vtkSMPropArrayListDomain Class Reference
list of arrays obtained from input prop More...
#include <vtkSMPropArrayListDomain.h>
Inheritance diagram for vtkSMPropArrayListDomain:
Collaboration diagram for vtkSMPropArrayListDomain:
typedef vtkSMStringListDomain Superclass
- Public Types inherited from vtkSMArrayListDomain
enum  InformationKeyStrategy { NEED_KEY, REJECT_KEY }
- Public Types inherited from vtkSMStringListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *prop) override
 Updates the string list based on the available arrays for each prop. More...
- Public Member Functions inherited from vtkSMArrayListDomain
 Updates the string list based on the available arrays. More...
int IsArrayPartial (unsigned int idx)
 Returns true if the array with the given idx is partial false otherwise. More...
int GetFieldAssociation (unsigned int idx)
 Get field association for the array. More...
int GetDomainAssociation (unsigned int idx)
 Get the true field association for the array. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 A vtkSMProperty is often defined with a default value in the XML itself. More...
unsigned int RemoveInformationKey (const char *location, const char *name)
 Removes an InformationKey from this domain. More...
unsigned int GetNumberOfInformationKeys ()
 Returns the number of InformationKeys in this domain. More...
void RemoveAllInformationKeys ()
 Removes all InformationKeys from this domain. More...
virtual int GetAttributeType ()
 Return the attribute type. More...
virtual unsigned int AddInformationKey (const char *location, const char *name, int strategy)
 Adds a new InformationKey to the domain. More...
virtual unsigned int AddInformationKey (const char *location, const char *name)
const char * GetInformationKeyLocation (unsigned int)
 Returns the location/name/strategy of a given InformationKey. More...
const char * GetInformationKeyName (unsigned int)
int GetInformationKeyStrategy (unsigned int)
- Public Member Functions inherited from vtkSMStringListDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
void Update (vtkSMProperty *) override
 Update self checking the "unchecked" values of all required properties. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMPropertyGetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMPropertyGetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformationGetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformationGetInputDataSetInformation (const char *function, unsigned int index=0)
virtual vtkPVDataInformationGetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual vtkPVDataInformationGetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMPropArrayListDomainNew ()
static vtkSMPropArrayListDomainSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMArrayListDomain
static vtkSMArrayListDomainNew ()
static vtkSMArrayListDomainSafeDownCast (vtkObject *o)
static std::string CreateMangledName (vtkPVArrayInformation *arrayInfo, int component)
 returns the mangled name for the component index that is passed in. More...
static std::string ArrayNameFromMangledName (const char *name)
static int ComponentIndexFromMangledName (vtkPVArrayInformation *info, const char *name)
- Static Public Member Functions inherited from vtkSMStringListDomain
static vtkSMStringListDomainNew ()
static vtkSMStringListDomainSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomainNew ()
static vtkSMDomainSafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMPropArrayListDomain ()=default
 ~vtkSMPropArrayListDomain () override=default
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
 Read the mandatory array_type attribute for the domain, which must be either "point" or "cell". More...
- Protected Member Functions inherited from vtkSMArrayListDomain
 vtkSMArrayListDomain ()
 ~vtkSMArrayListDomain () override
virtual vtkPVDataInformationGetExtraDataInformation ()
 HACK: Provides a temporary mechanism for subclasses to provide an "additional" vtkPVDataInformation instance to get available arrays list from. More...
virtual bool IsFilteredArray (vtkPVDataInformation *info, int association, const char *arrayName)
 Returns true if an array should be filtered out. More...
virtual char * GetInputDomainName ()
 InputDomainName refers to a input property domain that describes the type of array is needed by this property. More...
virtual void SetInputDomainName (const char *)
virtual void SetAttributeType (int)
 Set to an attribute type defined in vtkDataSetAttributes. More...
- Protected Member Functions inherited from vtkSMStringListDomain
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMArrayListDomain
char * InputDomainName
bool PickFirstAvailableArrayByDefault
int AttributeType
- Protected Attributes inherited from vtkSMStringListDomain
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
This domain can only be used inside of a vtkSMRenderViewExporterProxy It allows selecting arrays for all props in the view. The exporter needs to be able to handle array selection for props in the form "propName:arrayName".
Definition at line 26 of file vtkSMPropArrayListDomain.h.
Definition at line 30 of file vtkSMPropArrayListDomain.h.
◆ vtkSMPropArrayListDomain()
vtkSMPropArrayListDomain::vtkSMPropArrayListDomain ( )
protecteddefault
◆ ~vtkSMPropArrayListDomain()
vtkSMPropArrayListDomain::~vtkSMPropArrayListDomain ( )
overrideprotecteddefault
static vtkSMPropArrayListDomain* vtkSMPropArrayListDomain::New ( )
virtual const char* vtkSMPropArrayListDomain::GetClassName ( )
Reimplemented from vtkSMArrayListDomain.
static int vtkSMPropArrayListDomain::IsTypeOf ( const char *  type)
virtual int vtkSMPropArrayListDomain::IsA ( const char *  type)
static vtkSMPropArrayListDomain* vtkSMPropArrayListDomain::SafeDownCast ( vtkObject o)
void vtkSMPropArrayListDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMPropArrayListDomain::Update ( vtkSMProperty prop)
◆ ReadXMLAttributes()
int vtkSMPropArrayListDomain::ReadXMLAttributes ( vtkSMProperty prop,
vtkPVXMLElement element
overrideprotectedvirtual
