| void | SetViewProxy (vtkSMViewProxy *proxy) |
| | Set the view proxy. More...
| vtkSMViewProxy * | GetViewProxy () |
| void | SetupInteractor (vtkRenderWindowInteractor *iren) |
| | Set the interactor to "help" the view with. More...
| vtkRenderWindowInteractor * | GetInteractor () |
| void | CleanupInteractor () |
helper class that make it easier to hook vtkRenderWindowInteractor and vtkSMViewProxy.
vtkSMViewProxyInteractorHelper is a helper class designed to make it easier to hook up vtkRenderWindowInteractor to call methods on a vtkSMViewProxy (or subclass). It's primarily designed to work with vtkSMRenderViewProxy (and subclasses), but it should work with other types of views too.
To use this helper, the view typically creates an instance for itself as register itself (using vtkSMViewProxyInteractorHelper::SetViewProxy) and then calls vtkSMViewProxyInteractorHelper::SetupInteractor(). This method will initialize the interactor (potentially changing some ivars on the interactor to avoid automatic rendering, using vtkRenderWindowInteractor::EnableRenderOff(), etc.) and setup event observer to monitor interaction.
vtkSMViewProxyInteractorHelper only using vtkSMViewProxy::StillRender() and vtkSMViewProxy::InteractiveRender() APIs directly. However several properties can be optionally present on the view proxy to dictate this class' behaviour. These are as follows:
NonInteractiveRenderDelay :- when present provides time in seconds to delay the StillRender() call after user interaction has ended i.e. vtkRenderWindowInteractor fires the vtkCommand::EndInteractionEvent. If missing, or less than 0.01, the view will immediately render.
EnableRenderOnInteraction :- when present provides a flag whether the interactor should trigger the render calls (either StillRender or InteractiveRender) as a consequence of interaction. If missing, we treat EnableRender as ON.
Definition at line 46 of file vtkSMViewProxyInteractorHelper.h.
