#include <vtkPVMessage.pb.h>
Inherits Message.
| enum | : int { kVariantFieldNumber = 2, kKeyFieldNumber = 1 } |
| ProxyState_UserData () | |
| ~ProxyState_UserData () override | |
| constexpr | ProxyState_UserData (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized) |
| ProxyState_UserData (const ProxyState_UserData &from) | |
| ProxyState_UserData (ProxyState_UserData &&from) noexcept | |
| ProxyState_UserData & | operator= (const ProxyState_UserData &from) |
| ProxyState_UserData & | operator= (ProxyState_UserData &&from) noexcept |
| const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & | unknown_fields () const |
| inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * | mutable_unknown_fields () |
| void | Swap (ProxyState_UserData *other) |
| void | UnsafeArenaSwap (ProxyState_UserData *other) |
| ProxyState_UserData * | New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final |
| void | CopyFrom (const ProxyState_UserData &from) |
| void | MergeFrom (const ProxyState_UserData &from) |
| PROTOBUF_ATTRIBUTE_REINITIALIZES void | Clear () final |
| bool | IsInitialized () const final |
| size_t | ByteSizeLong () const final |
| const char * | _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final |
| uint8_t * | _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final |
| int | GetCachedSize () const final |
| const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * | GetClassData () const final |
| ::PROTOBUF_NAMESPACE_ID::Metadata | GetMetadata () const final |
| int | variant_size () const |
| void | clear_variant () |
| ::paraview_protobuf::Variant * | mutable_variant (int index) |
| ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Variant > * | mutable_variant () |
| const ::paraview_protobuf::Variant & | variant (int index) const |
| ::paraview_protobuf::Variant * | add_variant () |
| const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< ::paraview_protobuf::Variant > & | variant () const |
| bool | has_key () const |
| void | clear_key () |
| const std::string & | key () const |
| template<typename ArgT0 = const std::string&, typename... ArgT> | |
| void | set_key (ArgT0 &&arg0, ArgT... args) |
| std::string * | mutable_key () |
| PROTOBUF_NODISCARD std::string * | release_key () |
| void | set_allocated_key (std::string *key) |
| template<typename ArgT0 , typename... ArgT> | |
| PROTOBUF_ALWAYS_INLINE void | set_key (ArgT0 &&arg0, ArgT... args) |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | descriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | GetDescriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Reflection * | GetReflection () |
| static const ProxyState_UserData & | default_instance () |
| static const ProxyState_UserData * | internal_default_instance () |
Static Public Attributes | |
| static constexpr int | kIndexInFileMessages |
| static const ClassData | _class_data_ |
| ProxyState_UserData (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false) | |
Friends | |
| class | ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata |
| template<typename T > | |
| class | ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper |
| struct | ::TableStruct_vtkPVMessage_2eproto |
| void | swap (ProxyState_UserData &a, ProxyState_UserData &b) |
Definition at line 1871 of file vtkPVMessage.pb.h.
| anonymous enum : int |
| Enumerator | |
| kVariantFieldNumber | |
| kKeyFieldNumber | |
Definition at line 1999 of file vtkPVMessage.pb.h.
Definition at line 1874 of file vtkPVMessage.pb.h.
explicit |
| paraview_protobuf::ProxyState_UserData::ProxyState_UserData | ( | const ProxyState_UserData & | from | ) |
inlinenoexcept |
Definition at line 1879 of file vtkPVMessage.pb.h.
explicitprotected |
Definition at line 1884 of file vtkPVMessage.pb.h.
inlinenoexcept |
Definition at line 1888 of file vtkPVMessage.pb.h.
Definition at line 1902 of file vtkPVMessage.pb.h.
Definition at line 1905 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1909 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1912 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1915 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1918 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1921 of file vtkPVMessage.pb.h.
Definition at line 1931 of file vtkPVMessage.pb.h.
Definition at line 1944 of file vtkPVMessage.pb.h.
inlinefinal |
Definition at line 1952 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ProxyState_UserData::CopyFrom | ( | const ProxyState_UserData & | from | ) |
| void paraview_protobuf::ProxyState_UserData::MergeFrom | ( | const ProxyState_UserData & | from | ) |
final |
final |
final |
final |
final |
inlinefinal |
Definition at line 1969 of file vtkPVMessage.pb.h.
final |
final |
Definition at line 5703 of file vtkPVMessage.pb.h.
Definition at line 5706 of file vtkPVMessage.pb.h.
Definition at line 5709 of file vtkPVMessage.pb.h.
Definition at line 5714 of file vtkPVMessage.pb.h.
Definition at line 5721 of file vtkPVMessage.pb.h.
Definition at line 5728 of file vtkPVMessage.pb.h.
Definition at line 5734 of file vtkPVMessage.pb.h.
Definition at line 5635 of file vtkPVMessage.pb.h.
Definition at line 5638 of file vtkPVMessage.pb.h.
Definition at line 5642 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ProxyState_UserData::set_key | ( | ArgT0 && | arg0, |
| ArgT... | args | ||
Definition at line 5653 of file vtkPVMessage.pb.h.
Definition at line 5669 of file vtkPVMessage.pb.h.
Definition at line 5683 of file vtkPVMessage.pb.h.
Definition at line 5648 of file vtkPVMessage.pb.h.
friend |
Definition at line 1978 of file vtkPVMessage.pb.h.
friend |
Definition at line 2041 of file vtkPVMessage.pb.h.
friend |
Definition at line 2050 of file vtkPVMessage.pb.h.
friend |
Definition at line 1928 of file vtkPVMessage.pb.h.
Definition at line 1925 of file vtkPVMessage.pb.h.
Definition at line 1990 of file vtkPVMessage.pb.h.
1.8.13 on Fri Aug 28 2026
