vtkPythonCalculator Class Reference
Evaluates a Python expression vtkPythonCalculator uses Python to calculate an expression. More...
#include <vtkPythonCalculator.h>
Inheritance diagram for vtkPythonCalculator:
Collaboration diagram for vtkPythonCalculator:
typedef vtkProgrammableFilter Superclass
- Public Types inherited from vtkProgrammableFilter
typedef void(* ProgrammableMethodCallbackType) (void *arg)
enum  DesiredOutputPrecision
void ClearInputNames ()
 Clears all assigned input names. More...
virtual void SetArrayAssociation (int)
 Which field data to get the arrays from. More...
virtual int GetArrayAssociation ()
virtual void SetExpression (std::string)
 Set the text of the python expression to execute. More...
virtual std::string GetExpression ()
virtual void SetMultilineExpression (std::string)
 Set the text of the python multiline expression. More...
virtual std::string GetMultilineExpression ()
virtual void SetArrayName (const char *)
 Set the name of the output array. More...
virtual char * GetArrayName ()
virtual int GetResultArrayType ()
 Type of the result array. More...
virtual void SetResultArrayType (int)
virtual bool GetUseMultilineExpression ()
 If true, executes MultilineExpression, which is a multiline string representing a Python script, ending by a return statement. More...
virtual void SetUseMultilineExpression (bool)
void SetInputName (int index, const std::string &inputName)
 Set/Get an association between an input name and an index to get access to inputs with their name instead of their index. More...
std::string GetInputName (int index)
- Public Member Functions inherited from vtkProgrammableFilter
vtkProgrammableFilterNewInstance () const
void SetExecuteMethod (void(*f)(void *), void *arg)
void SetExecuteMethodArgDelete (void(*f)(void *))
vtkPolyDataGetPolyDataInput ()
vtkStructuredPointsGetStructuredPointsInput ()
vtkStructuredGridGetStructuredGridInput ()
vtkUnstructuredGridGetUnstructuredGridInput ()
vtkRectilinearGridGetRectilinearGridInput ()
vtkGraphGetGraphInput ()
vtkTableGetTableInput ()
virtual void SetCopyArrays (bool)
virtual bool GetCopyArrays ()
virtual void CopyArraysOn ()
virtual void CopyArraysOff ()
vtkPassInputTypeAlgorithmNewInstance () const
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkTableGetTableOutput ()
vtkGraphGetGraphOutput ()
vtkDataObjectGetInput ()
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPythonCalculatorSafeDownCast (vtkObject *o)
static vtkPythonCalculatorNew ()
static void ExecuteScript (void *)
 For internal use only. More...
- Static Public Member Functions inherited from vtkProgrammableFilter
static vtkProgrammableFilterNew ()
static vtkProgrammableFilterSafeDownCast (vtkObjectBase *o)
static vtkPassInputTypeAlgorithmNew ()
static vtkPassInputTypeAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPythonCalculator ()
 ~vtkPythonCalculator () override
void Exec (const std::string &)
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
int RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
- Protected Member Functions inherited from vtkProgrammableFilter
 vtkProgrammableFilter ()
 ~vtkProgrammableFilter ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
virtual int RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
std::string Expression
std::string MultilineExpression
bool UseMultilineExpression = false
char * ArrayName = nullptr
int ArrayAssociation = vtkDataObject::FIELD_ASSOCIATION_POINTS
int ResultArrayType = VTK_DOUBLE
- Protected Attributes inherited from vtkProgrammableFilter
ProgrammableMethodCallbackType ExecuteMethod
ProgrammableMethodCallbackType ExecuteMethodArgDelete
void * ExecuteMethodArg
bool CopyArrays
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter depends heavily on the numpy and paraview.vtk modules. To use the parallel functions, mpi4py is also necessary. The expression is evaluated and the resulting scalar value or numpy array is added to the output as an array. See numpy and paraview.vtk documentation for the list of available functions.
The variables available in the expression evaluation scope are as follows:
Definition at line 35 of file vtkPythonCalculator.h.
Definition at line 38 of file vtkPythonCalculator.h.
