vtkCSVExporter.h
37 #ifndef vtkCSVExporter_h
38 #define vtkCSVExporter_h
41 #include "vtkPVVTKExtensionsFiltersRenderingModule.h" // needed for export macro
42
43 #include <string> // needed for std::string
45 class vtkAbstractArray;
46 class vtkDataArray;
47 class vtkFieldData;
48
50 {
51 public:
52  static vtkCSVExporter* New();
54  void PrintSelf(ostream& os, vtkIndent indent) override;
55
57
60  vtkSetStringMacro(FileName);
61  vtkGetStringMacro(FileName);
63
65
68  vtkSetStringMacro(FieldDelimiter);
69  vtkGetStringMacro(FieldDelimiter);
71
73
79  vtkSetMacro(Formatting, int);
80  vtkGetMacro(Formatting, int);
82
84
90  vtkSetMacro(Precision, int);
91  vtkGetMacro(Precision, int);
93
95
99  void SetColumnLabel(const char* name, const char* label);
100  void ClearColumnLabels();
101  const char* GetColumnLabel(const char* name);
103
107  bool Open(ExporterModes mode = STREAM_ROWS) override;
108
113  void Close() override;
114
119  void Abort() override;
120
122
127  void WriteHeader(vtkFieldData*) override;
128  void WriteData(vtkFieldData*) override;
130
138  void AddColumn(vtkAbstractArray* yarray, const char* yarrayname = nullptr,
139  vtkDataArray* xarray = nullptr) override;
140
141  // CVS writer does not support adding the style yet;
142  void AddStyle(vtkPlot* vtkNotUsed(plot), const char* vtkNotUsed(plotName)) override {};
143
144  void SetGlobalStyle(vtkChart* vtkNotUsed(chart)) override {};
146
148
151  vtkSetMacro(WriteToOutputString, bool);
152  vtkGetMacro(WriteToOutputString, bool);
153  vtkBooleanMacro(WriteToOutputString, bool);
155
161  std::string GetOutputString();
162
163 protected:
164  vtkCSVExporter();
165  ~vtkCSVExporter() override;
166
167  char* FileName = nullptr;
168  char* FieldDelimiter = nullptr;
169  std::ostream* OutputStream = nullptr;
171
172  bool WriteToOutputString = false;
173  std::string OutputString;
174
176  int Precision = 6;
177
178 private:
179  vtkCSVExporter(const vtkCSVExporter&) = delete;
180  void operator=(const vtkCSVExporter&) = delete;
181
182  class vtkInternals;
183  vtkInternals* Internals;
184 };
185
186 #endif
void AddStyle(vtkPlot *vtkNotUsed(plot), const char *vtkNotUsed(plotName)) override
virtual void WriteHeader(vtkFieldData *)=0
In STREAM_ROWS mode, use these methods to write column headers once using WriteHeader and then use Wr...
virtual void WriteData(vtkFieldData *)=0
virtual void Abort()=0
Same as Close except deletes the file, if created.
#define VTKPVVTKEXTENSIONSFILTERSRENDERING_EXPORT
void SetGlobalStyle(vtkChart *vtkNotUsed(chart)) override
static vtkAbstractChartExporter * New()
virtual bool Open(ExporterModes mode=STREAM_ROWS)=0
Open the file and set mode in which the exporter is operating.
virtual void Close()=0
Closes the file cleanly.
exporter used by certain views to export data as CSV.
exporter used by certain views to export data into a file or stream.
virtual void AddColumn(vtkAbstractArray *yarray, const char *yarrayname=nullptr, vtkDataArray *xarray=nullptr)=0
In STREAM_COLUMNS mode, use this method to add a column (yarray).
