vtkSMScalarBarWidgetRepresentationProxy Class Reference
is the representation corresponding to a scalar bar or color legend in a Render View. More...
#include <vtkSMScalarBarWidgetRepresentationProxy.h>
Inheritance diagram for vtkSMScalarBarWidgetRepresentationProxy:
Collaboration diagram for vtkSMScalarBarWidgetRepresentationProxy:
typedef vtkSMNewWidgetRepresentationProxy Superclass
- Public Types inherited from vtkSMNewWidgetRepresentationProxy
typedef vtkSMNewWidgetRepresentationProxyAbstract Superclass
- Public Types inherited from vtkSMNewWidgetRepresentationProxyAbstract
typedef vtkSMProxy Superclass
void ClearRange ()
 Clears all data held by the scalar bar concerning range. More...
void AddRange (vtkSMRepresentationProxy *proxy)
 Add range to current scalar bar for a given representation proxy. More...
void AddBlockRange (vtkSMRepresentationProxy *proxy, const std::string &blockSelector)
void RemoveRange (vtkSMRepresentationProxy *proxy)
 Remove range to current scalar bar for a given representation proxy. More...
void RemoveBlockRange (vtkSMRepresentationProxy *proxy, const std::string &blockSelector)
void GetRange (double range[2], int component)
 Get the current range of the scalar bar. More...
- Public Member Functions inherited from vtkSMNewWidgetRepresentationProxy
virtual vtkAbstractWidgetGetWidget ()
 Get the widget for the representation. More...
virtual vtkSMProxyGetRepresentationProxy ()
 Get Representation Proxy. More...
- Public Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
bool LinkProperties (vtkSMProxy *controlledProxy, vtkSMPropertyGroup *controlledPropertyGroup)
 Called to link properties from a Widget to controlledProxy i.e. More...
bool UnlinkProperties (vtkSMProxy *controlledProxy)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMScalarBarWidgetRepresentationProxyNew ()
static vtkSMScalarBarWidgetRepresentationProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMNewWidgetRepresentationProxy
static vtkSMNewWidgetRepresentationProxyNew ()
static vtkSMNewWidgetRepresentationProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
static vtkSMNewWidgetRepresentationProxyAbstractSafeDownCast (vtkObject *o)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMScalarBarWidgetRepresentationProxy ()
 ~vtkSMScalarBarWidgetRepresentationProxy () override
 Overridden from vtkSMProxy to call BeginCreateVTKObjects() and EndCreateVTKObjects(). More...
void ExecuteEvent (unsigned long event) override
 Called every time the user interacts with the widget. More...
- Protected Member Functions inherited from vtkSMNewWidgetRepresentationProxy
 vtkSMNewWidgetRepresentationProxy ()
 ~vtkSMNewWidgetRepresentationProxy () override
- Protected Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
 vtkSMNewWidgetRepresentationProxyAbstract ()
 ~vtkSMNewWidgetRepresentationProxyAbstract () override
void ProcessLinkedPropertyEvent (vtkSMProperty *caller, unsigned long event)
 Called everytime a controlled property's unchecked values change. More...
void SetupPropertiesLinks ()
 Setup all links between properties and informations. More...
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMProxyActorProxy
std::unordered_map< vtkSMRepresentationProxy *, vtkWeakPointer< vtkSMRepresentationProxy > > Proxies
 Storing a list of proxies linked to this scalar bar. More...
std::map< std::pair< vtkSMRepresentationProxy *, std::string >, vtkWeakPointer< vtkSMRepresentationProxy > > BlockProxies
- Protected Attributes inherited from vtkSMNewWidgetRepresentationProxy
vtkSMProxyRepresentationProxy = nullptr
vtkSMProxyWidgetProxy = nullptr
vtkAbstractWidgetWidget = nullptr
- Protected Attributes inherited from vtkSMNewWidgetRepresentationProxyAbstract
vtkNew< vtkSMWidgetObserverObserver
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
static bool UpdateComponentTitle (vtkSMProxy *proxy, vtkPVArrayInformation *dataInfo)
 Updates the scalar bar's component title using the data information to determine component names if possible. More...
virtual bool UpdateComponentTitle (vtkPVArrayInformation *dataInfo)
static bool PlaceInView (vtkSMProxy *proxy, vtkSMProxy *view)
 Attempt to place the scalar bar in the view based on the placement of other currently shown and visible scalar bars. More...
virtual bool PlaceInView (vtkSMProxy *view)
Definition at line 25 of file vtkSMScalarBarWidgetRepresentationProxy.h.
Definition at line 30 of file vtkSMScalarBarWidgetRepresentationProxy.h.
