vtkSMDynamicPropertiesDomain Class Reference
A domain (JSON description) for dynamic properties. More...
#include <vtkSMDynamicPropertiesDomain.h>
Inheritance diagram for vtkSMDynamicPropertiesDomain:
Collaboration diagram for vtkSMDynamicPropertiesDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int IsInDomain (vtkSMProperty *property) override
int SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override
vtkSMPropertyGetInfoProperty ()
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMPropertyGetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMPropertyGetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformationGetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformationGetInputDataSetInformation (const char *function, unsigned int index=0)
virtual vtkPVDataInformationGetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual vtkPVDataInformationGetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMDynamicPropertiesDomainSafeDownCast (vtkObject *o)
static vtkSMDynamicPropertiesDomainNew ()
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomainNew ()
static vtkSMDomainSafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMDynamicPropertiesDomain ()
 ~vtkSMDynamicPropertiesDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
virtual int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem)
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
See:
Definition at line 23 of file vtkSMDynamicPropertiesDomain.h.
Definition at line 26 of file vtkSMDynamicPropertiesDomain.h.
◆ vtkSMDynamicPropertiesDomain()
vtkSMDynamicPropertiesDomain::vtkSMDynamicPropertiesDomain ( )
◆ ~vtkSMDynamicPropertiesDomain()
vtkSMDynamicPropertiesDomain::~vtkSMDynamicPropertiesDomain ( )
virtual const char* vtkSMDynamicPropertiesDomain::GetClassName ( )
static int vtkSMDynamicPropertiesDomain::IsTypeOf ( const char *  type)
virtual int vtkSMDynamicPropertiesDomain::IsA ( const char *  type)
static vtkSMDynamicPropertiesDomain* vtkSMDynamicPropertiesDomain::SafeDownCast ( vtkObject o)
void vtkSMDynamicPropertiesDomain::PrintSelf ( ostream &  os,
static vtkSMDynamicPropertiesDomain* vtkSMDynamicPropertiesDomain::New ( )
◆ IsInDomain()
int vtkSMDynamicPropertiesDomain::IsInDomain ( vtkSMProperty property)
override
◆ SetDefaultValues()
int vtkSMDynamicPropertiesDomain::SetDefaultValues ( vtkSMProperty prop,
override
◆ GetInfoProperty()
vtkSMProperty* vtkSMDynamicPropertiesDomain::GetInfoProperty ( )
inline
Definition at line 35 of file vtkSMDynamicPropertiesDomain.h.
