Classes | Public Types | Public Slots | Signals | Public Member Functions | Protected Member Functions | List of all members
pqSpreadSheetViewModel Class Reference
#include <pqSpreadSheetViewModel.h>
Inherits QAbstractTableModel.
class  vtkIndex
enum  { SectionInternal = Qt::UserRole + 1, SectionVisible, SectionHeaderTemp }
Public Slots
void forceUpdate ()
 resets the model. More...
void setActiveRepresentation (pqDataRepresentation *)
 Sets the active representation. More...
void setActiveRepresentationProxy (vtkSMProxy *)
Signals
void selectionChanged (const QItemSelection &selection)
 Fired whenever the server side selection changes. More...
 pqSpreadSheetViewModel (vtkSMProxy *viewProxy, QObject *parent=nullptr)
 ~pqSpreadSheetViewModel () override
int rowCount (const QModelIndex &parent=QModelIndex()) const override
 Returns the number of rows. More...
int columnCount (const QModelIndex &parent=QModelIndex()) const override
 Returns the number of columns. More...
QVariant data (const QModelIndex &index, int role=Qt::DisplayRole) const override
 Returns the data storeed under the given role for the item referred by the index. More...
QVariant headerData (int section, Qt::Orientation orientation, int role=Qt::DisplayRole) const override
 Returns the data for the given role and section in the header with the specified orientation. More...
bool setHeaderData (int section, Qt::Orientation orientation, const QVariant &value, int role) override
 Allow to hide header label data using the SectionHeaderTemp role note: all other calls are passed to the parent class. More...
void sortSection (int section, Qt::SortOrder order)
 Make a server request to sort based on a given column with a given order. More...
bool isSortable (int section)
 Return true only if the given column is sortable. More...
int getFieldType () const
 Returns the field type for the data currently shown by this model. More...
QSet< vtkIndex > getVTKIndices (const QModelIndexList &indexes)
void setDecimalPrecision (int)
 Set/Get the decimal precision for float and double type data. More...
int getDecimalPrecision ()
void setFixedRepresentation (bool)
 Set/Get whether the decimal representation is fixed or scientific. More...
bool getFixedRepresentation ()
void setActiveRegion (int row_top, int row_bottom)
 set the region (in row indices) that is currently being shown in the view. More...
pqDataRepresentation * activeRepresentation () const
 Returns the active representation. More...
vtkSMProxy * activeRepresentationProxy () const
Qt::ItemFlags flags (const QModelIndex &index) const override
 Method needed for copy/past cell editor. More...
bool setData (const QModelIndex &index, const QVariant &value, int role=Qt::EditRole) override
QString GetRowsAsString () const
 Returns the current rows as a CSV-formatted string, including header with column names. More...
bool isDataValid (const QModelIndex &idx) const
 Given an index into the model, check to see that its row number is less than the length of the data array associated with its column. More...
vtkSpreadSheetView * GetView () const
Definition at line 29 of file pqSpreadSheetViewModel.h.
◆ anonymous enum
anonymous enum
Enumerator
SectionInternal
SectionVisible
SectionHeaderTemp
Definition at line 132 of file pqSpreadSheetViewModel.h.
◆ pqSpreadSheetViewModel()
pqSpreadSheetViewModel::pqSpreadSheetViewModel ( vtkSMProxy *  viewProxy,
QObject *  parent = nullptr
◆ ~pqSpreadSheetViewModel()
pqSpreadSheetViewModel::~pqSpreadSheetViewModel ( )
override
◆ rowCount()
int pqSpreadSheetViewModel::rowCount ( const QModelIndex &  parent = QModelIndex()) const
override
◆ columnCount()
int pqSpreadSheetViewModel::columnCount ( const QModelIndex &  parent = QModelIndex()) const
override
◆ data()
QVariant pqSpreadSheetViewModel::data ( const QModelIndex &  index,
int  role = Qt::DisplayRole
) const
override
◆ headerData()
QVariant pqSpreadSheetViewModel::headerData ( int  section,
) const
override
When orientation is Qt::Horizontal, pqSpreadSheetViewModel adds support for two new roles: pqSpreadSheetViewModel::SectionVisible, and pqSpreadSheetViewModel::SectionInternal. SectionVisible can be used to determine if the column (or horizontal section) is visible or hidden. SectionInternal is used to determine if the section is internal. An internal section is also hidden. When data associated with these two roles changes, the model will fire headerDataChanged signal.
◆ setHeaderData()
bool pqSpreadSheetViewModel::setHeaderData ( int  section,
const QVariant &  value,
int  role
override
◆ sortSection()
void pqSpreadSheetViewModel::sortSection ( int  section,
Qt::SortOrder  order
◆ isSortable()
bool pqSpreadSheetViewModel::isSortable ( int  section)
◆ getFieldType()
int pqSpreadSheetViewModel::getFieldType ( ) const
◆ getVTKIndices()
QSet<vtkIndex> pqSpreadSheetViewModel::getVTKIndices ( const QModelIndexList &  indexes)
◆ setDecimalPrecision()
void pqSpreadSheetViewModel::setDecimalPrecision ( int  )
◆ getDecimalPrecision()
int pqSpreadSheetViewModel::getDecimalPrecision ( )
◆ setFixedRepresentation()
void pqSpreadSheetViewModel::setFixedRepresentation ( bool  )
True is fixed and False is scientific
◆ getFixedRepresentation()
bool pqSpreadSheetViewModel::getFixedRepresentation ( )
◆ setActiveRegion()
void pqSpreadSheetViewModel::setActiveRegion ( int  row_top,
int  row_bottom
the model will provide data-values only for the active-region. For any other region it will simply return a "..." text for display (in QAbstractTableModel::data(..) callback).
◆ activeRepresentation()
pqDataRepresentation* pqSpreadSheetViewModel::activeRepresentation ( ) const
Active representation is the representation being shown by the view.
◆ activeRepresentationProxy()
vtkSMProxy* pqSpreadSheetViewModel::activeRepresentationProxy ( ) const
◆ flags()
Qt::ItemFlags pqSpreadSheetViewModel::flags ( const QModelIndex &  index) const
override
◆ setData()
bool pqSpreadSheetViewModel::setData ( const QModelIndex &  index,
int  role = Qt::EditRole
override
◆ GetRowsAsString()
QString pqSpreadSheetViewModel::GetRowsAsString ( ) const
Uses the vtkCSVExporter.
◆ forceUpdate
void pqSpreadSheetViewModel::forceUpdate ( )
slot
resets the model.
◆ setActiveRepresentation
void pqSpreadSheetViewModel::setActiveRepresentation ( pqDataRepresentation *  )
slot
◆ setActiveRepresentationProxy
void pqSpreadSheetViewModel::setActiveRepresentationProxy ( vtkSMProxy *  )
slot
When using this API instead of setActiveRepresentation(pqDataRepresentation*), some functionality won't be available.
◆ selectionChanged
void pqSpreadSheetViewModel::selectionChanged ( const QItemSelection &  selection)
signal
◆ isDataValid()
bool pqSpreadSheetViewModel::isDataValid ( const QModelIndex &  idx) const
◆ GetView()
vtkSpreadSheetView* pqSpreadSheetViewModel::GetView ( ) const
