORT "${_paraview_build_INSTALL_EXPORT}
626 COMPONENT "${_paraview_build_TARGET_COMPONENT}
628 set(_paraview_build_required_exports_include_file_name "${_paraview_build_INSTALL_EXPORT}-${_paraview_build_TARGET_NAME}-targets-depends.cmake
629 set(_paraview_build_required_exports_include_build_file
630 "${CMAKE_BINARY_DIR}/${_paraview_build_CMAKE_DESTINATION}/${_paraview_build_required_exports_include_file_name}
631 set(_paraview_build_required_exports_include_contents "")
632 get_property(_paraview_build_required_exports GLOBAL
633 PROPERTY "paraview_plugin_${_paraview_build_TARGET}_required_exports
634 if (_paraview_build_required_exports)
635 foreach (_paraview_build_required_export IN LISTS _paraview_build_required_exports)
636 string(APPEND _paraview_build_required_exports_include_contents
637 "include(\
"\${CMAKE_CURRENT_LIST_DIR}/${_paraview_build_required_export}-targets.cmake\")\n"
638 "include(\"\${CMAKE_CURRENT_LIST_DIR}/${_paraview_build_required_export}-vtk-module-properties.cmake\")\n"
641 get_property(_paraview_build_modules GLOBAL
642 PROPERTY "paraview_plugin_${_paraview_build_required_export}_modules
643 if (_paraview_build_modules)
644 vtk_module_export_find_packages(
645 CMAKE_DESTINATION "${_paraview_build_CMAKE_DESTINATION}
646 FILE_NAME "${_paraview_build_required_export}-
vtk-module-find-packages.cmake
647 MODULES ${_paraview_build_modules})
649 # TODO: The list of modules should be checked for their `_FOUND`
650 # variables being false and propagate it up through the parent
651 # project's `_FOUND` variable.
652 string(APPEND _paraview_build_required_exports_include_contents
653 "set(CMAKE_FIND_PACKAGE_NAME_save \
"\${CMAKE_FIND_PACKAGE_NAME}\")\n"
654 "set(${_paraview_build_required_export}_FIND_QUIETLY \"\${\${CMAKE_FIND_PACKAGE_NAME}_FIND_QUIETLY}\")\n"
655 "set(${_paraview_build_required_export}_FIND_COMPONENTS)\n"
656 "set(CMAKE_FIND_PACKAGE_NAME \"${_paraview_build_required_export}\")\n"
657 "include(\"\${CMAKE_CURRENT_LIST_DIR}/${_paraview_build_required_export}-vtk-module-find-packages.cmake\")\n"
658 "set(CMAKE_FIND_PACKAGE_NAME \"\${CMAKE_FIND_PACKAGE_NAME_save}\")\n"
659 "unset(${_paraview_build_required_export}_FIND_QUIETLY)\n"
660 "unset(${_paraview_build_required_export}_FIND_COMPONENTS)\n"
661 "unset(CMAKE_FIND_PACKAGE_NAME_save)\n"
668 OUTPUT "${_paraview_build_required_exports_include_build_file}
669 CONTENT "${_paraview_build_required_exports_include_contents}
670 if (_paraview_build_INSTALL_HEADERS)
672 FILES "${_paraview_build_required_exports_include_build_file}
673 DESTINATION "${_paraview_build_CMAKE_DESTINATION}
674 COMPONENT "${_paraview_build_TARGET_COMPONENT}
677 set(_paraview_build_namespace_args)
678 if (_paraview_build_NAMESPACE)
679 list(APPEND _paraview_build_namespace_args
680 NAMESPACE "${_paraview_build_NAMESPACE}::
683 if (_paraview_build_INSTALL_HEADERS)
685 EXPORT "${_paraview_build_INSTALL_EXPORT}
686 ${_paraview_build_namespace_args}
687 FILE "${CMAKE_BINARY_DIR}/${_paraview_build_CMAKE_DESTINATION}/${_paraview_build_INSTALL_EXPORT}-targets.cmake
689 EXPORT "${_paraview_build_INSTALL_EXPORT}
690 DESTINATION "${_paraview_build_CMAKE_DESTINATION}
691 ${_paraview_build_namespace_args}
692 FILE "${_paraview_build_INSTALL_EXPORT}-targets.cmake
693 COMPONENT "${_paraview_build_TARGET_COMPONENT}
698 if (DEFINED _paraview_build_PLUGINS_FILE_NAME)
699 set(_paraview_build_xml_file
700 "${CMAKE_BINARY_DIR}/${_paraview_build_plugin_destination}/${_paraview_build_PLUGINS_FILE_NAME}
701 set(_paraview_build_xml_content
702 "<?xml
version=\
"1.0\"?>\n<Plugins>\n")
703 foreach (_paraview_build_plugin IN LISTS _paraview_build_PLUGINS)
704 set(_paraview_build_autoload 0)
705 if (_paraview_build_plugin IN_LIST _paraview_build_AUTOLOAD)
706 set(_paraview_build_autoload 1)
708 string(APPEND _paraview_build_xml_content
709 " <Plugin name=\"${_paraview_build_plugin}\
" auto_load=\"${_paraview_build_autoload}\"/>\n")
711 string(APPEND _paraview_build_xml_content
715 OUTPUT "${_paraview_build_xml_file}
716 CONTENT "${_paraview_build_xml_content}
718 FILES "${_paraview_build_xml_file}
719 DESTINATION "${_paraview_build_plugin_destination}
720 COMPONENT "${_paraview_build_TARGET_COMPONENT}
722 if (DEFINED _paraview_build_INSTALL_EXPORT)
723 set_property(TARGET "${_paraview_build_TARGET_NAME}
725 "INTERFACE_paraview_plugin_plugins_file
" "${_paraview_build_xml_file}
727 if (DEFINED _paraview_build_RUNTIME_DESTINATION)
728 set_property(TARGET "${_paraview_build_TARGET_NAME}
730 "INTERFACE_paraview_plugin_plugins_file_install
" "${_paraview_build_plugin_destination}/${_paraview_build_PLUGINS_FILE_NAME}
733 if (DEFINED _paraview_build_CMAKE_DESTINATION)
734 set(_paraview_build_properties_filename "${_paraview_build_INSTALL_EXPORT}-paraview-plugin-properties.cmake
735 set(_paraview_build_properties_build_file
736 "${CMAKE_BINARY_DIR}/${_paraview_build_CMAKE_DESTINATION}/${_paraview_build_properties_filename}
737 set(_paraview_build_properties_install_file
738 "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_paraview_build_properties_filename}.install
740 file(WRITE "${_paraview_build_properties_build_file}
741 file(WRITE "${_paraview_build_properties_install_file}
743 _vtk_module_write_import_prefix(
744 "${_paraview_build_properties_install_file}
745 "${_paraview_build_CMAKE_DESTINATION}
747 file(APPEND "${_paraview_build_properties_build_file}
748 "set_property(TARGET \
"${_paraview_build_TARGET}\"
750 INTERFACE_paraview_plugin_plugins_file \"${_paraview_build_xml_file}\")\n")
751 file(APPEND
"${_paraview_build_properties_install_file}"
752 "set_property(TARGET \"${_paraview_build_TARGET}\"
754 INTERFACE_paraview_plugin_plugins_file \"\${_vtk_module_import_prefix}/${_paraview_build_plugin_destination}/${_paraview_build_PLUGINS_FILE_NAME}\")
755 unset(_vtk_module_import_prefix)\n")
757 if (_paraview_build_INSTALL_HEADERS)
759 FILES
760 DESTINATION
"${_paraview_build_CMAKE_DESTINATION}"
761 RENAME
"${_paraview_build_properties_filename}"
762 COMPONENT
"${_paraview_build_TARGET_COMPONENT}")
770 ## Plugin configuration files
772 Applications will want to consume plugin targets by discovering their locations
773 at runtime. In
order to facilitate
this, ParaView supports loading a `conf`
774 file which contains the locations of plugin targets
' XML files. The plugins
775 specified in that file is then
778 paraview_plugin_write_conf(
780 PLUGINS_TARGETS <target>...
781 BUILD_DESTINATION <destination>
783 [INSTALL_DESTINATION <destination>]
784 [COMPONENT <component>])
787 * `NAME`: (Required) The base name of the configuration file.
788 * `PLUGINS_TARGETS`: (Required) The list of plugin targets to add to the
790 * `BUILD_DESTINATION`: (Required) Where to place the configuration file in
792 * `INSTALL_DESTINATION`: Where to install the configuration file in the
793 install tree. If not provided, the configuration file will not be
795 * `COMPONENT`: (Defaults to `runtime`) The component to use when installing
796 the configuration file.
