vtkSMSelfGeneratingSourceProxy Class Reference
source proxy that generates its own proxy definition at run time. More...
#include <vtkSMSelfGeneratingSourceProxy.h>
Inheritance diagram for vtkSMSelfGeneratingSourceProxy:
Collaboration diagram for vtkSMSelfGeneratingSourceProxy:
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
 Overridden to process extended definition XML in the state file. More...
 Overridden to push extended definitions to the server side if not already pushed. More...
virtual bool ExtendDefinition (const char *proxy_definition_xml)
 Will extend this proxy to add properties using the XML definition provided. More...
virtual bool ExtendDefinition (vtkPVXMLElement *xml)
vtkPVXMLElementSaveXMLState (vtkPVXMLElement *root, vtkSMPropertyIterator *iter) override
 Overridden to save information about extended definitions loaded. More...
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual void UpdatePipeline ()
 Calls Update() on all sources. More...
virtual void UpdatePipeline (double time)
 Calls Update() on all sources with the given time request. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPortGetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPortGetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformationGetDataSetInformation (unsigned int outputIdx)
 Return the DataInformation of the source proxy. More...
vtkPVDataInformationGetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxyGetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
virtual bool GetStreamReply ()
 This returns information about whether this proxy will wait for a reply when executing a stream. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
void EnableAbortCheck ()
 Enable AbortCheck on both remote and local progress handler for this proxy. More...
void ClearAbortFlags ()
 Clear abort execute flags on remote vtk objects. More...
void RecreateVTKObjects () override
 Overidden to handle disabling abort check for the deleted objects Also calls superclass. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentationGetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentationGetOutputPortDocumentation (const char *portname)
vtkPVDataInformationGetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformationGetDataInformation (unsigned int outputIdx)
vtkPVDataInformationGetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformationGetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformationGetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxyGetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
 Overridden to handle selections. More...
unsigned int GetSelectionId ()
 Get/Set the ID and port of the proxy refered by this selection proxy. More...
unsigned int GetSelectionPort ()
void SetSelectionId (unsigned int id)
void SetSelectionPort (unsigned int port)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMSelfGeneratingSourceProxyNew ()
static vtkSMSelfGeneratingSourceProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxyNew ()
static vtkSMSourceProxySafeDownCast (vtkObject *o)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMSelfGeneratingSourceProxy ()
 ~vtkSMSelfGeneratingSourceProxy () override
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
void ExecuteStream (const vtkClientServerStream &msg, bool ignoreErrors=false, vtkTypeUInt32 location=0) override
 Execute provided stream using the internal session with sendReply positioned to StreamReply value. More...
virtual void InvalidateDataInformation ()
 Mark the data information as invalid. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
virtual void SetExecutiveName (const char *)
void PostUpdateData (bool) override
 Overwritten from superclass to invoke. More...
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMSelfGeneratingSourceProxy is a source proxy that supports extending its property definition at runtime. Client code can instantiate this proxy using standard mechanisms and then call ExtendDefinition to add XML stubs to this proxy's definitions. vtkSMSelfGeneratingSourceProxy (working together with vtkSIProxy) ensures that those extensions get loaded correctly on both client and server side. After that point, the proxy is pretty much like a regular proxy together with its properties.
vtkSMSelfGeneratingSourceProxy also ensures that when the XML state for this proxy gets saved, the extended definitions are also saved in the XML state so that they can be loaded back as well.
Warning
This is only intended for simple source proxies. The ExtendDefinition() API is only intended to add new property definitions for the proxy and should not be used for adding other entities in a proxy definition such as sub proxies, hints, documentation, etc.
Definition at line 32 of file vtkSMSelfGeneratingSourceProxy.h.
Definition at line 36 of file vtkSMSelfGeneratingSourceProxy.h.
◆ vtkSMSelfGeneratingSourceProxy()
vtkSMSelfGeneratingSourceProxy::vtkSMSelfGeneratingSourceProxy ( )
◆ ~vtkSMSelfGeneratingSourceProxy()
vtkSMSelfGeneratingSourceProxy::~vtkSMSelfGeneratingSourceProxy ( )
static vtkSMSelfGeneratingSourceProxy* vtkSMSelfGeneratingSourceProxy::New ( )
virtual const char* vtkSMSelfGeneratingSourceProxy::GetClassName ( )
Reimplemented from vtkSMSourceProxy.
static int vtkSMSelfGeneratingSourceProxy::IsTypeOf ( const char *  type)
virtual int vtkSMSelfGeneratingSourceProxy::IsA ( const char *  type)
static vtkSMSelfGeneratingSourceProxy* vtkSMSelfGeneratingSourceProxy::SafeDownCast ( vtkObject o)
void vtkSMSelfGeneratingSourceProxy::PrintSelf ( ostream &  os,
◆ ExtendDefinition() [1/2]
virtual bool vtkSMSelfGeneratingSourceProxy::ExtendDefinition ( const char *  proxy_definition_xml)
◆ ExtendDefinition() [2/2]
virtual bool vtkSMSelfGeneratingSourceProxy::ExtendDefinition ( vtkPVXMLElement xml)
◆ SaveXMLState()
vtkPVXMLElement* vtkSMSelfGeneratingSourceProxy::SaveXMLState ( vtkPVXMLElement root,
vtkSMPropertyIterator iter
◆ LoadXMLState()
int vtkSMSelfGeneratingSourceProxy::LoadXMLState ( vtkPVXMLElement element,
vtkSMProxyLocator locator
◆ CreateVTKObjects()
void vtkSMSelfGeneratingSourceProxy::CreateVTKObjects ( )