◆ vtkSMScalarBarWidgetRepresentationProxy()
vtkSMScalarBarWidgetRepresentationProxy::vtkSMScalarBarWidgetRepresentationProxy ( )
◆ ~vtkSMScalarBarWidgetRepresentationProxy()
vtkSMScalarBarWidgetRepresentationProxy::~vtkSMScalarBarWidgetRepresentationProxy ( )
static vtkSMScalarBarWidgetRepresentationProxy* vtkSMScalarBarWidgetRepresentationProxy::New ( )
virtual const char* vtkSMScalarBarWidgetRepresentationProxy::GetClassName ( )
Reimplemented from vtkSMNewWidgetRepresentationProxy.
static int vtkSMScalarBarWidgetRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMScalarBarWidgetRepresentationProxy::IsA ( const char *  type)
static vtkSMScalarBarWidgetRepresentationProxy* vtkSMScalarBarWidgetRepresentationProxy::SafeDownCast ( vtkObject o)
void vtkSMScalarBarWidgetRepresentationProxy::PrintSelf ( ostream &  os,
◆ UpdateComponentTitle() [1/2]
virtual bool vtkSMScalarBarWidgetRepresentationProxy::UpdateComponentTitle ( vtkPVArrayInformation dataInfo)
◆ UpdateComponentTitle() [2/2]
static bool vtkSMScalarBarWidgetRepresentationProxy::UpdateComponentTitle ( vtkSMProxy proxy,
inlinestatic
Definition at line 39 of file vtkSMScalarBarWidgetRepresentationProxy.h.
◆ PlaceInView() [1/2]
virtual bool vtkSMScalarBarWidgetRepresentationProxy::PlaceInView ( vtkSMProxy view)
◆ PlaceInView() [2/2]
static bool vtkSMScalarBarWidgetRepresentationProxy::PlaceInView ( vtkSMProxy proxy,
vtkSMProxy view
inlinestatic
Definition at line 53 of file vtkSMScalarBarWidgetRepresentationProxy.h.
◆ AddRange()
void vtkSMScalarBarWidgetRepresentationProxy::AddRange ( vtkSMRepresentationProxy proxy)
This allows to display the combined range of multiple data sets that hold the same array.
◆ AddBlockRange()
void vtkSMScalarBarWidgetRepresentationProxy::AddBlockRange ( vtkSMRepresentationProxy proxy,
const std::string blockSelector
◆ RemoveRange()
void vtkSMScalarBarWidgetRepresentationProxy::RemoveRange ( vtkSMRepresentationProxy proxy)
◆ RemoveBlockRange()
void vtkSMScalarBarWidgetRepresentationProxy::RemoveBlockRange ( vtkSMRepresentationProxy proxy,
◆ GetRange() [1/2]
void vtkSMScalarBarWidgetRepresentationProxy::GetRange ( double  range[2],
int  component
◆ GetRange() [2/2]
void vtkSMScalarBarWidgetRepresentationProxy::GetRange ( double  range[2])
inline
Definition at line 86 of file vtkSMScalarBarWidgetRepresentationProxy.h.
◆ ClearRange()
void vtkSMScalarBarWidgetRepresentationProxy::ClearRange ( )
◆ CreateVTKObjects()
void vtkSMScalarBarWidgetRepresentationProxy::CreateVTKObjects ( )
overrideprotectedvirtual
◆ ExecuteEvent()
void vtkSMScalarBarWidgetRepresentationProxy::ExecuteEvent ( unsigned long  event)
◆ ActorProxy
vtkSMProxy* vtkSMScalarBarWidgetRepresentationProxy::ActorProxy
Definition at line 109 of file vtkSMScalarBarWidgetRepresentationProxy.h.
◆ Proxies
std::unordered_map<vtkSMRepresentationProxy*, vtkWeakPointer<vtkSMRepresentationProxy> > vtkSMScalarBarWidgetRepresentationProxy::Proxies
Note
We need 2 instances of vtkSMRepresentation* per item, as the proxy can become unused before this class is aware of it. The weak pointer helps not interfere with the life span of this proxy, and the raw pointer is used as key because of its constness: the weak pointer can become nullptr and would invalidate the container is used as key.
Definition at line 121 of file vtkSMScalarBarWidgetRepresentationProxy.h.
◆ BlockProxies
std::map<std::pair<vtkSMRepresentationProxy*, std::string>, vtkWeakPointer<vtkSMRepresentationProxy> > vtkSMScalarBarWidgetRepresentationProxy::BlockProxies
Note
Definition at line 124 of file vtkSMScalarBarWidgetRepresentationProxy.h.