798 function (paraview_plugin_write_conf)
799 cmake_parse_arguments(_paraview_plugin_conf
801 "NAME;BUILD_DESTINATION;INSTALL_DESTINATION;COMPONENT"
805 if (_paraview_plugin_conf_UNPARSED_ARGUMENTS)
807 "Unparsed arguments for paraview_plugin_write_conf: "
808 "${_paraview_plugin_conf_UNPARSED_ARGUMENTS}")
811 if (NOT _paraview_plugin_conf_NAME)
813 "The `NAME` must not be empty.")
816 if (NOT DEFINED _paraview_plugin_conf_BUILD_DESTINATION)
818 "The `BUILD_DESTINATION` argument is required.")
821 if (NOT DEFINED _paraview_plugin_conf_PLUGINS_TARGETS)
823 "The `PLUGINS_TARGETS` argument is required.")
826 if (NOT DEFINED _paraview_plugin_conf_COMPONENT)
827 set(_paraview_plugin_conf_COMPONENT "runtime")
830 set(_paraview_plugin_conf_file_name
831 "${_paraview_plugin_conf_NAME}.conf")
832 set(_paraview_plugin_conf_build_file
833 "${CMAKE_BINARY_DIR}/${_paraview_plugin_conf_BUILD_DESTINATION}/${_paraview_plugin_conf_file_name}")
834 set(_paraview_plugin_conf_install_file
835 "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_paraview_plugin_conf_file_name}.install")
836 set(_paraview_plugin_conf_build_contents)
837 set(_paraview_plugin_conf_install_contents)
838 foreach (_paraview_plugin_conf_target IN LISTS _paraview_plugin_conf_PLUGINS_TARGETS)
839 get_property(_paraview_plugin_conf_plugins_target_is_imported
840 TARGET "${_paraview_plugin_conf_target}"
842 if (_paraview_plugin_conf_plugins_target_is_imported)
843 get_property(_paraview_plugin_conf_plugins_target_xml_build
844 TARGET "${_paraview_plugin_conf_target}"
845 PROPERTY "INTERFACE_paraview_plugin_plugins_file")
846 set(_paraview_plugin_conf_plugins_target_xml_install
847 "${_paraview_plugin_conf_plugins_target_xml_build}")
849 file(RELATIVE_PATH _paraview_plugin_conf_rel_path
850 "/prefix/${CMAKE_INSTALL_PREFIX}"
851 "/prefix/${_paraview_plugin_conf_plugins_target_xml_install}")
852 # If the external plugins XML file is under our installation destination,
853 # use a relative path to it, otherwise keep the absolute path.
854 if (NOT _paraview_plugin_conf_rel_path MATCHES "^\.\./")
855 file(RELATIVE_PATH _paraview_plugin_conf_plugins_target_xml_install
856 "/prefix/${CMAKE_INSTALL_PREFIX}/${_paraview_plugin_conf_INSTALL_DESTINATION}"
857 "/prefix/${_paraview_plugin_conf_plugins_target_xml_install}")
860 get_property(_paraview_plugin_conf_plugins_target_is_alias
861 TARGET "${_paraview_plugin_conf_target}"
862 PROPERTY ALIASED_TARGET
864 if (_paraview_plugin_conf_plugins_target_is_alias)
865 get_property(_paraview_plugin_conf_target
866 TARGET "${_paraview_plugin_conf_target}"
867 PROPERTY ALIASED_TARGET)
869 get_property(_paraview_plugin_conf_plugins_target_xml_build
870 TARGET "${_paraview_plugin_conf_target}"
871 PROPERTY "INTERFACE_paraview_plugin_plugins_file")
872 get_property(_paraview_plugin_conf_plugins_target_xml_install
873 TARGET "${_paraview_plugin_conf_target}"
874 PROPERTY "INTERFACE_paraview_plugin_plugins_file_install")
876 if (_paraview_plugin_conf_plugins_target_xml_install)
877 # Compute the relative path within the install tree.
878 file(RELATIVE_PATH _paraview_plugin_conf_plugins_target_xml_install
879 "/prefix/${_paraview_plugin_conf_INSTALL_DESTINATION}"
880 "/prefix/${_paraview_plugin_conf_plugins_target_xml_install}")
884 # TODO: Write out in JSON instead.
885 if (_paraview_plugin_conf_plugins_target_xml_build)
886 string(APPEND _paraview_plugin_conf_build_contents
887 "${_paraview_plugin_conf_plugins_target_xml_build}\n")
889 if (_paraview_plugin_conf_plugins_target_xml_install)
890 string(APPEND _paraview_plugin_conf_install_contents
891 "${_paraview_plugin_conf_plugins_target_xml_install}\n")
896 OUTPUT "${_paraview_plugin_conf_build_file}"
897 CONTENT "${_paraview_plugin_conf_build_contents}")
899 if (_paraview_plugin_conf_INSTALL_DESTINATION)
901 OUTPUT "${_paraview_plugin_conf_install_file}"
902 CONTENT "${_paraview_plugin_conf_install_contents}")
904 FILES "${_paraview_plugin_conf_install_file}"
905 DESTINATION "${_paraview_plugin_conf_INSTALL_DESTINATION}"
906 RENAME "${_paraview_plugin_conf_file_name}"
907 COMPONENT "${_paraview_plugin_conf_COMPONENT}")
911 set(_paraview_plugin_source_dir "${CMAKE_CURRENT_LIST_DIR}")
919 paraview_add_plugin(<name>
920 [REQUIRED_ON_SERVER] [REQUIRED_ON_CLIENT]
923 [MODULE_FILES <vtk.module>...]
924 [MODULE_ARGS <arg>...]
925 [MODULES <module>...]
926 [SOURCES <source>...]
927 [SERVER_MANAGER_XML <xml>...]
928 [MODULE_INSTALL_EXPORT <export>]
930 [UI_INTERFACES <interface>...]
931 [UI_RESOURCES <resource>...]
934 [PYTHON_MODULES <module>...]
936 [INITIALIZERS <initializerFunction>...]
938 [EXTRA_INCLUDES <file>...]
940 [REQUIRED_PLUGINS <plugin>...]
943 [XML_DOCUMENTATION <ON|OFF>]
944 [DOCUMENTATION_DIR <directory>]
945 [DOCUMENTATION_ADD_PATTERNS <pattern>...]
946 [DOCUMENTATION_TOC <string>]
947 [DOCUMENTATION_DEPENDENCIES <target>...]
949 [FORCE_STATIC <ON|OFF>])
951 [TRANSLATIONS_DIRECTORY <directory>]
952 [TRANSLATIONS_TARGET <target>]
955 * `REQUIRED_ON_SERVER`: The plugin is required to be loaded on the server for
956 proper functionality.
957 * `REQUIRED_ON_CLIENT`: The plugin is required to be loaded on the client for
958 proper functionality.
959 * `VERSION`: (Required) The version number of the plugin.
960 * `MODULE_FILES`: Paths to `vtk.module` files describing modules to include
962 * `MODULE_ARGS`: Arguments to pass to `vtk_module_build` for included modules.
963 * `MODULES`: Modules to include in the plugin. These modules will be wrapped
964 using client server and have their server manager XML files processed.
965 * `SOURCES`: Source files for the plugin.
966 * `SERVER_MANAGER_XML`: Server manager XML files for the plugin.
967 * `UI_INTERFACES`: Interfaces to initialize, in the given order. See the
968 plugin interfaces section for more details.
969 * `MODULE_INSTALL_EXPORT`: (Defaults to `<name>`) If provided, any modules
970 will be added to the given export set.
971 * `UI_RESOURCES`: Qt resource files to include with the plugin.
972 * `UI_FILES`: Qt `.ui` files to include with the plugin.
973 * `PYTHON_MODULES`: Python modules to embed into the plugin.
974 * `INITIALIZERS`: An ordered list of free functions (declared in `EXTRA_INCLUDES`
975 if needed) to be invoked when the plugin is loaded. Each function must be
976 callable with no arguments.
977 * `EXTRA_INCLUDES`: Headers needed by the generated plugin code (such as `INITIALIZERS`).
978 Filename paths passed without quotes will be double-quoted (e.g., \verbatim`#include "foo.h"`\endverbatim),
979 while paths that start with angle- or double-quotes will not be.
980 * `REQUIRED_PLUGINS`: Plugins which must be loaded for this plugin to
981 function. These plugins do not need to be available at build time and are
982 therefore their existence is not checked here.
983 * `EULA`: A file with content to display as an end-user license agreement
984 before the plugin is initialized at runtime.
985 * `XML_DOCUMENTATION`: (Defaults to `ON`) If set, documentation will be
986 generated for the associated XML files.
987 * `DOCUMENTATION_DIR`: If specified, `*.html`, `*.css`, `*.png`, `*.js`, and `*.jpg`
988 files in this directory will be copied and made available to the
990 * `DOCUMENTATION_ADD_PATTERNS`: If specified, adds patterns for the documentation files
991 within `DOCUMENTATION_DIR` other than the default ones (see `DOCUMENTATION_DIR` help)
992 * `DOCUMENTATION_TOC`: If specified, use this string for describing the table of
993 content for the documentation.
