#include <vtkPVMessage.pb.h>
Inherits Message.
| enum | : int { kIdtypeFieldNumber = 3, kIntegerFieldNumber = 4, kFloat64FieldNumber = 5, kProxyGlobalIdFieldNumber = 6, kPortNumberFieldNumber = 7, kTxtFieldNumber = 8, kBinaryFieldNumber = 9, kTypeFieldNumber = 1 } |
| typedef Variant_Type | Type |
| Variant () | |
| ~Variant () override | |
| constexpr | Variant (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized) |
| Variant (const Variant &from) | |
| Variant (Variant &&from) noexcept | |
| Variant & | operator= (const Variant &from) |
| Variant & | operator= (Variant &&from) noexcept |
| const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & | unknown_fields () const |
| inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * | mutable_unknown_fields () |
| void | Swap (Variant *other) |
| void | UnsafeArenaSwap (Variant *other) |
| Variant * | New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final |
| void | CopyFrom (const Variant &from) |
| void | MergeFrom (const Variant &from) |
| PROTOBUF_ATTRIBUTE_REINITIALIZES void | Clear () final |
| bool | IsInitialized () const final |
| size_t | ByteSizeLong () const final |
| const char * | _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final |
| uint8_t * | _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final |
| int | GetCachedSize () const final |
| const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * | GetClassData () const final |
| ::PROTOBUF_NAMESPACE_ID::Metadata | GetMetadata () const final |
| int | idtype_size () const |
| void | clear_idtype () |
| int64_t | idtype (int index) const |
| void | set_idtype (int index, int64_t value) |
| void | add_idtype (int64_t value) |
| const ::PROTOBUF_NAMESPACE_ID::RepeatedField< int64_t > & | idtype () const |
| ::PROTOBUF_NAMESPACE_ID::RepeatedField< int64_t > * | mutable_idtype () |
| int | integer_size () const |
| void | clear_integer () |
| int32_t | integer (int index) const |
| void | set_integer (int index, int32_t value) |
| void | add_integer (int32_t value) |
| const ::PROTOBUF_NAMESPACE_ID::RepeatedField< int32_t > & | integer () const |
| ::PROTOBUF_NAMESPACE_ID::RepeatedField< int32_t > * | mutable_integer () |
| int | float64_size () const |
| void | clear_float64 () |
| double | float64 (int index) const |
| void | set_float64 (int index, double value) |
| void | add_float64 (double value) |
| const ::PROTOBUF_NAMESPACE_ID::RepeatedField< double > & | float64 () const |
| ::PROTOBUF_NAMESPACE_ID::RepeatedField< double > * | mutable_float64 () |
| int | proxy_global_id_size () const |
| void | clear_proxy_global_id () |
| uint64_t | proxy_global_id (int index) const |
| void | set_proxy_global_id (int index, uint64_t value) |
| void | add_proxy_global_id (uint64_t value) |
| const ::PROTOBUF_NAMESPACE_ID::RepeatedField< uint64_t > & | proxy_global_id () const |
| ::PROTOBUF_NAMESPACE_ID::RepeatedField< uint64_t > * | mutable_proxy_global_id () |
| int | port_number_size () const |
| void | clear_port_number () |
| int32_t | port_number (int index) const |
| void | set_port_number (int index, int32_t value) |
| void | add_port_number (int32_t value) |
| const ::PROTOBUF_NAMESPACE_ID::RepeatedField< int32_t > & | port_number () const |
| ::PROTOBUF_NAMESPACE_ID::RepeatedField< int32_t > * | mutable_port_number () |
| int | txt_size () const |
| void | clear_txt () |
| const std::string & | txt (int index) const |
| std::string * | mutable_txt (int index) |
| void | set_txt (int index, const std::string &value) |
| void | set_txt (int index, std::string &&value) |
| void | set_txt (int index, const char *value) |
| void | set_txt (int index, const char *value, size_t size) |
| std::string * | add_txt () |
| void | add_txt (const std::string &value) |
| void | add_txt (std::string &&value) |
| void | add_txt (const char *value) |
| void | add_txt (const char *value, size_t size) |
| const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< std::string > & | txt () const |
| ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< std::string > * | mutable_txt () |
| int | binary_size () const |
| void | clear_binary () |
| const std::string & | binary (int index) const |
| std::string * | mutable_binary (int index) |
| void | set_binary (int index, const std::string &value) |
| void | set_binary (int index, std::string &&value) |
| void | set_binary (int index, const char *value) |
| void | set_binary (int index, const void *value, size_t size) |
