vtkSMFieldDataDomain.h
45 #ifndef vtkSMFieldDataDomain_h
46 #define vtkSMFieldDataDomain_h
47
48 #include "vtkRemotingServerManagerModule.h" //needed for exports
49 #include "vtkSMEnumerationDomain.h"
50
52
54 {
55 public:
56  static vtkSMFieldDataDomain* New();
58  void PrintSelf(ostream& os, vtkIndent indent) override;
59
64  int SetDefaultValues(vtkSMProperty*, bool use_unchecked_values) override;
65
67
71  static std::string GetAttributeTypeAsString(vtkPVDataInformation* dataInfo, int attrType);
72  static const char* GetAttributeTypeAsString(int attrType);
74
76
80  static std::string GetElementTypeAsString(vtkPVDataInformation* dataInfo, int attrType);
81  static const char* GetElementTypeAsString(int attrType);
83
88  void Update(vtkSMProperty* property) override;
89
90 protected:
92  ~vtkSMFieldDataDomain() override;
93
98  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* elem) override;
99
100  // When true, "Field Data" option is added to the domain.
102
104
105 private:
107  void operator=(const vtkSMFieldDataDomain&) = delete;
108
115  int ComputeDefaultValue(int originalDefaultValue);
116 };
117
118 #endif
int SetDefaultValues(vtkSMProperty *, bool use_unchecked_values) override
Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value.
provides meta data about a vtkDataObject subclass.
list of integers with associated strings
enumeration domain to select array association or attribute type.
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
static vtkSMEnumerationDomain * New()
void Update(vtkSMProperty *property) override
Update self based on the "unchecked" values of all required properties.