994 * `DOCUMENTATION_DEPENDENCIES`: Targets that are needed to be built before
995 building the documentation.
996 * `EXPORT`: (Deprecated) Use `paraview_plugin_build(INSTALL_EXPORT)` instead.
997 * `FORCE_STATIC`: (Defaults to `OFF`) If set, the plugin will be built
998 statically so that it can be embedded into an application.
999 * `TRANSLATIONS_DIRECTORY`: (Defaults to `${CMAKE_CURRENT_BINARY_DIR}/Translations`)
1000 The path of the directory where translation source files are stored.
1001 * `TRANSLATION_TARGET` : The name of the target on which to add the ts file as
1004 function (paraview_add_plugin name)
1005 if (NOT name STREQUAL _paraview_build_plugin)
1007 "The ${_paraview_build_plugin}'s CMakeLists.txt may not add the ${
name}
1011 cmake_parse_arguments(_paraview_add_plugin
1012 "REQUIRED_ON_SERVER;REQUIRED_ON_CLIENT
1013 "VERSION;EULA;
EXPORT;MODULE_INSTALL_EXPORT;XML_DOCUMENTATION;DOCUMENTATION_DIR;FORCE_STATIC;DOCUMENTATION_TOC;TRANSLATIONS_DIRECTORY;TRANSLATIONS_TARGET
1014 "REQUIRED_PLUGINS;SERVER_MANAGER_XML;SOURCES;MODULES;UI_INTERFACES;UI_RESOURCES;UI_FILES;PYTHON_MODULES;MODULE_FILES;MODULE_ARGS;DOCUMENTATION_ADD_PATTERNS;DOCUMENTATION_DEPENDENCIES;INITIALIZERS;EXTRA_INCLUDES
1017 if (_paraview_add_plugin_UNPARSED_ARGUMENTS)
1020 "${_paraview_add_plugin_UNPARSED_ARGUMENTS}
1023 if (NOT DEFINED _paraview_add_plugin_VERSION)
1025 "The `VERSION` argument is required.
1028 if (NOT DEFINED _paraview_add_plugin_XML_DOCUMENTATION)
1029 set(_paraview_add_plugin_XML_DOCUMENTATION ON)
1031 if (DEFINED _paraview_add_plugin_DOCUMENTATION_DIR AND
1032 NOT _paraview_add_plugin_XML_DOCUMENTATION)
1034 "Specifying `DOCUMENTATION_DIR` and turning off `XML_DOCUMENTATION`
1037 if (_paraview_build_DISABLE_XML_DOCUMENTATION)
1038 set(_paraview_add_plugin_XML_DOCUMENTATION OFF)
1041 if (NOT DEFINED _paraview_add_plugin_FORCE_STATIC)
1042 set(_paraview_add_plugin_FORCE_STATIC OFF)
1045 if (DEFINED _paraview_add_plugin_EXPORT)
1051 if (_paraview_add_plugin_MODULE_ARGS)
1052 if (NOT _paraview_add_plugin_MODULE_FILES OR
1053 NOT _paraview_add_plugin_MODULES)
1055 "The `MODULE_ARGS` argument requires `MODULE_FILES` and `MODULES` to be provided.
1059 if (_paraview_add_plugin_UI_INTERFACES OR _paraview_add_plugin_UI_FILES OR _paraview_add_plugin_UI_RESOURCES)
1060 if (NOT PARAVIEW_USE_QT)
1061 message(FATAL_ERROR "UI_INTERFACES, UI_FILES and UI_RESOURCES require ParaView to be built with Qt
enabled.
1065 if (DEFINED _paraview_build_INSTALL_EXPORT AND
1066 NOT DEFINED _paraview_add_plugin_MODULE_INSTALL_EXPORT)
1067 set(_paraview_add_plugin_MODULE_INSTALL_EXPORT
1071 if (_paraview_add_plugin_MODULE_FILES)
1072 if (NOT _paraview_add_plugin_MODULES)
1074 "The `MODULE_FILES` argument requires `MODULES` to be provided.
1077 if (_paraview_build_ADD_INSTALL_RPATHS)
1079 list(INSERT CMAKE_INSTALL_RPATH 0
1082 list(INSERT CMAKE_INSTALL_RPATH 0
1087 set(_paraview_add_plugin_module_install_export_args)
1088 if (DEFINED _paraview_add_plugin_MODULE_INSTALL_EXPORT)
1089 list(APPEND _paraview_add_plugin_module_install_export_args
1090 INSTALL_EXPORT "${_paraview_add_plugin_MODULE_INSTALL_EXPORT}
1091 if (DEFINED _paraview_build_TARGET)
1092 set_property(GLOBAL APPEND
1094 "paraview_plugin_${_paraview_build_TARGET}_required_exports
" "${_paraview_add_plugin_MODULE_INSTALL_EXPORT}
1099 MODULE_FILES ${_paraview_add_plugin_MODULE_FILES}
1100 REQUEST_MODULES ${_paraview_add_plugin_MODULES}
1101 PROVIDES_MODULES plugin_modules
1102 REQUIRES_MODULES required_modules
1103 HIDE_MODULES_FROM_CACHE ON)
1105 if (required_modules)
1106 foreach (required_module IN LISTS required_modules)
1107 if (NOT TARGET "${required_module}
1109 "Failed to find the required module ${required_module}.
1115 set(_paraview_plugin_subdir "${_paraview_build_RUNTIME_DESTINATION}
1117 set(_paraview_plugin_subdir "${_paraview_build_LIBRARY_DESTINATION}
1119 if (NOT _paraview_build_LIBRARY_SUBDIRECTORY STREQUAL "")
1120 string(APPEND _paraview_plugin_subdir "/${_paraview_build_LIBRARY_SUBDIRECTORY}
1122 string(APPEND _paraview_plugin_subdir "/${_paraview_build_plugin}
1123 set(_paraview_plugin_CMAKE_RUNTIME_OUTPUT_DIRECTORY "${CMAKE_RUNTIME_OUTPUT_DIRECTORY}
1124 set(_paraview_plugin_CMAKE_LIBRARY_OUTPUT_DIRECTORY "${CMAKE_LIBRARY_OUTPUT_DIRECTORY}
1125 set(_paraview_plugin_CMAKE_ARCHIVE_OUTPUT_DIRECTORY "${CMAKE_ARCHIVE_OUTPUT_DIRECTORY}
1126 set(_paraview_plugin_CMAKE_INSTALL_NAME_DIR "${CMAKE_INSTALL_NAME_DIR}
1127 set(CMAKE_RUNTIME_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${_paraview_plugin_subdir}
1128 set(CMAKE_LIBRARY_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${_paraview_plugin_subdir}
1129 set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY "${CMAKE_BINARY_DIR}/${_paraview_plugin_subdir}
1130 set(CMAKE_INSTALL_NAME_DIR "@loader_path
1133 MODULES ${plugin_modules}
1134 PACKAGE "${_paraview_build_plugin}
1135 ${_paraview_add_plugin_module_install_export_args}
1136 INSTALL_HEADERS "${_paraview_build_INSTALL_HEADERS}
1137 TARGETS_COMPONENT "${_paraview_build_PLUGINS_COMPONENT}
1138 HEADERS_DESTINATION "${_paraview_build_HEADERS_DESTINATION}/${_paraview_build_target_safe}
1139 ARCHIVE_DESTINATION "${_paraview_plugin_subdir}
1140 LIBRARY_DESTINATION "${_paraview_plugin_subdir}
1141 RUNTIME_DESTINATION "${_paraview_plugin_subdir}
1142 CMAKE_DESTINATION "${_paraview_build_CMAKE_DESTINATION}
1143 ${_paraview_add_plugin_MODULE_ARGS}
1144 GENERATE_SPDX "${_paraview_build_GENERATE_SPDX}
1145 SPDX_DOCUMENT_NAMESPACE "${_paraview_build_SPDX_DOCUMENT_NAMESPACE}
1146 SPDX_DOWNLOAD_LOCATION "${_paraview_build_SPDX_DOWNLOAD_LOCATION}
1148 set_property(GLOBAL APPEND
1150 "paraview_plugin_${_paraview_add_plugin_MODULE_INSTALL_EXPORT}_modules
" "${plugin_modules}
1152 set(CMAKE_RUNTIME_OUTPUT_DIRECTORY "${_paraview_plugin_CMAKE_RUNTIME_OUTPUT_DIRECTORY}
1153 set(CMAKE_LIBRARY_OUTPUT_DIRECTORY "${_paraview_plugin_CMAKE_LIBRARY_OUTPUT_DIRECTORY}
1154 set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY "${_paraview_plugin_CMAKE_ARCHIVE_OUTPUT_DIRECTORY}
1155 set(CMAKE_INSTALL_NAME_DIR "${_paraview_plugin_CMAKE_INSTALL_NAME_DIR}
1156 unset(_paraview_plugin_CMAKE_RUNTIME_OUTPUT_DIRECTORY)
1157 unset(_paraview_plugin_CMAKE_LIBRARY_OUTPUT_DIRECTORY)
1158 unset(_paraview_plugin_CMAKE_ARCHIVE_OUTPUT_DIRECTORY)
1159 unset(_paraview_plugin_CMAKE_INSTALL_NAME_DIR)
1162 # TODO: resource initialization for static builds
1164 if (_paraview_add_plugin_REQUIRED_ON_SERVER)
