vtkPythonAnnotationFilter Class Reference
filter used to generate text annotation from Python expressions. More...
#include <vtkPythonAnnotationFilter.h>
Inheritance diagram for vtkPythonAnnotationFilter:
Collaboration diagram for vtkPythonAnnotationFilter:
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
virtual int GetNumberOfTimeSteps ()
double GetTimeStep (int index)
virtual bool GetTimeRangeValid ()
virtual doubleGetTimeRange ()
virtual void GetTimeRange (double &, double &)
virtual void GetTimeRange (double [2])
virtual vtkDataObjectGetCurrentInputDataObject ()
void SetComputedAnnotationValue (const char *value)
virtual void SetExpression (const char *)
 Set the expression to evaluate. More...
virtual char * GetExpression ()
virtual void SetArrayAssociation (int)
 Set the input array association. More...
virtual int GetArrayAssociation ()
virtual char * GetComputedAnnotationValue ()
 Get the value that is going to be printed to the output. More...
virtual bool GetDataTimeValid ()
 Get methods for use in annotation.py. More...
virtual double GetDataTime ()
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithmNewInstance () const
vtkTableGetOutput ()
vtkTableGetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPythonAnnotationFilterNew ()
static vtkPythonAnnotationFilterSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithmNew ()
static vtkTableAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPythonAnnotationFilter ()
 ~vtkPythonAnnotationFilter () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
virtual void EvaluateExpression ()
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
char * Expression
char * ComputedAnnotationValue
int ArrayAssociation
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPythonAnnotationFilter is designed to generate vtkTableAlgorithm with a single string in it. The goal is that user will write a Python expression, similar to an expression in Python Calculator (vtkPythonCalculator). The generated result is converted to string and placed in the output.
The variables available in the expression evaluation scope are as follows:
Examples of valid expressions are:
Definition at line 38 of file vtkPythonAnnotationFilter.h.
Definition at line 42 of file vtkPythonAnnotationFilter.h.
◆ vtkPythonAnnotationFilter()
vtkPythonAnnotationFilter::vtkPythonAnnotationFilter ( )
◆ ~vtkPythonAnnotationFilter()
vtkPythonAnnotationFilter::~vtkPythonAnnotationFilter ( )
static vtkPythonAnnotationFilter* vtkPythonAnnotationFilter::New ( )
virtual const char* vtkPythonAnnotationFilter::GetClassName ( )
Reimplemented in vtkAnnotateAttributeDataFilter.
static int vtkPythonAnnotationFilter::IsTypeOf ( const char *  type)
virtual int vtkPythonAnnotationFilter::IsA ( const char *  type)
Reimplemented from vtkTableAlgorithm.
static vtkPythonAnnotationFilter* vtkPythonAnnotationFilter::SafeDownCast ( vtkObject o)
void vtkPythonAnnotationFilter::PrintSelf ( ostream &  os,
◆ SetExpression()
virtual void vtkPythonAnnotationFilter::SetExpression ( const char *  )
Here is a set of common expressions:
  • "Momentum %s" % str(Momentum[available_timesteps.index(provided_time)])
◆ GetExpression()
virtual char* vtkPythonAnnotationFilter::GetExpression ( )
◆ SetArrayAssociation()
virtual void vtkPythonAnnotationFilter::SetArrayAssociation ( int  )
This dictates which array names are made available in the namespace by default. You can still use input.PointData['foo'] or input.CellData['bar'] explicitly to pick a specific array in your expression.
◆ GetArrayAssociation()
virtual int vtkPythonAnnotationFilter::GetArrayAssociation ( )
◆ GetComputedAnnotationValue()
virtual char* vtkPythonAnnotationFilter::GetComputedAnnotationValue ( )
◆ GetDataTimeValid()
virtual bool vtkPythonAnnotationFilter::GetDataTimeValid ( )
The values are only valid during RequestData().
◆ GetDataTime()
virtual double vtkPythonAnnotationFilter::GetDataTime ( )
◆ GetNumberOfTimeSteps()
virtual int vtkPythonAnnotationFilter::GetNumberOfTimeSteps ( )
◆ GetTimeStep()
double vtkPythonAnnotationFilter::GetTimeStep ( int  index)
inline
Definition at line 84 of file vtkPythonAnnotationFilter.h.
◆ GetTimeRangeValid()
virtual bool vtkPythonAnnotationFilter::GetTimeRangeValid ( )
◆ GetTimeRange() [1/3]
virtual double* vtkPythonAnnotationFilter::GetTimeRange ( )
◆ GetTimeRange() [2/3]
virtual void vtkPythonAnnotationFilter::GetTimeRange ( double ,
double
◆ GetTimeRange() [3/3]
virtual void vtkPythonAnnotationFilter::GetTimeRange ( double  [2])
◆ GetCurrentInputDataObject()
virtual vtkDataObject* vtkPythonAnnotationFilter::GetCurrentInputDataObject ( )
◆ SetComputedAnnotationValue()
void vtkPythonAnnotationFilter::SetComputedAnnotationValue ( const char *  value)
◆ FillInputPortInformation()
int vtkPythonAnnotationFilter::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ RequestInformation()
int vtkPythonAnnotationFilter::RequestInformation ( vtkInformation request,
vtkInformationVector outputVector
◆ RequestData()
int vtkPythonAnnotationFilter::RequestData ( vtkInformation request,
◆ EvaluateExpression()
virtual void vtkPythonAnnotationFilter::EvaluateExpression ( )
protectedvirtual
◆ Expression
char* vtkPythonAnnotationFilter::Expression
Definition at line 106 of file vtkPythonAnnotationFilter.h.
◆ ComputedAnnotationValue
char* vtkPythonAnnotationFilter::ComputedAnnotationValue
Definition at line 107 of file vtkPythonAnnotationFilter.h.
◆ ArrayAssociation
int vtkPythonAnnotationFilter::ArrayAssociation
Definition at line 108 of file vtkPythonAnnotationFilter.h.
