10 #ifndef vtkSMCoreUtilities_h 11 #define vtkSMCoreUtilities_h 35 static const char* GetFileNameProperty(
vtkSMProxy*);
41 static std::vector<std::string> GetFileNameProperties(
vtkSMProxy* proxy);
46 static std::string SanitizeName(
const char*);
57 static bool AdjustRangeForLog(
double range[2]);
60 double range[2] = { rmin, rmax };
83 static bool AdjustRange(
double range[2]);
86 double range[2] = { rmin, rmax };
99 static bool AlmostEqual(
const double range[2],
int ulpsDiff);
102 double range[2] = { rmin, rmax };
111 static const char* GetInputPropertyName(
vtkSMProxy* proxy,
int port = 0);
120 static const char* GetStringForCellType(
int cellType);
133 vtkSMProxy* proxy,
const std::vector<std::string>& files,
const char* propName)
137 static void ReplaceReaderFileName(
vtkSMProxy* proxy,
138 const char* propName,
bool userModifiedName);
146 static std::string FindLargestPrefix(
const std::vector<std::string>& files);
152 static std::optional<std::string> RecoverRegistrationName(
vtkSMProxy* proxy);
159 static std::string GetFileNameFromFileNameList(
const std::vector<std::string>& fileNames);
static bool AdjustRange(double range[2])
Adjust the given range to make it suitable for use with color maps.
static bool AlmostEqual(const double range[2], int ulpsDiff)
Compares val1 and val2 and returns true is the two numbers are within ulpsDiff ULPs (units in last pl...
property representing a vector of strings
static bool AdjustRangeForLog(double range[2])
Given a range, converts it to be a valid range to switch to log space.
static std::string SanitizeName(const std::string &name)
static bool AdjustRangeForLog(double &rmin, double &rmax)
static void ReplaceReaderFileName(vtkSMProxy *proxy, const std::vector< std::string > &files, const char *propName)
Replaces input proxy, which should be a reader proxy, by a new proxy in the pipeline.
static bool AdjustRange(double &rmin, double &rmax)
CellTypeInDataSet cellType(vtkDataSet *input)
static std::string SanitizeName(const char *)
Sanitize a label/name to be remove spaces, delimiters etc.
static bool AlmostEqual(double rmin, double rmax, int ulpsDiff)