1165 set(_paraview_add_plugin_required_on_server "true")
1167 set(_paraview_add_plugin_required_on_server "false")
1170 if (_paraview_add_plugin_REQUIRED_ON_CLIENT)
1171 set(_paraview_add_plugin_required_on_client "true")
1173 set(_paraview_add_plugin_required_on_client "false")
1176 set(_paraview_add_plugin_export_args)
1177 set(_paraview_add_plugin_install_export_args)
1178 if (DEFINED _paraview_build_INSTALL_EXPORT)
1179 list(APPEND _paraview_add_plugin_export_args
1180 EXPORT "${_paraview_build_INSTALL_EXPORT}
1181 list(APPEND _paraview_add_plugin_install_export_args
1182 INSTALL_EXPORT "${_paraview_build_INSTALL_EXPORT}
1185 set(_paraview_add_plugin_includes)
1186 set(_paraview_add_plugin_required_libraries)
1188 if (_paraview_add_plugin_EXTRA_INCLUDES)
1189 foreach (_include IN LISTS _paraview_add_plugin_EXTRA_INCLUDES)
1190 if ((${_include} MATCHES "^\
".*\"$") OR (${_include} MATCHES
1191 string(APPEND _paraview_add_plugin_includes "
#include ${_include}\n")
1193 string(APPEND _paraview_add_plugin_includes
"#include \"${_include}\"\n")
1198 set(_paraview_add_plugin_module_xmls)
1199 set(_paraview_add_plugin_with_xml 0)
1200 if (_paraview_add_plugin_MODULES)
1201 set(_paraview_add_plugin_with_xml 1)
1203 list(APPEND _paraview_add_plugin_required_libraries
1204 ${_paraview_add_plugin_MODULES})
1207 MODULES ${_paraview_add_plugin_MODULES}
1208 TARGET
"${_paraview_build_plugin}_client_server"
1209 ${_paraview_add_plugin_install_export_args})
1211 if (NOT DEFINED _paraview_add_plugin_TRANSLATIONS_DIRECTORY)
1212 set(_paraview_add_plugin_TRANSLATIONS_DIRECTORY
1213 "${CMAKE_CURRENT_BINARY_DIR}/Translations")
1215 set(_paraview_add_plugin_translation_args)
1216 if (_paraview_add_plugin_TRANSLATIONS_DIRECTORY AND _paraview_add_plugin_TRANSLATIONS_TARGET)
1217 list(APPEND _paraview_add_plugin_translation_args
1218 TRANSLATIONS_DIRECTORY "${_paraview_add_plugin_TRANSLATIONS_DIRECTORY}
1219 list(APPEND _paraview_add_plugin_translation_args
1220 TRANSLATIONS_TARGET "${_paraview_add_plugin_TRANSLATIONS_TARGET}
1223 paraview_server_manager_process(
1224 MODULES ${_paraview_add_plugin_MODULES}
1225 TARGET "${_paraview_build_plugin}_server_manager_modules
1226 ${_paraview_add_plugin_install_export_args}
1227 XML_FILES _paraview_add_plugin_module_xmls
1228 ${_paraview_add_plugin_translation_args})
1230 list(APPEND _paraview_add_plugin_required_libraries
1231 "${_paraview_build_plugin}_client_server
1232 "${_paraview_build_plugin}_server_manager_modules
1235 set(_paraview_add_plugin_binary_resources "")
1236 set(_paraview_add_plugin_binary_headers)
1237 if (_paraview_add_plugin_SERVER_MANAGER_XML)
1238 set(_paraview_add_plugin_with_xml 1)
1240 set(_paraview_add_plugin_xmls)
1241 foreach (_paraview_add_plugin_xml IN LISTS _paraview_add_plugin_SERVER_MANAGER_XML)
1242 if (NOT IS_ABSOLUTE "${_paraview_add_plugin_xml}
1243 set(_paraview_add_plugin_xml "${CMAKE_CURRENT_SOURCE_DIR}/${_paraview_add_plugin_xml}
1246 list(APPEND _paraview_add_plugin_xmls
1247 "${_paraview_add_plugin_xml}
1250 paraview_server_manager_process_files(
1251 TARGET "${_paraview_build_plugin}_server_manager
1252 ${_paraview_add_plugin_install_export_args}
1253 FILES ${_paraview_add_plugin_xmls})
1254 list(APPEND _paraview_add_plugin_required_libraries
1255 "${_paraview_build_plugin}_server_manager
1258 if ((_paraview_add_plugin_module_xmls OR _paraview_add_plugin_xmls) AND
1259 PARAVIEW_USE_QT AND _paraview_add_plugin_XML_DOCUMENTATION)
1261 if (PARAVIEW_QT_MAJOR_VERSION VERSION_GREATER "5
1262 # see https://gitlab.kitware.com/paraview/paraview/-/issues/19742
1263 if (NOT DEFINED ENV{CI})
1264 message(AUTHOR_WARNING "Building the plugin
documentation with Qt6 is not supported
1268 set(_paraview_build_plugin_docdir
1269 "${CMAKE_CURRENT_BINARY_DIR}/paraview_help
1271 paraview_client_documentation(
1272 TARGET "${_paraview_build_plugin}_doc
1273 OUTPUT_DIR "${_paraview_build_plugin_docdir}
1274 XMLS ${_paraview_add_plugin_module_xmls}
1275 ${_paraview_add_plugin_xmls})
1277 set(_paraview_build_plugin_doc_source_args)
1278 if (DEFINED _paraview_add_plugin_DOCUMENTATION_DIR)
1279 list(APPEND _paraview_build_plugin_doc_source_args
1280 SOURCE_DIR "${_paraview_add_plugin_DOCUMENTATION_DIR}
1283 paraview_client_generate_help(
1284 NAME "${_paraview_build_plugin}
1285 OUTPUT_PATH _paraview_build_plugin_qch_path
1286 OUTPUT_DIR "${_paraview_build_plugin_docdir}
1287 TARGET "${_paraview_build_plugin}_qch
1288 ${_paraview_build_plugin_doc_source_args}
1289 TABLE_OF_CONTENTS "${_paraview_add_plugin_DOCUMENTATION_TOC}
1290 DEPENDS "${_paraview_build_plugin}_doc
1291 "${_paraview_add_plugin_DOCUMENTATION_DEPENDENCIES}
1292 PATTERNS "*.html
" "*.css
" "*.js
1293 ${_paraview_add_plugin_DOCUMENTATION_ADD_PATTERNS})
1295 list(APPEND _paraview_add_plugin_extra_include_dirs
1296 "${CMAKE_CURRENT_BINARY_DIR}
1297 set(_paraview_add_plugin_qch_output
1298 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_build_plugin}_qch.h
1299 list(APPEND _paraview_add_plugin_binary_headers
1300 "${_paraview_add_plugin_qch_output}
1302 OUTPUT "${_paraview_add_plugin_qch_output}
1303 COMMAND ${CMAKE_CROSSCOMPILING_EMULATOR}
1304 $<TARGET_FILE:ParaView::ProcessXML>
1306 "${_paraview_add_plugin_qch_output}
1310 "${_paraview_build_plugin_qch_path}
1311 DEPENDS "${_paraview_build_plugin_qch_path}
1312 "${_paraview_build_plugin}_qch
1313 "$<TARGET_FILE:ParaView::ProcessXML>
1314 COMMENT "Generating header
for ${_paraview_build_plugin}
documentation")
1315 set_property(SOURCE "${_paraview_add_plugin_qch_output}
1319 string(APPEND _paraview_add_plugin_includes
1320 "#include \
"${_paraview_build_plugin}_qch.h\"\n")
1321 string(APPEND _paraview_add_plugin_binary_resources
1323 const char *text = ${_paraview_build_plugin}_qch();
1324 resources.emplace_back(text);
1330 set(_paraview_add_plugin_eula_sources)
1331 if (_paraview_add_plugin_EULA)
1333 INPUT "${_paraview_add_plugin_EULA}
1334 NAME "${_paraview_build_plugin}_EULA
1335 HEADER_OUTPUT _paraview_add_plugin_eula_header
1336 SOURCE_OUTPUT _paraview_add_plugin_eula_source)
1337 list(APPEND _paraview_add_plugin_eula_sources
1338 "${_paraview_add_plugin_eula_header}
1339 "${_paraview_add_plugin_eula_source}
1342 set(_paraview_add_plugin_with_ui 0)
1343 set(_paraview_add_plugin_ui_sources)
1344 if (_paraview_add_plugin_UI_INTERFACES)
1345 set(_paraview_add_plugin_with_ui 1)
1346 set(CMAKE_AUTOMOC 1)
1347 set(_paraview_add_plugin_push_back_interfaces
