vtkChartRepresentation.h
16 #ifndef vtkChartRepresentation_h
17 #define vtkChartRepresentation_h
18
20 #include "vtkSmartPointer.h" // needed for vtkSmartPointer
21 #include "vtkWeakPointer.h" // needed for vtkWeakPointer
22
23 #include <map> // needed for std::map
24 #include <set> // needed for std::set
25 #include <vector> // needed for std::vector
26
29 class vtkCSVExporter;
30 class vtkDataObjectTree;
31 class vtkPVContextView;
33 class vtkTable;
36 {
37 public:
38  static vtkChartRepresentation* New();
40  void PrintSelf(ostream& os, vtkIndent indent) override;
41
46  void SetSelectionRepresentation(vtkChartSelectionRepresentation*);
47
51  void SetVisibility(bool visible) override;
52
59  void MarkModified() override;
60
61  // *************************************************************************
62
64
68  void SetFieldAssociation(int);
69  vtkGetMacro(FieldAssociation, int);
71
73
79  vtkSetStringMacro(ActiveAssembly);
80  vtkGetStringMacro(ActiveAssembly);
82
84
87  void AddBlockSelector(const char* selector);
88  void RemoveAllBlockSelectors();
90
95  unsigned int Initialize(unsigned int minIdAvailable, unsigned int maxIdAvailable) override;
96
105  vtkInformation* outInfo) override;
106
114  virtual std::string GetDefaultSeriesLabel(
115  const std::string& tableName, const std::string& columnName);
116
118
122  vtkSetMacro(FlattenTable, int);
123  vtkGetMacro(FlattenTable, int);
125
139  virtual bool MapSelectionToInput(vtkSelection* sel);
140
151  virtual bool MapSelectionToView(vtkSelection* sel);
152
154
159  virtual bool Export(vtkAbstractChartExporter* vtkNotUsed(exporter)) { return false; }
161
163  {
164  MERGED_BLOCKS = 0,
165  INDIVIDUAL_BLOCKS = 1,
166  };
167
169
174  vtkGetMacro(ArraySelectionMode, int);
175  void SetArraySelectionMode(int mode);
177
179
183  vtkGetMacro(ShowBlockName, bool);
184  vtkSetMacro(ShowBlockName, bool);
185  vtkBooleanMacro(ShowBlockName, bool);
187
189
200  void SetPlaceHolderDataType(int datatype);
201  vtkGetMacro(PlaceHolderDataType, int);
203 protected:
205  ~vtkChartRepresentation() override;
206
210  int FillInputPortInformation(int port, vtkInformation* info) override;
211
222  virtual void PrepareForRendering() {}
223
235
241  bool AddToView(vtkView* view) override;
242
248  bool RemoveFromView(vtkView* view) override;
249
256  vtkTable* GetLocalOutput(bool pre_delivery = false);
257
262  virtual vtkSmartPointer<vtkDataObject> TransformInputData(vtkDataObject* data);
263
271  virtual vtkSmartPointer<vtkDataObject> ReduceDataToRoot(vtkDataObject* data);
272
280
281  using MapOfTables = std::map<std::string, std::pair<vtkSmartPointer<vtkTable>, unsigned int>>;
285  bool GetLocalOutput(MapOfTables& tables);
286
289
290  std::vector<std::string> BlockSelectors;
291  std::set<unsigned int> CompositeIndices; // the selected blocks
292
293 private:
294  int FieldAssociation;
295  int FlattenTable;
296  int ArraySelectionMode = MERGED_BLOCKS;
297
298  // This is used to be able to create the correct placeHolder in RequestData for the client
299  int PlaceHolderDataType = VTK_PARTITIONED_DATA_SET_COLLECTION;
300
301  char* ActiveAssembly = nullptr;
302
303  vtkWeakPointer<vtkChartSelectionRepresentation> SelectionRepresentation;
304
305  bool ShowBlockName = true;
306
308  void operator=(const vtkChartRepresentation&) = delete;
309
310  vtkTimeStamp PrepareForRenderingTime;
311  vtkMTimeType LastLocalOutputMTime;
313  vtkSmartPointer<vtkDataObjectTree> LocalOutputRequestData;
314 };
315
316 #endif
data
This method is called before actual render if this->MTime was modified since the last time this metho...
std::vector< std::string > BlockSelectors
vtkPVDataRepresentation adds some ParaView specific API to data representations.
vtkWeakPointer< vtkPVContextView > ContextView
bool AddToView(vtkView *view) override
Making these methods public.
virtual void SetVisibility(bool val)
vtkTypeUInt64 vtkMTimeType
virtual int ProcessViewRequest(vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo)
virtual unsigned int Initialize(unsigned int minIdAvailable, unsigned int maxIdAvailable)
Initialize the representation with an identifier range so each internal representation can own a uniq...
virtual int FillInputPortInformation(int port, vtkInformation *info)
std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > MapOfTables
int RequestData(vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
Overridden to invoke vtkCommand::UpdateDataEvent.
bool RemoveFromView(vtkView *view) override
virtual void MarkModified()
This is one of the most important functions.
static vtkDataRepresentation * New()
virtual bool Export(vtkAbstractChartExporter *vtkNotUsed(exporter))
Called by vtkPVContextView::Export() to export the representation&#39;s data to a CSV file...
vtkPVContextView adopts vtkContextView so that it can be used in ParaView configurations.
vtkChartRepresentation is the base representation for charting representations.
exporter used by certain views to export data as CSV.
vtkSmartPointer< vtkDataObjectTree > LocalOutput
std::set< unsigned int > CompositeIndices
vtkSelectionDeliveryFilter is a filter that can deliver vtkSelection from data-server nodes to the cl...
exporter used by certain views to export data into a file or stream.
representation for showing selections in chart views.
