vtkSMStringVectorProperty.h
17 #ifndef vtkSMStringVectorProperty_h
18 #define vtkSMStringVectorProperty_h
20 #include "vtkRemotingServerManagerModule.h" //needed for exports
21 #include "vtkSMVectorProperty.h"
22
23 #include <string> // needed for std::string
24 #include <vector> // needed for std::vector
25
26 class vtkStringList;
27 class vtkSMStateLocator;
28
30 {
31 public:
34  void PrintSelf(ostream& os, vtkIndent indent) override;
35
39  unsigned int GetNumberOfElements() override;
40
45  void SetNumberOfElements(unsigned int num) override;
46
52  int SetElement(unsigned int idx, const char* value);
53
57  int SetElements(const char* values[], unsigned int count);
58
60
63  int SetElements(vtkStringList* newvalue);
64  int SetElements(const std::vector<std::string>& newvalue);
66
68
71  int SetUncheckedElements(const char* values[], unsigned int count);
72  int SetUncheckedElements(const std::vector<std::string>& newvalue);
74
78  int AppendElements(const std::vector<std::string>& newvalue);
79
83  int AppendUncheckedElements(const std::vector<std::string>& newvalue);
84
88  void GetElements(vtkStringList* list);
89
91
94  const std::vector<std::string>& GetElements() const;
95  const std::vector<std::string>& GetUncheckedElements() const;
97
101  const char* GetElement(unsigned int idx);
102
107  unsigned int GetElementIndex(const char* value, int& exists);
108
110
118  void SetElementType(unsigned int idx, int type);
119  int GetElementType(unsigned int idx);
121
128  const char* GetUncheckedElement(unsigned int idx);
129
135  void SetUncheckedElement(unsigned int idx, const char* value);
136
138
141  void GetUncheckedElements(vtkStringList* list);
142  int SetUncheckedElements(vtkStringList* list);
144
150  unsigned int GetNumberOfUncheckedElements() override;
151
153  {
156  STRING
157  };
158
162  void Copy(vtkSMProperty* src) override;
163
167  const char* GetDefaultValue(int idx);
168
169  void ClearUncheckedElements() override;
170
171  bool IsValueDefault() override;
172
178  void ResetToXMLDefaults() override;
179
180 protected:
182  ~vtkSMStringVectorProperty() override;
183
189  void SetNumberOfUncheckedElements(unsigned int num) override;
190
199  int ReadXMLAttributes(vtkSMProxy* parent, vtkPVXMLElement* element) override;
200
204  void WriteTo(vtkSMMessage*) override;
205
209  void ReadFrom(const vtkSMMessage*, int msg_offset, vtkSMProxyLocator*) override;
210
214  int LoadState(vtkPVXMLElement* element, vtkSMProxyLocator* loader) override;
215
216  // Save concrete property values into the XML state property declaration
217  void SaveStateValues(vtkPVXMLElement* propElement) override;
218
219 private:
221  void operator=(const vtkSMStringVectorProperty&) = delete;
222
223  class vtkInternals;
224  vtkInternals* Internals;
225 };
226
227 #endif
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
This method must be overridden by concrete class in order to save the real property data...
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
virtual void SetNumberOfUncheckedElements(unsigned int num)=0
API for setting unchecked element values.
property representing a vector of strings
void Copy(vtkSMProperty *src) override
Copy all property values.
virtual void SetNumberOfElements(unsigned int num)=0
Sets the size of the vector.
abstract superclass for all vector properties
static vtkSMProperty * New()
virtual unsigned int GetNumberOfUncheckedElements()=0
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
Definition: vtkSMProxy.h:140
void ClearUncheckedElements() override=0
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
virtual int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader)
Updates state from an XML element.
int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element) override
virtual bool IsValueDefault()
Returns true if the property&#39;s value is different from the default value.
virtual unsigned int GetNumberOfElements()=0
Returns the size of the vector.
Manages allocation and freeing for a string list.
Definition: vtkStringList.h:20
Class used to retrieve a given message state based on its GlobalID.