1348 "#define PARAVIEW_ADD_INTERFACES(arg) \\\n
1349 set(_paraview_add_plugin_include_interfaces "")
1351 foreach (_paraview_add_plugin_ui_interface IN LISTS _paraview_add_plugin_UI_INTERFACES)
1352 string(APPEND _paraview_add_plugin_push_back_interfaces
1353 " (arg).push_back(
new ${_paraview_add_plugin_ui_interface}(
this)); \\\n
1354 string(APPEND _paraview_add_plugin_include_interfaces
1355 "#include \
"${_paraview_add_plugin_ui_interface}.h\"\n")
1357 list(APPEND _paraview_add_plugin_required_libraries
1358 ParaView::pqComponents)
1361 set(_paraview_add_plugin_with_initializers 0)
1362 if (_paraview_add_plugin_INITIALIZERS)
1363 set(_paraview_add_plugin_with_initializers 1)
1364 set(_paraview_add_plugin_invoke_initializers)
1366 foreach (_paraview_add_plugin_initializer IN LISTS _paraview_add_plugin_INITIALIZERS)
1367 string(APPEND _paraview_add_plugin_invoke_initializers
1368 " ${_paraview_add_plugin_initializer}();\n
1372 set(_paraview_add_plugin_with_resources 0)
1373 set(_paraview_add_plugin_resources_init)
1374 if (_paraview_add_plugin_UI_RESOURCES)
1375 set(_paraview_add_plugin_with_resources 1)
1376 set(CMAKE_AUTORCC 1)
1377 if (NOT BUILD_SHARED_LIBS OR _paraview_add_plugin_FORCE_STATIC)
1378 foreach (_paraview_add_plugin_ui_resource IN LISTS _paraview_add_plugin_UI_RESOURCES)
1379 get_filename_component(_paraview_add_plugin_ui_resource_base "${_paraview_add_plugin_ui_resource}
" NAME_WE)
1380 string(APPEND _paraview_add_plugin_resources_init
1381 " Q_INIT_RESOURCE(${_paraview_add_plugin_ui_resource_base});\n
1384 list(APPEND _paraview_add_plugin_ui_sources
1385 ${_paraview_add_plugin_UI_RESOURCES})
1388 set(_paraview_add_plugin_qt_extra_components)
1389 if (_paraview_add_plugin_UI_FILES)
1390 set(_paraview_add_plugin_with_ui 1)
1391 set(CMAKE_AUTOUIC 1)
1392 list(APPEND _paraview_add_plugin_qt_extra_components
1394 list(APPEND _paraview_add_plugin_required_libraries
1395 "Qt${PARAVIEW_QT_MAJOR_VERSION}::Widgets
1396 list(APPEND _paraview_add_plugin_ui_sources
1397 ${_paraview_add_plugin_UI_FILES})
1400 if (_paraview_add_plugin_with_ui OR _paraview_add_plugin_with_resources)
1401 include("${_ParaViewPlugin_cmake_dir}/paraview-find-package-helpers.cmake
" OPTIONAL)
1402 find_package("Qt${PARAVIEW_QT_MAJOR_VERSION}
" QUIET REQUIRED COMPONENTS Core ${_paraview_add_plugin_qt_extra_components})
1403 list(APPEND _paraview_add_plugin_required_libraries
1404 "Qt${PARAVIEW_QT_MAJOR_VERSION}::Core
1405 if (_paraview_add_plugin_with_ui)
1406 list(APPEND _paraview_add_plugin_required_libraries
1410 # CMake 3.13 started using Qt5's version variables to detect what version
1411 # of Qt's tools to run for automoc, autouic, and autorcc. However, they are
1412 # looked up using the target's directory scope, but these are here in a
1413 # local scope and unset when AutoGen gets around to asking about the
1414 # variables at generate time.
1416 # Fix for 3.13.0–3.13.3. Does not work if `paraview_add_plugin` is called
1417 # from another function.
1418 set("Qt${PARAVIEW_QT_MAJOR_VERSION}Core_VERSION_MAJOR
" "${Qt${PARAVIEW_QT_MAJOR_VERSION}Core_VERSION_MAJOR}
" PARENT_SCOPE)
1419 set("Qt${PARAVIEW_QT_MAJOR_VERSION}Core_VERSION_MINOR
" "${Qt${PARAVIEW_QT_MAJOR_VERSION}Core_VERSION_MINOR}
" PARENT_SCOPE)
1421 set_property(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}
1423 "Qt${PARAVIEW_QT_MAJOR_VERSION}Core_VERSION_MAJOR
1424 set_property(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}
1426 "Qt${PARAVIEW_QT_MAJOR_VERSION}Core_VERSION_MINOR
1429 set(_paraview_add_plugin_with_python 0)
1430 set(_paraview_add_plugin_python_sources)
1431 set(_paraview_add_plugin_python_includes)
1432 set(_paraview_add_plugin_python_modules)
1433 set(_paraview_add_plugin_python_module_sources)
1434 set(_paraview_add_plugin_python_package_flags)
1435 if (_paraview_add_plugin_PYTHON_MODULES)
1436 set(_paraview_add_plugin_with_python 1)
1437 foreach (_paraview_add_plugin_python_module IN LISTS _paraview_add_plugin_PYTHON_MODULES)
1438 set(_paraview_add_plugin_python_path
1439 "${CMAKE_CURRENT_SOURCE_DIR}/${_paraview_add_plugin_python_module}
1440 get_filename_component(_paraview_add_plugin_python_package "${_paraview_add_plugin_python_module}
" PATH)
1441 get_filename_component(_paraview_add_plugin_python_name "${_paraview_add_plugin_python_module}
" NAME_WE)
1442 if (_paraview_add_plugin_python_package)
1443 set(_paraview_add_plugin_python_full_name
1444 "${_paraview_add_plugin_python_package}.${_paraview_add_plugin_python_name}
1446 set(_paraview_add_plugin_python_full_name
1447 "${_paraview_add_plugin_python_name}
1449 string(REPLACE ".
" "_
" _paraview_add_plugin_python_module_mangled "${_paraview_add_plugin_python_full_name}
1450 set(_paraview_add_plugin_python_is_package 0)
1451 set(_paraview_add_plugin_python_import
1452 "${_paraview_add_plugin_python_full_name}
1453 if (_paraview_add_plugin_python_name STREQUAL "__init__
1454 set(_paraview_add_plugin_python_is_package 1)
1455 set(_paraview_add_plugin_python_import
1456 "${_paraview_add_plugin_python_package}
1458 set(_paraview_add_plugin_python_header_name
1459 "WrappedPython_${_paraview_build_plugin}_${_paraview_add_plugin_python_module_mangled}.h
1460 set(_paraview_add_plugin_python_header
1461 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_add_plugin_python_header_name}
1463 OUTPUT "${_paraview_add_plugin_python_header}
1464 COMMAND ${CMAKE_CROSSCOMPILING_EMULATOR}
1465 $<TARGET_FILE:ParaView::ProcessXML>
1466 "${_paraview_add_plugin_python_header}
1467 "module_${_paraview_add_plugin_python_module_mangled}_
1470 "${_paraview_add_plugin_python_path}
1471 DEPENDS "${_paraview_add_plugin_python_path}
1472 "$<TARGET_FILE:ParaView::ProcessXML>
1473 COMMENT "Convert Python module ${_paraview_add_plugin_python_module_name}
1475 list(APPEND _paraview_add_plugin_python_sources
1476 "${_paraview_add_plugin_python_header}
1477 string(APPEND _paraview_add_plugin_python_includes
1478 "#include \
"${_paraview_add_plugin_python_header_name}\"\n")
1479 string(APPEND _paraview_add_plugin_python_modules
1480 " \"${_paraview_add_plugin_python_import}\",\n")
1481 string(APPEND _paraview_add_plugin_python_module_sources
1482 " module_${_paraview_add_plugin_python_module_mangled}_${_paraview_add_plugin_python_name}_source(),\n")
1483 string(APPEND _paraview_add_plugin_python_package_flags
1484 " ${_paraview_add_plugin_python_is_package},\n")
1487 # Add terminators to the list.
