vtkPVPluginLoader Class Reference
Used to load ParaView plugins. More...
#include <vtkPVPluginLoader.h>
Inheritance diagram for vtkPVPluginLoader:
Collaboration diagram for vtkPVPluginLoader:
bool LoadPluginByName (const char *name)
 Tries to the load the plugin by name using tracked plugins. More...
bool LoadPlugin (const char *filename)
 Tries to the load the plugin given the path to the plugin file. More...
bool LoadPluginSilently (const char *filename)
void LoadPluginConfigurationXMLFromString (const char *xmlcontents)
 Simply forwards the call to vtkPVPluginLoader::LoadPluginConfigurationXMLFromString to load configuration xml. More...
void LoadPluginsFromPluginSearchPath ()
 Loads all plugins under the directories mentioned in the SearchPaths. More...
void LoadPluginsFromPluginConfigFile ()
 Use PV_PLUGIN_CONFILE_FILE xml file to load specified plugins It can contain path to multiples xml pluginc config files sperated by env separator. More...
void LoadPluginsFromPath (const char *path)
 Loads all plugin libraries at a path. More...
virtual char * GetFileName ()
 Returns the full filename for the plugin attempted to load most recently using LoadPlugin(). More...
virtual char * GetPluginName ()
 Get the plugin name. More...
virtual char * GetPluginVersion ()
 Get the plugin version string. More...
virtual char * GetErrorString ()
 Get the error string if the plugin failed to load. More...
virtual char * GetSearchPaths ()
 Get a string of standard search paths (path1;path2;path3) search paths are based on PV_PLUGIN_PATH, plugin dir relative to executable. More...
virtual bool GetLoaded ()
 Returns the status of most recent LoadPlugin call. More...
static vtkPVPluginLoader * New ()
static vtkPVPluginLoader * SafeDownCast (vtkObject *o)
static void PluginLibraryUnloaded (const char *pluginname)
 Internal method used in pqParaViewPlugin.cxx.in to tell the vtkPVPluginLoader that a library was unloaded so it doesn't try to unload it again. More...
 vtkPVPluginLoader ()
 ~vtkPVPluginLoader () override
bool LoadPluginInternal (const char *filename, bool no_errors)
bool LoadPluginInternal (vtkPVPlugin *plugin)
 Called by LoadPluginInternal() to do the final steps in loading of a plugin. More...
virtual void SetErrorString (const char *)
virtual void SetPluginName (const char *)
virtual void SetPluginVersion (const char *)
virtual void SetSearchPaths (const char *)
char * ErrorString
char * PluginName
char * PluginVersion
char * FileName
char * SearchPaths
bool Loaded
using PluginLoaderCallback = std::function< bool(const char *)>
static int RegisterLoadPluginCallback (PluginLoaderCallback callback)
static void UnregisterLoadPluginCallback (int id)
vtkPVPluginLoader can be used to load plugins for ParaView. vtkPVPluginLoader loads the plugin on the local process.
vtkPVPluginLoader logs plugin related messages using at PARAVIEW_LOG_PLUGIN_VERBOSITY level. See vtkPVLogger::SetPluginVerbosity for information on using environment variables to override or elevate the verbosity level.
This class only needed when loading plugins from shared libraries dynamically. For statically importing plugins, one directly uses PV_PLUGIN_IMPORT() macro defined in vtkPVPlugin.h.
Definition at line 30 of file vtkPVPluginLoader.h.
Definition at line 34 of file vtkPVPluginLoader.h.
◆ PluginLoaderCallback
Definition at line 133 of file vtkPVPluginLoader.h.
◆ vtkPVPluginLoader()
vtkPVPluginLoader::vtkPVPluginLoader ( )
◆ ~vtkPVPluginLoader()
vtkPVPluginLoader::~vtkPVPluginLoader ( )
static vtkPVPluginLoader* vtkPVPluginLoader::New ( )
virtual const char* vtkPVPluginLoader::GetClassName ( )
static int vtkPVPluginLoader::IsTypeOf ( const char *  type)
virtual int vtkPVPluginLoader::IsA ( const char *  type)
static vtkPVPluginLoader* vtkPVPluginLoader::SafeDownCast ( vtkObject *  o)
void vtkPVPluginLoader::PrintSelf ( ostream &  os,
◆ LoadPluginByName()
bool vtkPVPluginLoader::LoadPluginByName ( const char *  name)
◆ LoadPlugin()
bool vtkPVPluginLoader::LoadPlugin ( const char *  filename)
inline
Definition at line 45 of file vtkPVPluginLoader.h.
