representation that can be used to show a unstructured grid volume in a render view.
| void | AboutToDelete () override |
| | This method is called before the deletion of the SIObject. More...
| void | Push (vtkSMMessage *msg) override |
| | Push a new state to the underneath implementation. More...
| void | Pull (vtkSMMessage *msg) override |
| | Pull the current state of the underneath implementation. More...
| vtkSIProperty * | GetSIProperty (const char *name) |
| | Provides access to the property helper. More...
| bool | IsNullProxy () |
| | Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More...
| | Triggers UpdateInformation() on vtkObject if possible. More...
| | Called by vtkSMProxy::RecreateVTKObjects() to re-create the VTK objects. More...
| virtual bool | ExtendDefinition (const char *xml) |
| | Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More...
| | Returns access to the VTKObject pointer, if any. More...
| void | SetVTKObject (vtkObjectBase *) |
| | Returns the VTKClassName. More...
| virtual void | AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method) |
| | These methods are called to add/remove input connections by vtkSIInputProperty. More...
| virtual void | CleanInputs (const char *method) |
| virtual void | Initialize (vtkPVSessionCore *session) |
| | Initializes the instance. More...
| vtkClientServerInterpreter * | GetInterpreter () |
| | Provides access to the Interpreter. More...
| vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) const |
| | Convenience method to obtain a vtkSIObject subclass given its global id. More...
| vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| | Convenience method to obtain a vtkObject subclass given its global id. More...
| virtual void | SetGlobalID (vtkTypeUInt32) |
| | Get/Set the global id for this object. More...
vtkSIUnstructuredGridVolumeRepresentationProxy is a concrete representation that can be used to render the unstructured grid volume in a vtkSIRenderViewProxy.
Definition at line 18 of file vtkSIUnstructuredGridVolumeRepresentationProxy.h.