1488 string(APPEND _paraview_add_plugin_python_modules
1490 string(APPEND _paraview_add_plugin_python_module_sources
1492 string(APPEND _paraview_add_plugin_python_package_flags
1496 set(_paraview_add_plugin_header
1497 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_build_plugin}Plugin.h
1498 set(_paraview_add_plugin_source
1499 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_build_plugin}Plugin.cxx
1501 get_property(_paraview_add_plugin_description GLOBAL
1502 PROPERTY "_paraview_plugin_${_paraview_build_plugin}_description
1504 set(_paraview_build_plugin_type MODULE)
1505 set(_paraview_add_plugin_built_shared 1)
1506 if (NOT BUILD_SHARED_LIBS OR _paraview_add_plugin_FORCE_STATIC)
1507 set(_paraview_build_plugin_type STATIC)
1508 set(_paraview_add_plugin_built_shared 0)
1512 "${_paraview_plugin_source_dir}/paraview_plugin.h.in
1513 "${_paraview_add_plugin_header}
1515 "${_paraview_plugin_source_dir}/paraview_plugin.cxx.in
1516 "${_paraview_add_plugin_source}
1519 # On Windows, we want `MODULE` libraries to go to the runtime directory,
1520 # but CMake always uses `CMAKE_LIBRARY_OUTPUT_DIRECTORY`.
1521 set(CMAKE_LIBRARY_OUTPUT_DIRECTORY "${CMAKE_RUNTIME_OUTPUT_DIRECTORY}
1523 if (NOT _paraview_build_LIBRARY_SUBDIRECTORY STREQUAL "")
1524 string(APPEND CMAKE_LIBRARY_OUTPUT_DIRECTORY "/${_paraview_build_LIBRARY_SUBDIRECTORY}
1526 string(APPEND CMAKE_LIBRARY_OUTPUT_DIRECTORY "/${_paraview_build_plugin}
1528 # Place static plugins in the same place they would be if they were shared.
1529 if (NOT _paraview_build_LIBRARY_SUBDIRECTORY STREQUAL "")
1530 string(APPEND CMAKE_ARCHIVE_OUTPUT_DIRECTORY "/${_paraview_build_LIBRARY_SUBDIRECTORY}
1532 string(APPEND CMAKE_ARCHIVE_OUTPUT_DIRECTORY "/${_paraview_build_plugin}
1534 add_library("${_paraview_build_plugin}
" "${_paraview_build_plugin_type}
1535 ${_paraview_add_plugin_header}
1536 ${_paraview_add_plugin_source}
1537 ${_paraview_add_plugin_eula_sources}
1538 ${_paraview_add_plugin_binary_headers}
1539 ${_paraview_add_plugin_ui_sources}
1540 ${_paraview_add_plugin_python_sources}
1541 ${_paraview_add_plugin_SOURCES})
1542 if (NOT BUILD_SHARED_LIBS OR _paraview_add_plugin_FORCE_STATIC)
1543 target_compile_definitions("${_paraview_build_plugin}
1547 target_link_libraries("${_paraview_build_plugin}
1549 ParaView::RemotingCore
1550 ${_paraview_add_plugin_required_libraries})
1551 target_include_directories("${_paraview_build_plugin}
1553 "${CMAKE_CURRENT_SOURCE_DIR}
1554 ${_paraview_add_plugin_extra_include_dirs})
1555 set_property(TARGET "${_paraview_build_plugin}
1559 set(_paraview_add_plugin_destination
1560 "${_paraview_build_plugin_destination}/${_paraview_build_plugin}
1562 TARGETS "${_paraview_build_plugin}
1563 ${_paraview_add_plugin_export_args}
1564 COMPONENT "${_paraview_build_PLUGINS_COMPONENT}
1565 ARCHIVE DESTINATION "${_paraview_add_plugin_destination}
1566 LIBRARY DESTINATION "${_paraview_add_plugin_destination}
1570 ## Plugin interfaces
1572 ParaView plugins may satisfy a number of interfaces. These functions all take a
1573 `INTERFACES` argument which takes the name of a variable to set with the name
1574 of the interface generated. This variable's should be passed to
1575 `paraview_add_plugin`'s `UI_INTERFACES` argument.
1581 TODO: What is a property widget?
1584 paraview_plugin_add_property_widget(
1585 KIND <WIDGET|GROUP_WIDGET|WIDGET_DECORATOR>
1588 INTERFACES <variable>
1592 * `KIND`: The kind of widget represented.
1593 * `TYPE`: The name of the property type.
1594 * `CLASS_NAME`: The name of the property widget class.
1595 * `INTERFACES`: The name of the generated interface.
1596 * `SOURCES`: The source files generated by the interface.
1598 function (paraview_plugin_add_property_widget)
1599 cmake_parse_arguments(_paraview_property_widget
1601 "KIND;
TYPE;CLASS_NAME;INTERFACES;SOURCES
1605 if (_paraview_property_widget_UNPARSED_ARGUMENTS)
1608 "${_paraview_property_widget_UNPARSED_ARGUMENTS}
1611 set(_paraview_property_widget_kind_widget 0)
1612 set(_paraview_property_widget_kind_group_widget 0)
1613 set(_paraview_property_widget_kind_widget_decorator 0)
1614 if (_paraview_property_widget_KIND STREQUAL "WIDGET")
1615 set(_paraview_property_widget_kind_widget 1)
1616 elseif (_paraview_property_widget_KIND STREQUAL "GROUP_WIDGET
1617 set(_paraview_property_widget_kind_group_widget 1)
1618 elseif (_paraview_property_widget_KIND STREQUAL "WIDGET_DECORATOR
1619 set(_paraview_property_widget_kind_widget_decorator 1)
1622 "The `KIND` argument must be one of `
WIDGET`, `GROUP_WIDGET`, or
1623 "`WIDGET_DECORATOR`.
1626 if (NOT DEFINED _paraview_property_widget_TYPE)
1628 "The `
TYPE` argument is required.
1631 if (NOT DEFINED _paraview_property_widget_CLASS_NAME)
1633 "The `CLASS_NAME` argument is required.
1636 if (NOT DEFINED _paraview_property_widget_INTERFACES)
1638 "The `INTERFACES` argument is required.
1641 if (NOT DEFINED _paraview_property_widget_SOURCES)
1643 "The `SOURCES` argument is required.
1648 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_property_widget_CLASS_NAME}PWIImplementation.h
1652 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_property_widget_CLASS_NAME}PWIImplementation.cxx
1655 set("${_paraview_property_widget_INTERFACES}
1656 "${_paraview_property_widget_CLASS_NAME}PWIImplementation
1659 set("${_paraview_property_widget_SOURCES}
1660 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_property_widget_CLASS_NAME}PWIImplementation.cxx
1661 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_property_widget_CLASS_NAME}PWIImplementation.h
1668 TODO: What is a dock window?
1671 paraview_plugin_add_dock_window(
1673 [DOCK_AREA <Right|Left|Top|Bottom>]
1674 INTERFACES <variable>
1678 * `CLASS_NAME`: The name of the dock window class.
1679 * `DOCK_AREA`: (Default `Left`) Where to dock the window within the
1681 * `INTERFACES`: The name of the generated interface.
1682 * `SOURCES`: The source files generated by the interface.
1684 function (paraview_plugin_add_dock_window)
1685 cmake_parse_arguments(_paraview_dock_window
1687 "DOCK_AREA;CLASS_NAME;INTERFACES;SOURCES
1691 if (_paraview_dock_window_UNPARSED_ARGUMENTS)
1694 "${_paraview_dock_window_UNPARSED_ARGUMENTS}
1697 if (NOT DEFINED _paraview_dock_window_CLASS_NAME)
1699 "The `CLASS_NAME` argument is required.
1702 if (NOT DEFINED _paraview_dock_window_INTERFACES)
1704 "The `INTERFACES` argument is required.
1707 if (NOT DEFINED _paraview_dock_window_SOURCES)
1709 "The `SOURCES` argument is required.
1712 if (NOT DEFINED _paraview_dock_window_DOCK_AREA)
1713 set(_paraview_dock_window_DOCK_AREA "Left
1716 if (NOT _paraview_dock_window_DOCK_AREA STREQUAL "Left
" AND
1717 NOT _paraview_dock_window_DOCK_AREA STREQUAL "Right
" AND
1718 NOT _paraview_dock_window_DOCK_AREA STREQUAL "Top
" AND
1719 NOT _paraview_dock_window_DOCK_AREA STREQUAL "Bottom
1721 "`DOCK_AREA` must be one of `Left`, `Right`, `Top`, or `Bottom`. Got
1722 "`${_paraview_dock_window_DOCK_AREA}`.
