vtkSMEnumerationDomain.h
58 #ifndef vtkSMEnumerationDomain_h
59 #define vtkSMEnumerationDomain_h
60
61 #include "vtkRemotingServerManagerModule.h" //needed for exports
62 #include "vtkSMDomain.h"
63
64 #include <utility> // for std::pair
65 #include <vector> // for std::vector
66
68 {
69 public:
70  static vtkSMEnumerationDomain* New();
72  void PrintSelf(ostream& os, vtkIndent indent) override;
73
80  int IsInDomain(vtkSMProperty* property) override;
81
86  int IsInDomain(int val, unsigned int& idx);
87
91  unsigned int GetNumberOfEntries();
92
96  int GetEntryValue(unsigned int idx);
97
101  const char* GetEntryText(unsigned int idx);
102
106  const char* GetEntryTextForValue(int value);
107
111  int HasEntryText(const char* text);
112
117  int GetEntryValueForText(const char* text);
118
124  int GetEntryValue(const char* text, int& valid);
125
132  const char* GetInfoText(unsigned int idx);
133
137  void AddEntry(const char* text, int value, const char* info = nullptr);
138
142  void RemoveAllEntries();
143
148  void Update(vtkSMProperty* property) override;
149
151
155  int SetDefaultValues(vtkSMProperty*, bool use_unchecked_values) override;
156
157 protected:
159  ~vtkSMEnumerationDomain() override;
161
166  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
167
168  void ChildSaveState(vtkPVXMLElement* domainElement) override;
169
170 private:
172  void operator=(const vtkSMEnumerationDomain&) = delete;
173
174  struct vtkEDInternals;
175  vtkEDInternals* EInternals;
176 };
177
178 #endif
virtual void ChildSaveState(vtkPVXMLElement *domainElement)
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attribut...
virtual void Update(vtkSMProperty *requestingProperty)
Update self based on the "unchecked" values of all required properties.
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
Definition: vtkSMDomain.h:92
represents the possible values a property can have
Definition: vtkSMDomain.h:38
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
virtual int IsInDomain(vtkSMProperty *vtkNotUsed(property))
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes.
Definition: vtkSMDomain.h:65
list of integers with associated strings
static vtkSMDomain * New()