◆ LoadPluginSilently()
bool vtkPVPluginLoader::LoadPluginSilently ( const char *  filename)
inline
Definition at line 46 of file vtkPVPluginLoader.h.
◆ LoadPluginConfigurationXMLFromString()
void vtkPVPluginLoader::LoadPluginConfigurationXMLFromString ( const char *  xmlcontents)
◆ LoadPluginsFromPluginSearchPath()
void vtkPVPluginLoader::LoadPluginsFromPluginSearchPath ( )
◆ LoadPluginsFromPluginConfigFile()
void vtkPVPluginLoader::LoadPluginsFromPluginConfigFile ( )
It allow user to fine pick which plugins to load, instead of using PV_PLUGIN_PATH the format a xml plugin file should be the following :
<?xml version="1.0"?>
<Plugins>
<Plugin name="MyPlugin" filename="absolute/path/to/libMyPlugin.so"/>
</Plugins>
◆ LoadPluginsFromPath()
void vtkPVPluginLoader::LoadPluginsFromPath ( const char *  path)
◆ GetFileName()
virtual char* vtkPVPluginLoader::GetFileName ( )
◆ GetPluginName()
virtual char* vtkPVPluginLoader::GetPluginName ( )
This returns a valid name only after the plugin has been loaded.
◆ GetPluginVersion()
virtual char* vtkPVPluginLoader::GetPluginVersion ( )
This returns a valid version string only after the plugin has been loaded.
◆ GetErrorString()
virtual char* vtkPVPluginLoader::GetErrorString ( )
Returns nullptr if the plugin was loaded successfully.
◆ GetSearchPaths()
virtual char* vtkPVPluginLoader::GetSearchPaths ( )
◆ GetLoaded()
virtual bool vtkPVPluginLoader::GetLoaded ( )
◆ RegisterLoadPluginCallback()
static int vtkPVPluginLoader::RegisterLoadPluginCallback ( PluginLoaderCallback  callback)
◆ UnregisterLoadPluginCallback()
static void vtkPVPluginLoader::UnregisterLoadPluginCallback ( int  id)
◆ PluginLibraryUnloaded()
static void vtkPVPluginLoader::PluginLibraryUnloaded ( const char *  pluginname)
◆ LoadPluginInternal() [1/2]
bool vtkPVPluginLoader::LoadPluginInternal ( const char *  filename,
bool  no_errors
◆ LoadPluginInternal() [2/2]
bool vtkPVPluginLoader::LoadPluginInternal ( vtkPVPlugin *  plugin)
◆ SetErrorString()
virtual void vtkPVPluginLoader::SetErrorString ( const char *  )
protectedvirtual
◆ SetPluginName()
virtual void vtkPVPluginLoader::SetPluginName ( const char *  )
protectedvirtual
◆ SetPluginVersion()
virtual void vtkPVPluginLoader::SetPluginVersion ( const char *  )
protectedvirtual
◆ SetFileName()
virtual void vtkPVPluginLoader::SetFileName ( const char *  )
protectedvirtual
◆ SetSearchPaths()
virtual void vtkPVPluginLoader::SetSearchPaths ( const char *  )
protectedvirtual
◆ ErrorString
char* vtkPVPluginLoader::ErrorString
Definition at line 161 of file vtkPVPluginLoader.h.
◆ PluginName
char* vtkPVPluginLoader::PluginName
Definition at line 164 of file vtkPVPluginLoader.h.
◆ PluginVersion
char* vtkPVPluginLoader::PluginVersion
Definition at line 165 of file vtkPVPluginLoader.h.
◆ FileName
char* vtkPVPluginLoader::FileName
Definition at line 166 of file vtkPVPluginLoader.h.
◆ SearchPaths
char* vtkPVPluginLoader::SearchPaths
Definition at line 167 of file vtkPVPluginLoader.h.
◆ Loaded
bool vtkPVPluginLoader::Loaded
Definition at line 168 of file vtkPVPluginLoader.h.