1726 "${_ParaViewPlugin_cmake_dir}/pqDockWindowImplementation.h.in
1727 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_dock_window_CLASS_NAME}Implementation.h
1730 "${_ParaViewPlugin_cmake_dir}/pqDockWindowImplementation.cxx.in
1731 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_dock_window_CLASS_NAME}Implementation.cxx
1734 set("${_paraview_dock_window_INTERFACES}
1735 "${_paraview_dock_window_CLASS_NAME}Implementation
1738 set("${_paraview_dock_window_SOURCES}
1739 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_dock_window_CLASS_NAME}Implementation.cxx
1740 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_dock_window_CLASS_NAME}Implementation.h
1747 TODO: What is an action group?
1750 paraview_plugin_add_action_group(
1753 INTERFACES <variable>
1757 * `CLASS_NAME`: The name of the action group class.
1758 * `GROUP_NAME`: The name of the action group.
1759 * `INTERFACES`: The name of the generated interface.
1760 * `SOURCES`: The source files generated by the interface.
1762 function (paraview_plugin_add_action_group)
1763 cmake_parse_arguments(_paraview_action_group
1765 "CLASS_NAME;GROUP_NAME;INTERFACES;SOURCES
1769 if (_paraview_action_group_UNPARSED_ARGUMENTS)
1772 "${_paraview_action_group_UNPARSED_ARGUMENTS}
1775 if (NOT DEFINED _paraview_action_group_CLASS_NAME)
1777 "The `CLASS_NAME` argument is required.
1780 if (NOT DEFINED _paraview_action_group_GROUP_NAME)
1782 "The `GROUP_NAME` argument is required.
1785 if (NOT DEFINED _paraview_action_group_INTERFACES)
1787 "The `INTERFACES` argument is required.
1790 if (NOT DEFINED _paraview_action_group_SOURCES)
1792 "The `SOURCES` argument is required.
1796 "${_ParaViewPlugin_cmake_dir}/pqActionGroupImplementation.h.in
1797 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_action_group_CLASS_NAME}Implementation.h
1800 "${_ParaViewPlugin_cmake_dir}/pqActionGroupImplementation.cxx.in
1801 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_action_group_CLASS_NAME}Implementation.cxx
1804 set("${_paraview_action_group_INTERFACES}
1805 "${_paraview_action_group_CLASS_NAME}Implementation
1808 set("${_paraview_action_group_SOURCES}
1809 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_action_group_CLASS_NAME}Implementation.cxx
1810 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_action_group_CLASS_NAME}Implementation.h
1817 TODO: What is a toolbar?
1820 paraview_plugin_add_toolbar(
1822 INTERFACES <variable>
1826 * `CLASS_NAME`: The name of the toolbar class.
1827 * `INTERFACES`: The name of the generated interface.
1828 * `SOURCES`: The source files generated by the interface.
1830 function (paraview_plugin_add_toolbar)
1831 cmake_parse_arguments(_paraview_toolbar
1833 "CLASS_NAME;INTERFACES;SOURCES
1837 if (_paraview_toolbar_UNPARSED_ARGUMENTS)
1840 "${_paraview_toolbar_UNPARSED_ARGUMENTS}
1843 if (NOT DEFINED _paraview_toolbar_CLASS_NAME)
1845 "The `CLASS_NAME` argument is required.
1848 if (NOT DEFINED _paraview_toolbar_INTERFACES)
1850 "The `INTERFACES` argument is required.
1853 if (NOT DEFINED _paraview_toolbar_SOURCES)
1855 "The `SOURCES` argument is required.
1859 "${_ParaViewPlugin_cmake_dir}/pqToolBarImplementation.h.in
1860 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_toolbar_CLASS_NAME}Implementation.h
1863 "${_ParaViewPlugin_cmake_dir}/pqToolBarImplementation.cxx.in
1864 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_toolbar_CLASS_NAME}Implementation.cxx
1867 set("${_paraview_toolbar_INTERFACES}
1868 "${_paraview_toolbar_CLASS_NAME}Implementation
1871 set("${_paraview_toolbar_SOURCES}
1872 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_toolbar_CLASS_NAME}Implementation.cxx
1873 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_toolbar_CLASS_NAME}Implementation.h
1880 TODO: What is an auto start?
1883 paraview_plugin_add_auto_start(
1885 [STARTUP <function>]
1886 [SHUTDOWN <function>]
1887 INTERFACES <variable>
1891 * `CLASS_NAME`: The name of the auto start class.
1892 * `STARTUP`: (Defaults to `startup`) The name of the method to call on
1894 * `SHUTDOWN`: (Defaults to `shutdown`) The name of the method to call on
1896 * `INTERFACES`: The name of the generated interface.
1897 * `SOURCES`: The source files generated by the interface.
1899 function (paraview_plugin_add_auto_start)
1900 cmake_parse_arguments(_paraview_auto_start
1902 "CLASS_NAME;INTERFACES;SOURCES;STARTUP;SHUTDOWN
1906 if (_paraview_auto_start_UNPARSED_ARGUMENTS)
1909 "${_paraview_auto_start_UNPARSED_ARGUMENTS}
1912 if (NOT DEFINED _paraview_auto_start_CLASS_NAME)
1914 "The `CLASS_NAME` argument is required.
1917 if (NOT DEFINED _paraview_auto_start_INTERFACES)
1919 "The `INTERFACES` argument is required.
1922 if (NOT DEFINED _paraview_auto_start_SOURCES)
1924 "The `SOURCES` argument is required.
1927 if (NOT DEFINED _paraview_auto_start_STARTUP)
1928 set(_paraview_auto_start_STARTUP "startup
1931 if (NOT DEFINED _paraview_auto_start_SHUTDOWN)
1932 set(_paraview_auto_start_SHUTDOWN "shutdown
1936 "${_ParaViewPlugin_cmake_dir}/pqAutoStartImplementation.h.in
1937 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_auto_start_CLASS_NAME}Implementation.h
1940 "${_ParaViewPlugin_cmake_dir}/pqAutoStartImplementation.cxx.in
1941 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_auto_start_CLASS_NAME}Implementation.cxx
1944 set("${_paraview_auto_start_INTERFACES}
1945 "${_paraview_auto_start_CLASS_NAME}Implementation
1948 set("${_paraview_auto_start_SOURCES}
1949 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_auto_start_CLASS_NAME}Implementation.cxx
1950 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_auto_start_CLASS_NAME}Implementation.h
1957 The filesystem location of dynamically-loaded plugin.
1960 paraview_plugin_add_location(
1963 INTERFACES <variable>
1967 * `CLASS_NAME`: The name of the location class.
1968 * `STORE`: (Defaults to `StoreLocation`) The name of the method to call on
1969 startup, passing in the plugin location (const char*).
1970 * `INTERFACES`: The name of the generated interface.
1971 * `SOURCES`: The source files generated by the interface.
1973 function (paraview_plugin_add_location)
1974 cmake_parse_arguments(_paraview_location
1976 "CLASS_NAME;INTERFACES;SOURCES;STORE
1980 if (_paraview_location_UNPARSED_ARGUMENTS)
1983 "${_paraview_location_UNPARSED_ARGUMENTS}
1986 if (NOT DEFINED _paraview_location_CLASS_NAME)
1988 "The `CLASS_NAME` argument is required.
1991 if (NOT DEFINED _paraview_location_INTERFACES)
1993 "The `INTERFACES` argument is required.
1996 if (NOT DEFINED _paraview_location_SOURCES)
1998 "The `SOURCES` argument is required.
2001 if (NOT DEFINED _paraview_location_STORE)
2002 set(_paraview_location_STORE "StoreLocation
2006 "${_ParaViewPlugin_cmake_dir}/pqPluginLocationImplementation.h.in
2007 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_location_CLASS_NAME}Implementation.h
2010 "${_ParaViewPlugin_cmake_dir}/pqPluginLocationImplementation.cxx.in
2011 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_location_CLASS_NAME}Implementation.cxx
2014 set("${_paraview_location_INTERFACES}
2015 "${_paraview_location_CLASS_NAME}Implementation
2018 set("${_paraview_location_SOURCES}
2019 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_location_CLASS_NAME}Implementation.cxx
2020 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_location_CLASS_NAME}Implementation.h
2025 ### Tree layout strategy
2027 TODO: What is a tree layout strategy?
2030 paraview_plugin_add_tree_layout_strategy(
2031 STRATEGY_TYPE <type>
2032 STRATEGY_LABEL <label>
2033 INTERFACES <variable>
2037 * `STRATEGY_TYPE`: The name of the tree layout strategy class.
2038 * `STRATEGY_LABEL`: The label to use for the strategy.
2039 * `INTERFACES`: The name of the generated interface.
2040 * `SOURCES`: The source files generated by the interface.