| std::string * | add_binary () |
| void | add_binary (const std::string &value) |
| void | add_binary (std::string &&value) |
| void | add_binary (const char *value) |
| void | add_binary (const void *value, size_t size) |
| const ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< std::string > & | binary () const |
| ::PROTOBUF_NAMESPACE_ID::RepeatedPtrField< std::string > * | mutable_binary () |
| bool | has_type () const |
| void | clear_type () |
| ::paraview_protobuf::Variant_Type | type () const |
| void | set_type (::paraview_protobuf::Variant_Type value) |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | descriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | GetDescriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Reflection * | GetReflection () |
| static const Variant & | default_instance () |
| static const Variant * | internal_default_instance () |
| static bool | Type_IsValid (int value) |
| static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * | Type_descriptor () |
| template<typename T > | |
| static const std::string & | Type_Name (T enum_t_value) |
| static bool | Type_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, Type *value) |
Static Public Attributes | |
| static constexpr int | kIndexInFileMessages |
| static const ClassData | _class_data_ |
| static constexpr Type | INT |
| static constexpr Type | FLOAT64 |
| static constexpr Type | IDTYPE |
| static constexpr Type | STRING |
| static constexpr Type | PROXY |
| static constexpr Type | INPUT |
| static constexpr Type | BYTES |
| static constexpr Type | MAP |
| static constexpr Type | Type_MIN |
| static constexpr Type | Type_MAX |
| static constexpr int | Type_ARRAYSIZE |
| Variant (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false) | |
Friends | |
| class | ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata |
| class | ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper |
| struct | ::TableStruct_vtkPVMessage_2eproto |
| void | swap (Variant &a, Variant &b) |
Definition at line 262 of file vtkPVMessage.pb.h.
Definition at line 388 of file vtkPVMessage.pb.h.
| anonymous enum : int |
| Enumerator | |
| kIdtypeFieldNumber | |
| kIntegerFieldNumber | |
| kFloat64FieldNumber | |
| kProxyGlobalIdFieldNumber | |
| kPortNumberFieldNumber | |
| kTxtFieldNumber | |
| kBinaryFieldNumber | |
| kTypeFieldNumber | |
Definition at line 432 of file vtkPVMessage.pb.h.
Definition at line 265 of file vtkPVMessage.pb.h.
explicit |
inlinenoexcept |
Definition at line 270 of file vtkPVMessage.pb.h.
explicitprotected |
Definition at line 275 of file vtkPVMessage.pb.h.
Definition at line 279 of file vtkPVMessage.pb.h.
Definition at line 293 of file vtkPVMessage.pb.h.
Definition at line 296 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 300 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 303 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 306 of file vtkPVMessage.pb.h.
Definition at line 309 of file vtkPVMessage.pb.h.
Definition at line 312 of file vtkPVMessage.pb.h.
Definition at line 322 of file vtkPVMessage.pb.h.
Definition at line 335 of file vtkPVMessage.pb.h.
inlinefinal |
Definition at line 343 of file vtkPVMessage.pb.h.
final |
final |
final |
final |
final |
inlinefinal |
Definition at line 360 of file vtkPVMessage.pb.h.
final |
final |
inlinestatic |
Definition at line 405 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 415 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 419 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 425 of file vtkPVMessage.pb.h.
Definition at line 4766 of file vtkPVMessage.pb.h.
Definition at line 4769 of file vtkPVMessage.pb.h.
Definition at line 4775 of file vtkPVMessage.pb.h.
Definition at line 4779 of file vtkPVMessage.pb.h.
Definition at line 4786 of file vtkPVMessage.pb.h.
Definition at line 4795 of file vtkPVMessage.pb.h.
Definition at line 4804 of file vtkPVMessage.pb.h.
Definition at line 4813 of file vtkPVMessage.pb.h.
Definition at line 4816 of file vtkPVMessage.pb.h.
Definition at line 4822 of file vtkPVMessage.pb.h.
Definition at line 4826 of file vtkPVMessage.pb.h.
Definition at line 4833 of file vtkPVMessage.pb.h.
Definition at line 4842 of file vtkPVMessage.pb.h.
Definition at line 4851 of file vtkPVMessage.pb.h.
Definition at line 4860 of file vtkPVMessage.pb.h.
Definition at line 4863 of file vtkPVMessage.pb.h.
Definition at line 4869 of file vtkPVMessage.pb.h.
Definition at line 4873 of file vtkPVMessage.pb.h.
