| | pqComparativeXYChartView (const QString &group, const QString &name, vtkSMComparativeViewProxy *view, pqServer *server, QObject *parent=nullptr) |
| | ~pqComparativeXYChartView () override |
| | ~pqComparativeContextView () override |
| vtkContextView * | getVTKContextView () const override |
| vtkSMContextViewProxy * | getContextViewProxy () const override |
| | Returns the context view proxy associated with this object. More...
| vtkSMComparativeViewProxy * | getComparativeViewProxy () const |
| virtual vtkSMViewProxy * | getViewProxy () const |
| | Returns the proxy of the root plot view in the comparative view. More...
| | ~pqContextView () override |
| virtual bool | supportsSelection () const |
| | Returns true if selection can be done. More...
| bool | supportsCapture () const override |
| | Returns if this view module can support image capture. More...
| virtual void | setSelectionAction (int selAction) |
| | set/get the selection action in the context view, defined by vtkChart enumeration from SELECT to SELECT_POLYGON. More...
| virtual int | selectionAction () |
| void | resetDisplay (bool closest=false) override |
| | Resets the zoom level to 100%. More...
| | ~pqView () override |
| | Returns the internal render Module proxy associated with this object. More...
| virtual vtkView * | getClientSideView () const |
| | Return the client-side vtkView encapsulated by this view (if any), or return nullptr. More...
| QWidget * | widget () |
| | Return a widget associated with this view. More...
| virtual bool | supportsUndo () const |
| | Returns if this view module can support undo/redo. More...
| QString | getViewType () const |
| | Returns the type of this view module. More...
| virtual bool | canUndo () const |
| | Returns true if undo can be done. More...
| virtual bool | canRedo () const |
| | Returns true if redo can be done. More...
| virtual QSize | getSize () |
| | Returns the current size of the rendering context. More...
| bool | hasRepresentation (pqRepresentation *repr) const |
| | This method checks if the representation is shown in this view. More...
| int | getNumberOfRepresentations () const |
| | Returns the number representations in the view. More...
| int | getNumberOfVisibleRepresentations () const |
| int | getNumberOfVisibleDataRepresentations () const |
| pqRepresentation * | getRepresentation (int index) const |
| | Returns the representation for the specified index where (index < getNumberOfRepresentations()). More...
| QList< pqRepresentation * > | getRepresentations () const |
| | Returns a list of representations in this view. More...
| bool | canDisplay (pqOutputPort *opPort) const |
| | This method returns is any pqPipelineSource can be displayed in this view. More...
| | pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) |
| | ~pqProxy () override |
| | Get the server on which this proxy exists. More...
| | This is a convenience method. More...
| | Get the name with which this proxy is registered on the server manager. More...
| | Get the vtkSMProxy this object stands for. More...
| | Gets whether or not the source has been modified. More...
| | Sets whether or not the source has been modified. More...
| | Returns the hints for this proxy, if any. More...
| | Returns a list of all helper proxies. More...
| | Returns a list of all the helper proxies added with a given key. More...
| | Returns the keys for helper proxies. More...
| | Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
| | Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
| | Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
| | Return whether or not the user has modified the GUI name of the source. More...
| | pqServerManagerModelItem (QObject *parent=nullptr) |
| | ~pqServerManagerModelItem () override |
| enum | SelectionModifier { PV_SELECTION_DEFAULT = 0,
PV_SELECTION_ADDITION,
PV_SELECTION_SUBTRACTION,
PV_SELECTION_TOGGLE
| enum | ModifiedState { UNINITIALIZED,
MODIFIED,
UNMODIFIED
| | The modification state of this proxy. More...
| virtual void | render () |
| | Request a StillRender on idle. More...
| virtual void | forceRender () |
| | Forces an immediate render. More...
| void | cancelPendingRenders () |
| | Cancels any pending renders. More...
| virtual void | undo () |
| | Called to undo interaction. More...
| virtual void | redo () |
| | Called to redo interaction. More...
| void | updateDataEvent () |
| | Fired when the vtkSMViewProxy fires the vtkCommand::UpdateDataEvent The view proxy fires this event at the end of vtkSMViewProxy::Update() when the update executes, not just when the method is called. More...
| void | representationAdded (pqRepresentation *) |
| | Fired after a representation has been added to this view. More...
| void | representationRemoved (pqRepresentation *) |
| | Fired after a representation has been removed from this view. More...
| void | beginRender () |
| | Fired when the render module fires a vtkCommand::StartEvent signalling the beginning of rendering. More...
| void | endRender () |
| | Fired when the render module fires a vtkCommand::EndEvent signalling the end of rendering. More...
| void | representationVisibilityChanged (pqRepresentation *repr, bool visible) |
| | Fired when any representation visibility changes. More...
| void | canUndoChanged (bool) |
| | Fired when interaction undo stack status changes. More...
| void | canRedoChanged (bool) |
| void | selected (pqOutputPort *opport) |
| | Fired when a selection is made in this view. More...
| void | picked (pqOutputPort *opport) |
| | Fired when a port is picked. More...
| void | beginProgress () |
| | Fired before doing any actions that may result in progress events that must be reported by the client. More...
| void | endProgress () |
| | Fired after performing any actions that may result in progress events. More...
| void | progress (const QString &message, int percent_progress) |
| | Fired to notify the current execution progress. More...
| void | multipleSelected (QList< pqOutputPort *> opports) |
| | Fired when UseMultipleRepresentationSelection is set to on and selection on multiple representations is made in this view. More...
| void | nameChanged (pqServerManagerModelItem *) |
| | Fired when the name of the proxy is changed. More...
| void | modifiedStateChanged (pqServerManagerModelItem *) |
| | Fired when the modified status changes for the proxy. More...
| void | updateViewWidgets () |
| | Called when the layout on the comparative vis changes. More...
| void | startInteraction () |
| | Slots called when vtkCommand::StartInteractionEvent and vtkCommand::EndInteractionEvent are fired by vtkSMContextViewProxy. More...
| void | endInteraction () |
| void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
| void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
| QWidget * | createWidget () override |
| | Create the QWidget for this view. More...
| | pqComparativeContextView (const QString &type, const QString &group, const QString &name, vtkSMComparativeViewProxy *view, pqServer *server, QObject *parent=nullptr) |
| | Constructor: type :- view type. More...
| | pqContextView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr) |
| | Creates a new instance of the QWidget subclass to be used to show this view. More...
| virtual void | selectionChanged () |
| | Listen for new selection events, and pass them back to ParaView. More...
| virtual void | setSelection (vtkSelection *) |
| | Set selection to the view. More...
| | pqView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr) |
| void | initialize () override |
| | Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
| | Make this pqProxy take on a new identity. More...
| | All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
| QPointer< QWidget > | Widget |
| command * | Command |
The comparative line chart subclass.
Definition at line 12 of file pqComparativeXYChartView.h.