2042 function (paraview_plugin_add_tree_layout_strategy)
2043 cmake_parse_arguments(_paraview_tree_layout_strategy
2045 "INTERFACES;SOURCES;STRATEGY_TYPE;STRATEGY_LABEL
2049 if (_paraview_tree_layout_strategy_UNPARSED_ARGUMENTS)
2052 "${_paraview_tree_layout_strategy_UNPARSED_ARGUMENTS}
2055 if (NOT DEFINED _paraview_tree_layout_strategy_STRATEGY_TYPE)
2057 "The `STRATEGY_TYPE` argument is required.
2060 if (NOT DEFINED _paraview_tree_layout_strategy_STRATEGY_LABEL)
2062 "The `STRATEGY_LABEL` argument is required.
2065 if (NOT DEFINED _paraview_tree_layout_strategy_INTERFACES)
2067 "The `INTERFACES` argument is required.
2070 if (NOT DEFINED _paraview_tree_layout_strategy_SOURCES)
2072 "The `SOURCES` argument is required.
2076 "${_ParaViewPlugin_cmake_dir}/pqTreeLayoutStrategyImplementation.h.in
2077 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_tree_layout_strategy_STRATEGY_TYPE}Implementation.h
2080 "${_ParaViewPlugin_cmake_dir}/pqTreeLayoutStrategyImplementation.cxx.in
2081 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_tree_layout_strategy_STRATEGY_TYPE}Implementation.cxx
2084 set("${_paraview_tree_layout_strategy_INTERFACES}
2085 "${_paraview_tree_layout_strategy_STRATEGY_TYPE}Implementation
2088 set("${_paraview_tree_layout_strategy_SOURCES}
2089 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_tree_layout_strategy_STRATEGY_TYPE}Implementation.cxx
2090 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_tree_layout_strategy_STRATEGY_TYPE}Implementation.h
2097 TODO: What is a proxy?
2100 paraview_plugin_add_proxy(
2102 INTERFACES <variable>
2105 [CLASS_NAME <class>]
2107 <XML_NAME|XML_NAME_REGEX> <name>]...)
2110 * `NAME`: The name of the proxy.
2111 * `INTERFACES`: The name of the generated interface.
2112 * `SOURCES`: The source files generated by the interface.
2114 At least one `PROXY_TYPE` must be specified. Each proxy type must be given an
2115 `XML_GROUP` and either an `XML_NAME` or `XML_NAME_REGEX`. If `CLASS_NAME` is
2116 not given, the `PROXY_TYPE` name is used instead.
2118 function (paraview_plugin_add_proxy)
2119 cmake_parse_arguments(_paraview_proxy
2121 "INTERFACES;SOURCES;
NAME"
2125 if (NOT DEFINED _paraview_proxy_INTERFACES)
2127 "The `INTERFACES` argument is required.
2130 if (NOT DEFINED _paraview_proxy_SOURCES)
2132 "The `SOURCES` argument is required.
2135 if (NOT DEFINED _paraview_proxy_NAME)
2137 "The `
2140 set(_paraview_proxy_parse "")
2141 set(_paraview_proxy_type)
2142 set(_paraview_proxy_types)
2143 foreach (_paraview_proxy_arg IN LISTS _paraview_proxy_UNPARSED_ARGUMENTS)
2144 if (_paraview_proxy_parse STREQUAL "")
2145 set(_paraview_proxy_parse "${_paraview_proxy_arg}
2146 elseif (_paraview_proxy_parse STREQUAL "PROXY_TYPE
2147 set(_paraview_proxy_type "${_paraview_proxy_arg}
2148 list(APPEND _paraview_proxy_types "${_paraview_proxy_type}
2149 set(_paraview_proxy_parse "")
2150 elseif (_paraview_proxy_parse STREQUAL "CLASS_NAME
2151 if (NOT _paraview_proxy_type)
2153 "Missing `PROXY_TYPE`
for `CLASS_NAME`
2155 if (DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_class_name
2157 "Duplicate `CLASS_NAME`
for `${_paraview_proxy_type}`
2159 set("_paraview_proxy_type_${_paraview_proxy_type}_class_name
2160 "${_paraview_proxy_arg}
2161 set(_paraview_proxy_parse "")
2162 elseif (_paraview_proxy_parse STREQUAL "XML_GROUP
2163 if (NOT _paraview_proxy_type)
2165 "Missing `PROXY_TYPE`
for `XML_GROUP`
2167 if (DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_xml_group
2169 "Duplicate `XML_GROUP`
2171 set("_paraview_proxy_type_${_paraview_proxy_type}_xml_group
2172 "${_paraview_proxy_arg}
2173 set(_paraview_proxy_parse "")
2174 elseif (_paraview_proxy_parse STREQUAL "XML_NAME
2175 if (NOT _paraview_proxy_type)
2177 "Missing `PROXY_TYPE`
for `XML_NAME`
2179 if (DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_xml_name
" OR
2180 DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_xml_name_regex
2182 "Duplicate `XML_NAME` or `XML_NAME_REGEX`
2184 set("_paraview_proxy_type_${_paraview_proxy_type}_xml_name
2185 "${_paraview_proxy_arg}
2186 set(_paraview_proxy_parse "")
2187 elseif (_paraview_proxy_parse STREQUAL "XML_NAME_REGEX
2188 if (NOT _paraview_proxy_type)
2190 "Missing `PROXY_TYPE`
for `XML_NAME_REGEX`
2192 if (DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_xml_name
" OR
2193 DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_xml_name_regex
2195 "Duplicate `XML_NAME` or `XML_NAME_REGEX`
2197 set("_paraview_proxy_type_${_paraview_proxy_type}_xml_name_regex
2198 "${_paraview_proxy_arg}
2199 set(_paraview_proxy_parse "")
2202 "Unknown argument `${_paraview_proxy_parse}`
2206 if (_paraview_proxy_parse)
2208 "Missing argument
for `${_paraview_proxy_parse}`
2211 if (NOT _paraview_proxy_types)
2213 "No `PROXY_TYPE` arguments given
2216 set(_paraview_proxy_includes)
2217 set(_paraview_proxy_body)
2218 foreach (_paraview_proxy_type IN LISTS _paraview_proxy_types)
2219 if (NOT DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_xml_group
2221 "Missing `XML_GROUP`
2223 if (NOT DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_xml_name
" AND
2224 NOT DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_xml_name_regex
2226 "Missing `XML_NAME` or `XML_NAME_REGEX`
2228 if (DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_class_name
2229 set(_paraview_proxy_class
2230 "${_paraview_proxy_type_${_paraview_proxy_type}_class_name}
2232 set(_paraview_proxy_class
2233 "${_paraview_proxy_type}
2236 set(_paraview_proxy_group "${_paraview_proxy_type_${_paraview_proxy_type}_xml_group}
2237 if (DEFINED "_paraview_proxy_type_${_paraview_proxy_type}_xml_name
2238 set(_paraview_proxy_name "${_paraview_proxy_type_${_paraview_proxy_type}_xml_name}
2239 set(_paraview_proxy_name_type "QString
2240 set(_paraview_proxy_cmp "name == proxy->GetXMLName()
2242 set(_paraview_proxy_name "${_paraview_proxy_type_${_paraview_proxy_type}_xml_name_regex}
2243 set(_paraview_proxy_name_type "QRegularExpression
2244 set(_paraview_proxy_cmp "QString(proxy->GetXMLName()).contains(name)
2247 if (NOT DEFINED "_paraview_proxy_included_${_paraview_proxy_class}
2248 string(APPEND _paraview_proxy_includes
2249 "#include \
"${_paraview_proxy_class}.h\"\n")
2250 set(
"_paraview_proxy_included_${_paraview_proxy_class}" 1)
2252 string(APPEND _paraview_proxy_body
2254 static const QString group(\
"${_paraview_proxy_group}\");
2255 static const ${_paraview_proxy_name_type} name(\"${_paraview_proxy_name}\");
2256 if (group == proxy->GetXMLGroup() && ${_paraview_proxy_cmp})
2258 return new ${_paraview_proxy_class}(regGroup, regName, proxy, server, nullptr);
2264 "${_ParaViewPlugin_cmake_dir}/pqServerManagerModelImplementation.h.in
2265 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_proxy_NAME}ServerManagerModelImplementation.h
2268 "${_ParaViewPlugin_cmake_dir}/pqServerManagerModelImplementation.cxx.in
2269 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_proxy_NAME}ServerManagerModelImplementation.cxx
2272 set("${_paraview_proxy_INTERFACES}
2273 "${_paraview_proxy_NAME}ServerManagerModelImplementation
2276 set("${_paraview_proxy_SOURCES}
2277 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_proxy_NAME}ServerManagerModelImplementation.cxx
2278 "${CMAKE_CURRENT_BINARY_DIR}/${_paraview_proxy_NAME}ServerManagerModelImplementation.h
