| virtual void | SetRootElement (vtkPVXMLElement *) |
| void | SetSession (vtkSMSession *session) |
| | Convenience method for setting the SessionProxyManager. More...
| vtkSMSession * | GetSession () |
| | Provides access to the session. More...
| vtkSMSessionProxyManager * | GetSessionProxyManager () |
| | Get/Set the proxy manager on which this deserializer is expected to operate. More...
| void | SetSessionProxyManager (vtkSMSessionProxyManager *) |
| | vtkSMCompoundProxyDefinitionLoader () |
| | ~vtkSMCompoundProxyDefinitionLoader () override |
| vtkPVXMLElement * | LocateProxyElement (vtkTypeUInt32 id) override |
| | Locate the XML for the proxy with the given id. More...
| | vtkSMDeserializerXML () |
| | ~vtkSMDeserializerXML () override |
| vtkSMProxy * | NewProxy (vtkTypeUInt32 id, vtkSMProxyLocator *locator) override |
| | Create a new proxy with the id if possible. More...
| virtual int | LoadProxyState (vtkPVXMLElement *element, vtkSMProxy *, vtkSMProxyLocator *locator) |
| | TEMPORARY. More...
| vtkSMProxy * | CreateProxy (const char *xmlgroup, const char *xmlname, const char *subProxyName=nullptr) override |
| | Create a new proxy of the given group and name. More...
| virtual void | CreatedNewProxy (vtkTypeUInt32 id, vtkSMProxy *proxy) |
| | Called after a new proxy has been created. More...
| | vtkSMDeserializer () |
| | ~vtkSMDeserializer () override |
| | vtkObject () |
| | vtkObjectBase () |
Creates a compound proxy from an XML definition.
vtkSMCompoundProxyDefinitionLoader can load a compound proxy definition from a given vtkPVXMLElement. This element can be populated by a vtkPVXMLElement or obtained from the proxy manager.
- See also
- vtkPVXMLElement vtkPVXMLParser vtkSMProxyManager
Definition at line 23 of file vtkSMCompoundProxyDefinitionLoader.h.