Definition at line 4880 of file vtkPVMessage.pb.h.
Definition at line 4889 of file vtkPVMessage.pb.h.
Definition at line 4898 of file vtkPVMessage.pb.h.
Definition at line 4907 of file vtkPVMessage.pb.h.
Definition at line 4910 of file vtkPVMessage.pb.h.
Definition at line 4916 of file vtkPVMessage.pb.h.
Definition at line 4920 of file vtkPVMessage.pb.h.
Definition at line 4927 of file vtkPVMessage.pb.h.
Definition at line 4936 of file vtkPVMessage.pb.h.
Definition at line 4945 of file vtkPVMessage.pb.h.
Definition at line 4954 of file vtkPVMessage.pb.h.
Definition at line 4957 of file vtkPVMessage.pb.h.
Definition at line 4963 of file vtkPVMessage.pb.h.
Definition at line 4967 of file vtkPVMessage.pb.h.
Definition at line 4974 of file vtkPVMessage.pb.h.
Definition at line 4983 of file vtkPVMessage.pb.h.
Definition at line 4992 of file vtkPVMessage.pb.h.
Definition at line 5001 of file vtkPVMessage.pb.h.
Definition at line 5004 of file vtkPVMessage.pb.h.
Definition at line 5015 of file vtkPVMessage.pb.h.
Definition at line 5019 of file vtkPVMessage.pb.h.
Definition at line 5023 of file vtkPVMessage.pb.h.
Definition at line 5027 of file vtkPVMessage.pb.h.
Definition at line 5031 of file vtkPVMessage.pb.h.
Definition at line 5036 of file vtkPVMessage.pb.h.
Definition at line 5007 of file vtkPVMessage.pb.h.
Definition at line 5044 of file vtkPVMessage.pb.h.
Definition at line 5048 of file vtkPVMessage.pb.h.
Definition at line 5052 of file vtkPVMessage.pb.h.
Definition at line 5057 of file vtkPVMessage.pb.h.
Definition at line 5062 of file vtkPVMessage.pb.h.
Definition at line 5067 of file vtkPVMessage.pb.h.
Definition at line 5076 of file vtkPVMessage.pb.h.
Definition at line 5079 of file vtkPVMessage.pb.h.
Definition at line 5090 of file vtkPVMessage.pb.h.
Definition at line 5094 of file vtkPVMessage.pb.h.
Definition at line 5098 of file vtkPVMessage.pb.h.
Definition at line 5102 of file vtkPVMessage.pb.h.
Definition at line 5106 of file vtkPVMessage.pb.h.
Definition at line 5111 of file vtkPVMessage.pb.h.
Definition at line 5082 of file vtkPVMessage.pb.h.
Definition at line 5119 of file vtkPVMessage.pb.h.
Definition at line 5123 of file vtkPVMessage.pb.h.
Definition at line 5127 of file vtkPVMessage.pb.h.
Definition at line 5132 of file vtkPVMessage.pb.h.
Definition at line 5137 of file vtkPVMessage.pb.h.
Definition at line 5142 of file vtkPVMessage.pb.h.
Definition at line 4738 of file vtkPVMessage.pb.h.
Definition at line 4741 of file vtkPVMessage.pb.h.
Definition at line 4748 of file vtkPVMessage.pb.h.
Definition at line 4757 of file vtkPVMessage.pb.h.
friend |
Definition at line 369 of file vtkPVMessage.pb.h.
friend |
Definition at line 615 of file vtkPVMessage.pb.h.
friend |
Definition at line 630 of file vtkPVMessage.pb.h.
Definition at line 319 of file vtkPVMessage.pb.h.
Definition at line 316 of file vtkPVMessage.pb.h.
Definition at line 381 of file vtkPVMessage.pb.h.
Definition at line 389 of file vtkPVMessage.pb.h.
Definition at line 391 of file vtkPVMessage.pb.h.
Definition at line 393 of file vtkPVMessage.pb.h.
Definition at line 395 of file vtkPVMessage.pb.h.
Definition at line 397 of file vtkPVMessage.pb.h.
Definition at line 399 of file vtkPVMessage.pb.h.
Definition at line 401 of file vtkPVMessage.pb.h.
Definition at line 403 of file vtkPVMessage.pb.h.
Definition at line 408 of file vtkPVMessage.pb.h.
Definition at line 410 of file vtkPVMessage.pb.h.
Definition at line 412 of file vtkPVMessage.pb.h.
1.8.13 on Sat Oct 10 2026
