Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
vtkPVDataSetAlgorithmSelectorFilter Class Reference
is a generic vtkAlgorithm that allow the user to register several vtkAlgorithm to it and be able to switch the active one on the fly. More...
#include <vtkPVDataSetAlgorithmSelectorFilter.h>
Inheritance diagram for vtkPVDataSetAlgorithmSelectorFilter:
Collaboration diagram for vtkPVDataSetAlgorithmSelectorFilter:
enum  DesiredOutputPrecision
int RegisterFilter (vtkAlgorithm *filter)
 Register a new filter that can be used underneath in the requestData call. More...
void UnRegisterFilter (int index)
 UnRegister an existing filter that was previously registered. More...
void ClearFilters ()
 Remove all the registered filters. More...
int GetNumberOfFilters ()
 Return the current number of registered filters. More...
vtkAlgorithmGetFilter (int index)
 Return the filter that lies at the given index of the filters registration queue. More...
vtkAlgorithmGetActiveFilter ()
 Return the current active filter if any otherwise return nullptr. More...
virtual vtkAlgorithmSetActiveFilter (int index)
 Set the active filter based on the given index of the filters registration queue. More...
vtkMTimeType GetMTime () override
 Override GetMTime because we delegate to other filters to do the real work. More...
int ProcessRequest (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) override
 Forward those methods to the underneath filters. More...
virtual int ProcessRequest (vtkInformation *request, vtkCollection *inInfo, vtkInformationVector *outInfo)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVDataSetAlgorithmSelectorFilterSafeDownCast (vtkObject *o)
static vtkPVDataSetAlgorithmSelectorFilterNew ()
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVDataSetAlgorithmSelectorFilter ()
 ~vtkPVDataSetAlgorithmSelectorFilter () override
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *outputVector)
virtual int GetOutputType ()
virtual void SetOutputType (int)
void InternalProgressCallback (vtkAlgorithm *algorithm)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
static void InternalProgressCallbackFunction (vtkObject *, unsigned long, void *clientdata, void *)
int OutputType
vtkCallbackCommandInternalProgressObserver
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
The idea behind that filter is to merge the usage of any number of existing vtk filter and allow to easily switch from one implementation to another without changing anything in your pipeline.
Definition at line 23 of file vtkPVDataSetAlgorithmSelectorFilter.h.
Definition at line 27 of file vtkPVDataSetAlgorithmSelectorFilter.h.
◆ vtkPVDataSetAlgorithmSelectorFilter()
vtkPVDataSetAlgorithmSelectorFilter::vtkPVDataSetAlgorithmSelectorFilter ( )
◆ ~vtkPVDataSetAlgorithmSelectorFilter()
vtkPVDataSetAlgorithmSelectorFilter::~vtkPVDataSetAlgorithmSelectorFilter ( )
virtual const char* vtkPVDataSetAlgorithmSelectorFilter::GetClassName ( )
static int vtkPVDataSetAlgorithmSelectorFilter::IsTypeOf ( const char *  type)
virtual int vtkPVDataSetAlgorithmSelectorFilter::IsA ( const char *  type)
Reimplemented in vtkPVMetaSliceDataSet, and vtkPVMetaClipDataSet.
static vtkPVDataSetAlgorithmSelectorFilter* vtkPVDataSetAlgorithmSelectorFilter::SafeDownCast ( vtkObject o)
void vtkPVDataSetAlgorithmSelectorFilter::PrintSelf ( ostream &  os,
static vtkPVDataSetAlgorithmSelectorFilter* vtkPVDataSetAlgorithmSelectorFilter::New ( )
◆ RegisterFilter()
int vtkPVDataSetAlgorithmSelectorFilter::RegisterFilter ( vtkAlgorithm filter)
The return value is the index of that registered filter that should be use to activate it later on. (This number can became wrong in case you remove some previous registered filter)
◆ UnRegisterFilter()
void vtkPVDataSetAlgorithmSelectorFilter::UnRegisterFilter ( int  index)
◆ ClearFilters()
void vtkPVDataSetAlgorithmSelectorFilter::ClearFilters ( )
◆ GetNumberOfFilters()
int vtkPVDataSetAlgorithmSelectorFilter::GetNumberOfFilters ( )
◆ GetFilter()
vtkAlgorithm* vtkPVDataSetAlgorithmSelectorFilter::GetFilter ( int  index)
◆ GetActiveFilter()
vtkAlgorithm* vtkPVDataSetAlgorithmSelectorFilter::GetActiveFilter ( )
◆ SetActiveFilter()
virtual vtkAlgorithm* vtkPVDataSetAlgorithmSelectorFilter::SetActiveFilter ( int  index)
And return the corresponding active filter.
◆ GetMTime()
vtkMTimeType vtkPVDataSetAlgorithmSelectorFilter::GetMTime ( )
Reimplemented in vtkPVMetaClipDataSet, and vtkPVMetaSliceDataSet.
◆ ProcessRequest() [1/2]
int vtkPVDataSetAlgorithmSelectorFilter::ProcessRequest ( vtkInformation request,
vtkInformationVector **  inInfo,
vtkInformationVector outInfo
Reimplemented in vtkPVMetaClipDataSet.
◆ ProcessRequest() [2/2]
virtual int vtkPVDataSetAlgorithmSelectorFilter::ProcessRequest ( vtkInformation request,
vtkCollection inInfo,
◆ RequestDataObject()
virtual int vtkPVDataSetAlgorithmSelectorFilter::RequestDataObject ( vtkInformation ,
vtkInformationVector **  ,
vtkInformationVector outputVector
protectedvirtual
◆ FillInputPortInformation()
int vtkPVDataSetAlgorithmSelectorFilter::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ FillOutputPortInformation()
int vtkPVDataSetAlgorithmSelectorFilter::FillOutputPortInformation ( int  port,
vtkInformation info
◆ GetOutputType()
virtual int vtkPVDataSetAlgorithmSelectorFilter::GetOutputType ( )
protectedvirtual
◆ SetOutputType()
virtual void vtkPVDataSetAlgorithmSelectorFilter::SetOutputType ( int  )
protectedvirtual
◆ InternalProgressCallbackFunction()
static void vtkPVDataSetAlgorithmSelectorFilter::InternalProgressCallbackFunction ( vtkObject ,
unsigned  long,
void *  clientdata,
void *
staticprotected
◆ InternalProgressCallback()
void vtkPVDataSetAlgorithmSelectorFilter::InternalProgressCallback ( vtkAlgorithm algorithm)
◆ OutputType
int vtkPVDataSetAlgorithmSelectorFilter::OutputType
Definition at line 98 of file vtkPVDataSetAlgorithmSelectorFilter.h.
◆ InternalProgressObserver
vtkCallbackCommand* vtkPVDataSetAlgorithmSelectorFilter::InternalProgressObserver
Definition at line 105 of file vtkPVDataSetAlgorithmSelectorFilter.h.