◆ vtkPythonCalculator()
vtkPythonCalculator::vtkPythonCalculator ( )
◆ ~vtkPythonCalculator()
vtkPythonCalculator::~vtkPythonCalculator ( )
virtual const char* vtkPythonCalculator::GetClassName ( )
static int vtkPythonCalculator::IsTypeOf ( const char *  type)
virtual int vtkPythonCalculator::IsA ( const char *  type)
Reimplemented from vtkProgrammableFilter.
static vtkPythonCalculator* vtkPythonCalculator::SafeDownCast ( vtkObject o)
void vtkPythonCalculator::PrintSelf ( ostream &  os,
static vtkPythonCalculator* vtkPythonCalculator::New ( )
◆ SetArrayAssociation()
virtual void vtkPythonCalculator::SetArrayAssociation ( int  )
See vtkDataObject::FieldAssociations for choices. The default is FIELD_ASSOCIATION_POINTS.
◆ GetArrayAssociation()
virtual int vtkPythonCalculator::GetArrayAssociation ( )
◆ SetExpression()
virtual void vtkPythonCalculator::SetExpression ( std::string  )
This expression must return a scalar value (which is converted to an array) or a numpy array.
◆ GetExpression()
virtual std::string vtkPythonCalculator::GetExpression ( )
◆ SetMultilineExpression()
virtual void vtkPythonCalculator::SetMultilineExpression ( std::string  )
The expression must use an explicit return statement for the result scalar value or numpy array.
◆ GetMultilineExpression()
virtual std::string vtkPythonCalculator::GetMultilineExpression ( )
◆ SetArrayName()
virtual void vtkPythonCalculator::SetArrayName ( const char *  )
The default is Result.
◆ GetArrayName()
virtual char* vtkPythonCalculator::GetArrayName ( )
◆ GetResultArrayType()
virtual int vtkPythonCalculator::GetResultArrayType ( )
Initial value is VTK_DOUBLE.
◆ SetResultArrayType()
virtual void vtkPythonCalculator::SetResultArrayType ( int  )
◆ GetUseMultilineExpression()
virtual bool vtkPythonCalculator::GetUseMultilineExpression ( )
Otherwise, evaluates Expression, a python expression. Initial value is false.
◆ SetUseMultilineExpression()
virtual void vtkPythonCalculator::SetUseMultilineExpression ( bool  )
◆ SetInputName()
void vtkPythonCalculator::SetInputName ( int  index,
const std::string inputName
Inputs can then be accessed by Sphere2 or inputs["Sphere2"] instead of inputs[1]
◆ GetInputName()
std::string vtkPythonCalculator::GetInputName ( int  index)
◆ ClearInputNames()
void vtkPythonCalculator::ClearInputNames ( )
◆ ExecuteScript()
static void vtkPythonCalculator::ExecuteScript ( void *  )
◆ Exec()
void vtkPythonCalculator::Exec ( const std::string )
◆ FillOutputPortInformation()
int vtkPythonCalculator::FillOutputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ FillInputPortInformation()
int vtkPythonCalculator::FillInputPortInformation ( int  port,
vtkInformation info
◆ RequestInformation()
int vtkPythonCalculator::RequestInformation ( vtkInformation request,
vtkInformationVector outputVector
◆ RequestData()
int vtkPythonCalculator::RequestData ( vtkInformation request,
◆ RequestDataObject()
int vtkPythonCalculator::RequestDataObject ( vtkInformation request,
◆ Expression
std::string vtkPythonCalculator::Expression
Definition at line 146 of file vtkPythonCalculator.h.
◆ MultilineExpression
std::string vtkPythonCalculator::MultilineExpression
Definition at line 147 of file vtkPythonCalculator.h.
◆ UseMultilineExpression
bool vtkPythonCalculator::UseMultilineExpression = false
Definition at line 148 of file vtkPythonCalculator.h.
◆ ArrayName
char* vtkPythonCalculator::ArrayName = nullptr
Definition at line 150 of file vtkPythonCalculator.h.
◆ ArrayAssociation
int vtkPythonCalculator::ArrayAssociation = vtkDataObject::FIELD_ASSOCIATION_POINTS
Definition at line 151 of file vtkPythonCalculator.h.
◆ ResultArrayType
int vtkPythonCalculator::ResultArrayType = VTK_DOUBLE
Definition at line 152 of file vtkPythonCalculator.h.
