Creates a panel_widget for setting dynamically generated properties. More...
#include <pqDynamicPropertiesWidget.h>
Public Slots | |
| void | setHeaderLabel (const QString &str) |
| void | setPushPropertyName (const QByteArray &pName) |
Signals | |
| void | widgetModified () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqDynamicPropertiesWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
| ~pqDynamicPropertiesWidget () override | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | setReadOnly (bool readOnly) |
| Set widget in read-only mode. More... | |
| virtual void | select () |
Protected Slots | |
| void | updateProperty () |
| Start a timer that calls updatePropertyImpl. More... | |
| void | updatePropertyImpl () |
| Update the Qt property with current widget state. More... | |
| bool | eventFilter (QObject *obj, QEvent *e) override |
| void | propertyChanged () |
| Update the widget state from the PropertyLink Qt property. More... | |
| template<class T > | |
The properties are specified using a JSON file. The JSON contains a version and an array of parameters, and possible additional key: value parameters which are ignored. each parameter has a name, type, description, default, min, max the type is an int given vtkDynamicProperties::Type (such as vtkDynamicProperties::Type) default, min and max have the specified type. Example: { "library": "environment" "renderer": "ao", "version": "1.0" "parameters": [ { "name" : "sampleLimit", "type" : <vtkDynamicProperties::Type> "default" : 128, "value": 0, "description" : "stop refining the frame after this number of samples", "max" : 100, "min" : 0, }, ... ] } The key names and types are defined in vtkDynamicProperties class.
See:
Definition at line 66 of file pqDynamicPropertiesWidget.h.
| pqDynamicPropertiesWidget::pqDynamicPropertiesWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | property, | ||
slot |
slot |
signal |
protectedslot |
This slot is triggered when a widget is modified.
protectedslot |
Emits widgetModified.
1.8.13 on Sat Oct 10 2026
