Public Types | Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Protected Attributes | List of all members
vtkPVMetaSliceDataSet Class Reference
Meta class for slice filter that will allow the user to switch between a regular cutter filter or an extract cell by region filter. More...
#include <vtkPVMetaSliceDataSet.h>
Inheritance diagram for vtkPVMetaSliceDataSet:
Collaboration diagram for vtkPVMetaSliceDataSet:
typedef vtkPVDataSetAlgorithmSelectorFilter Superclass
- Public Types inherited from vtkPVDataSetAlgorithmSelectorFilter
enum  DesiredOutputPrecision
void PreserveInputCells (int keepCellAsIs)
 Enable or disable the Extract Cells By Regions. More...
void SetImplicitFunction (vtkImplicitFunction *func)
void SetDataSetCutFunction (vtkImplicitFunction *func)
 Sets the cut function for vtkDataSet inputs. More...
void SetHyperTreeGridCutFunction (vtkImplicitFunction *func)
 Sets the cut function for vtkHyperTreeGrid inputs. More...
void SetCutFunction (vtkImplicitFunction *func)
 Expose method from vtkPVCutter. More...
void SetNumberOfContours (int nbContours)
void SetValue (int index, double value)
void SetGenerateTriangles (int status)
void SetDual (bool dual)
 Method used for vtkHyperTreeGrid. More...
int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
vtkMTimeType GetMTime () override
 Override GetMTime because the implicit functions need to be taken into account. More...
void SetLocator (vtkIncrementalPointLocator *locator)
 Set / get a spatial locator. More...
vtkIncrementalPointLocatorGetLocator ()
- Public Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
int RegisterFilter (vtkAlgorithm *filter)
 Register a new filter that can be used underneath in the requestData call. More...
void UnRegisterFilter (int index)
 UnRegister an existing filter that was previously registered. More...
void ClearFilters ()
 Remove all the registered filters. More...
int GetNumberOfFilters ()
 Return the current number of registered filters. More...
vtkAlgorithmGetFilter (int index)
 Return the filter that lies at the given index of the filters registration queue. More...
vtkAlgorithmGetActiveFilter ()
 Return the current active filter if any otherwise return nullptr. More...
virtual vtkAlgorithmSetActiveFilter (int index)
 Set the active filter based on the given index of the filters registration queue. More...
int ProcessRequest (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) override
 Forward those methods to the underneath filters. More...
virtual int ProcessRequest (vtkInformation *request, vtkCollection *inInfo, vtkInformationVector *outInfo)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVMetaSliceDataSetSafeDownCast (vtkObject *o)
static vtkPVMetaSliceDataSetNew ()
- Static Public Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
static vtkPVDataSetAlgorithmSelectorFilterSafeDownCast (vtkObject *o)
static vtkPVDataSetAlgorithmSelectorFilterNew ()
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
static const unsigned METASLICE_DATASET = 0
static const unsigned METASLICE_HYPERTREEGRID = 1
 vtkPVMetaSliceDataSet ()
 ~vtkPVMetaSliceDataSet () override
- Protected Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
 vtkPVDataSetAlgorithmSelectorFilter ()
 ~vtkPVDataSetAlgorithmSelectorFilter () override
virtual int GetOutputType ()
virtual void SetOutputType (int)
void InternalProgressCallback (vtkAlgorithm *algorithm)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkImplicitFunctionImplicitFunctions [2]
- Protected Attributes inherited from vtkPVDataSetAlgorithmSelectorFilter
int OutputType
vtkCallbackCommandInternalProgressObserver
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Static Protected Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
static void InternalProgressCallbackFunction (vtkObject *, unsigned long, void *clientdata, void *)
Definition at line 22 of file vtkPVMetaSliceDataSet.h.
Definition at line 26 of file vtkPVMetaSliceDataSet.h.
◆ vtkPVMetaSliceDataSet()
vtkPVMetaSliceDataSet::vtkPVMetaSliceDataSet ( )
◆ ~vtkPVMetaSliceDataSet()
vtkPVMetaSliceDataSet::~vtkPVMetaSliceDataSet ( )
virtual const char* vtkPVMetaSliceDataSet::GetClassName ( )
static int vtkPVMetaSliceDataSet::IsTypeOf ( const char *  type)
virtual int vtkPVMetaSliceDataSet::IsA ( const char *  type)
static vtkPVMetaSliceDataSet* vtkPVMetaSliceDataSet::SafeDownCast ( vtkObject o)
void vtkPVMetaSliceDataSet::PrintSelf ( ostream &  os,
static vtkPVMetaSliceDataSet* vtkPVMetaSliceDataSet::New ( )
◆ PreserveInputCells()
void vtkPVMetaSliceDataSet::PreserveInputCells ( int  keepCellAsIs)
◆ SetImplicitFunction()
void vtkPVMetaSliceDataSet::SetImplicitFunction ( vtkImplicitFunction func)
◆ SetDataSetCutFunction()
void vtkPVMetaSliceDataSet::SetDataSetCutFunction ( vtkImplicitFunction func)
◆ SetHyperTreeGridCutFunction()
void vtkPVMetaSliceDataSet::SetHyperTreeGridCutFunction ( vtkImplicitFunction func)
◆ SetCutFunction()
void vtkPVMetaSliceDataSet::SetCutFunction ( vtkImplicitFunction func)
inline
Definition at line 56 of file vtkPVMetaSliceDataSet.h.
◆ SetNumberOfContours()
void vtkPVMetaSliceDataSet::SetNumberOfContours ( int  nbContours)
◆ SetValue()
void vtkPVMetaSliceDataSet::SetValue ( int  index,
double  value
◆ SetGenerateTriangles()
void vtkPVMetaSliceDataSet::SetGenerateTriangles ( int  status)
◆ SetDual()
void vtkPVMetaSliceDataSet::SetDual ( bool  dual)
◆ RequestDataObject()
int vtkPVMetaSliceDataSet::RequestDataObject ( vtkInformation ,
vtkInformationVector **  ,
◆ SetLocator()
void vtkPVMetaSliceDataSet::SetLocator ( vtkIncrementalPointLocator locator)
◆ GetLocator()
vtkIncrementalPointLocator* vtkPVMetaSliceDataSet::GetLocator ( )
◆ GetMTime()
vtkMTimeType vtkPVMetaSliceDataSet::GetMTime ( )
Reimplemented from vtkPVDataSetAlgorithmSelectorFilter.
◆ METASLICE_DATASET
const unsigned vtkPVMetaSliceDataSet::METASLICE_DATASET = 0
Definition at line 31 of file vtkPVMetaSliceDataSet.h.
◆ METASLICE_HYPERTREEGRID
const unsigned vtkPVMetaSliceDataSet::METASLICE_HYPERTREEGRID = 1
Definition at line 32 of file vtkPVMetaSliceDataSet.h.
◆ ImplicitFunctions
vtkImplicitFunction* vtkPVMetaSliceDataSet::ImplicitFunctions[2]
Definition at line 98 of file vtkPVMetaSliceDataSet.h.
