Internal class used as the TabWidget.
#include <pqTabbedMultiViewWidget.h>
Inherits QTabWidget.
| static QString | popoutLabelText (bool popped_out) |
| | Returns the label/tooltip to use for the popout button given the popped_out state. More...
| static QStyle::StandardPixmap | popoutLabelPixmap (bool popped_out) |
| | Returns the icon to use for the popout button given the popped_out state. More...
Definition at line 213 of file pqTabbedMultiViewWidget.h.
◆ pqTabWidget()
| pqTabbedMultiViewWidget::pqTabWidget::pqTabWidget |
QWidget * |
parentWdg = nullptr | ) |
◆ ~pqTabWidget()
| pqTabbedMultiViewWidget::pqTabWidget::~pqTabWidget |
◆ setTabButton()
| virtual void pqTabbedMultiViewWidget::pqTabWidget::setTabButton |
int |
index, |
QTabBar::ButtonPosition |
position, |
QWidget * |
wdg |
Set a button to use on the tab bar.
◆ tabButtonIndex()
| virtual int pqTabbedMultiViewWidget::pqTabWidget::tabButtonIndex |
QWidget * |
wdg, |
position |
| const |
Given the QWidget pointer that points to the buttons (popout or close) in the tabbar, this returns the index of that that the button corresponds to.
◆ addAsTab()
Add a pqTabbedMultiViewWidget instance as a new tab.
This will setup the appropriate tab-bar for this new tab (with 2 buttons for popout and close).
◆ popoutLabelText()
| static QString pqTabbedMultiViewWidget::pqTabWidget::popoutLabelText |
bool |
popped_out | ) |
◆ popoutLabelPixmap()
| static QStyle::StandardPixmap pqTabbedMultiViewWidget::pqTabWidget::popoutLabelPixmap |
bool |
popped_out | ) |
◆ setReadOnly()
| void pqTabbedMultiViewWidget::pqTabWidget::setReadOnly |
bool |
val | ) |
When true the widget disable changes to the tabs i.e adding/removing tabs by user interaction.
◆ readOnly()
| bool pqTabbedMultiViewWidget::pqTabWidget::readOnly |
const |
◆ preview()
| QSize pqTabbedMultiViewWidget::pqTabWidget::preview |
const QSize & |
◆ setTabBarVisibility()
| void pqTabbedMultiViewWidget::pqTabWidget::setTabBarVisibility |
bool |
Get/Set tab bar visibility.
Use this instead of directly calling this->tabBar()->setVisible() as that avoid interactions with preview mode.
◆ tabBarVisibility()
| bool pqTabbedMultiViewWidget::pqTabWidget::tabBarVisibility |
const |
Definition at line 272 of file pqTabbedMultiViewWidget.h.
◆ createViewSelectorTabIfNeeded()
| void pqTabbedMultiViewWidget::pqTabWidget::createViewSelectorTabIfNeeded |
int |
tabIndex | ) |
◆ pqTabbedMultiViewWidget
