pqTabbedMultiViewWidget is used to to enable adding of multiple pqMultiViewWidget instances in tabs.
#include <pqTabbedMultiViewWidget.h>
| bool | eventFilter (QObject *obj, QEvent *event) override |
This class directly listens to the server-manager to automatically create pqMultiViewWidget instances for every vtkSMViewLayoutProxy registered.
Definition at line 28 of file pqTabbedMultiViewWidget.h.
◆ pqTabbedMultiViewWidget()
| pqTabbedMultiViewWidget::pqTabbedMultiViewWidget |
QWidget * |
parent = nullptr | ) |
◆ ~pqTabbedMultiViewWidget()
| pqTabbedMultiViewWidget::~pqTabbedMultiViewWidget |
◆ clientSize()
| virtual QSize pqTabbedMultiViewWidget::clientSize |
const |
Returns the size for the tabs in the widget.
◆ setReadOnly()
| void pqTabbedMultiViewWidget::setReadOnly |
bool |
val | ) |
When set to true (off by default), the widget will not allow adding/removing tabs trough user interactions.
◆ readOnly()
| bool pqTabbedMultiViewWidget::readOnly |
const |
◆ setTabVisibility()
| void pqTabbedMultiViewWidget::setTabVisibility |
bool |
visible | ) |
Set the tab visibility.
To save some screen space when only one tab is needed, this can be set to false. True by default.
◆ tabVisibility()
| bool pqTabbedMultiViewWidget::tabVisibility |
const |
◆ layoutProxy()
Return the layout proxy for the current tab.
◆ decorationsVisibility()
| bool pqTabbedMultiViewWidget::decorationsVisibility |
const |
Returns whether frame decorations are shown.
◆ findTab()
◆ enableAnnotationFilter()
| void pqTabbedMultiViewWidget::enableAnnotationFilter |
const QString & |
annotationKey | ) |
◆ disableAnnotationFilter()
| void pqTabbedMultiViewWidget::disableAnnotationFilter |
◆ setAnnotationFilterMatching()
| void pqTabbedMultiViewWidget::setAnnotationFilterMatching |
bool |
matching | ) |
◆ updateVisibleTabs()
| void pqTabbedMultiViewWidget::updateVisibleTabs |
While generally not necessary to call this, if the annotations for the layout proxies are changed after they are created, applications can use this method to refresh the tabs that are visible.
◆ visibleTabLabels()
| QList<QString> pqTabbedMultiViewWidget::visibleTabLabels |
const |
This is primarily for testing purposes.
Returns list of names for visible tabs.
◆ viewSizeLocked
| void pqTabbedMultiViewWidget::viewSizeLocked |
bool |
signal |
◆ fullScreenEnabled
| void pqTabbedMultiViewWidget::fullScreenEnabled |
bool |
signal |
fired when toggleFullscreen() is called.
◆ fullScreenActiveViewEnabled
| void pqTabbedMultiViewWidget::fullScreenActiveViewEnabled |
bool |
signal |
◆ createTab [1/3]
| virtual int pqTabbedMultiViewWidget::createTab |
virtualslot |
◆ createTab [2/3]
pqServer * |
virtualslot |
◆ createTab [3/3]
◆ closeTab
| virtual void pqTabbedMultiViewWidget::closeTab |
int |
virtualslot |
◆ setCurrentTab
| void pqTabbedMultiViewWidget::setCurrentTab |
int |
index | ) |
slot |
Makes the tab at the given index current.
◆ setDecorationsVisibility
| void pqTabbedMultiViewWidget::setDecorationsVisibility |
bool |
slot |
When set to false, all decorations including title frames, separators, tab-bars are hidden.
◆ showDecorations
| void pqTabbedMultiViewWidget::showDecorations |
inlineslot |
Definition at line 128 of file pqTabbedMultiViewWidget.h.
◆ hideDecorations
| void pqTabbedMultiViewWidget::hideDecorations |
inlineslot |
Definition at line 129 of file pqTabbedMultiViewWidget.h.
◆ toggleFullScreen
| virtual void pqTabbedMultiViewWidget::toggleFullScreen |
virtualslot |
Toggle fullscreen state for the active multi-view widget.
All views contained in the active tab will be displayed fullscreen. Hide frame decorations, but they can still be shown afterward through the GUI.
◆ toggleFullScreenActiveView
| void pqTabbedMultiViewWidget::toggleFullScreenActiveView |
slot |
Toggle fullscreen state for active view only.
◆ toggleWidgetDecoration
| virtual void pqTabbedMultiViewWidget::toggleWidgetDecoration |
virtualslot |
toggles decoration visibility on the current widget
◆ lockViewSize
| virtual void pqTabbedMultiViewWidget::lockViewSize |
const QSize & |
virtualslot |
Locks the maximum size for each view-frame to the given size.
Use empty QSize() instance to indicate no limits.
◆ reset
| virtual void pqTabbedMultiViewWidget::reset |
virtualslot |
◆ preview
| QSize pqTabbedMultiViewWidget::preview |
const QSize & |
previewSize = QSize() | ) |
slot |
Enter (or exit) preview mode.
Preview mode is a mode were various widget's decorations are hidden and the widget is locked to the specified size. If the widget's current size is less than the size specified, then the widget is locked to a size with similar aspect ratio as requested. Pass in invalid (or empty) size to exit preview mode.
Preview mode is preferred over toggleWidgetDecoration and lockViewSize and is mutually exclusive with either. Mixing them can have unintended consequences.
- Returns
- the size to which the widget was locked. When unlocked, this will be QSize(QWIDGETSIZE_MAX, QWIDGETSIZE_MAX). When entering preview mode this will same as requested
previewSize or a smaller size preserving aspect ratio as much as possible.
◆ proxyAdded
| virtual void pqTabbedMultiViewWidget::proxyAdded |
pqProxy * |
protectedvirtualslot |
◆ proxyRemoved
| virtual void pqTabbedMultiViewWidget::proxyRemoved |
pqProxy * |
◆ serverRemoved
| virtual void pqTabbedMultiViewWidget::serverRemoved |
pqServer * |
◆ currentTabChanged
| virtual void pqTabbedMultiViewWidget::currentTabChanged |
int |
called when the active tab changes.
If the active tab is the "+" tab, then add a new tab to the widget.
◆ onStateLoaded
| virtual void pqTabbedMultiViewWidget::onStateLoaded |
verifies that all views loaded from state are indeed assigned to some view layout, or we just assign them to one.
◆ contextMenuRequested
| void pqTabbedMultiViewWidget::contextMenuRequested |
const QPoint & |
protectedslot |
called when context menu need to be created on the tab title.
◆ onLayoutNameChanged
◆ eventFilter()
| bool pqTabbedMultiViewWidget::eventFilter |
QObject * |
obj, |
QEvent * |
event |
◆ pqInternals
◆ readOnly
readwrite |
