vtkSMGL2PSExporterProxy Class Reference
Proxy for vtkPVGL2PSExporter. More...
#include <vtkSMGL2PSExporterProxy.h>
Inheritance diagram for vtkSMGL2PSExporterProxy:
Collaboration diagram for vtkSMGL2PSExporterProxy:
typedef vtkSMRenderViewExporterProxy Superclass
- Public Types inherited from vtkSMRenderViewExporterProxy
typedef vtkSMExporterProxy Superclass
- Public Types inherited from vtkSMExporterProxy
typedef vtkSMProxy Superclass
bool CanExport (vtkSMProxy *) override
 Returns if the view can be exported. More...
void Write () override
 Export the current view. More...
 See superclass documentation for description. More...
- Public Member Functions inherited from vtkSMRenderViewExporterProxy
 Exports the view. More...
void SetView (vtkSMViewProxy *view) override
 Set the view used for export, and update all domains based on prop extraction using the view. More...
- Public Member Functions inherited from vtkSMExporterProxy
virtual vtkSMViewProxy * GetView ()
 Set the view proxy to export. More...
const std::vector< std::string > & GetFileExtensions () const
 Returns the suggested file extensions for this exporter. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMGL2PSExporterProxy * New ()
static vtkSMGL2PSExporterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMRenderViewExporterProxy
static vtkSMRenderViewExporterProxy * New ()
static vtkSMRenderViewExporterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExporterProxy
static vtkSMExporterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMGL2PSExporterProxy ()
 ~vtkSMGL2PSExporterProxy () override
- Protected Member Functions inherited from vtkSMRenderViewExporterProxy
 vtkSMRenderViewExporterProxy ()
 ~vtkSMRenderViewExporterProxy () override
- Protected Member Functions inherited from vtkSMExporterProxy
 vtkSMExporterProxy ()
 ~vtkSMExporterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
enum  { None, ContextView, RenderView }
 Type of view that this exporter is configured to export. More...
int ViewType
- Protected Attributes inherited from vtkSMExporterProxy
vtkSMViewProxy * View
std::vector< std::string > FileExtensions
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Definition at line 16 of file vtkSMGL2PSExporterProxy.h.
Definition at line 20 of file vtkSMGL2PSExporterProxy.h.
◆ anonymous enum
anonymous enum
Enumerator
None
ContextView
RenderView
Definition at line 48 of file vtkSMGL2PSExporterProxy.h.
◆ vtkSMGL2PSExporterProxy()
vtkSMGL2PSExporterProxy::vtkSMGL2PSExporterProxy ( )
◆ ~vtkSMGL2PSExporterProxy()
vtkSMGL2PSExporterProxy::~vtkSMGL2PSExporterProxy ( )
static vtkSMGL2PSExporterProxy* vtkSMGL2PSExporterProxy::New ( )
virtual const char* vtkSMGL2PSExporterProxy::GetClassName ( )
Reimplemented from vtkSMRenderViewExporterProxy.
static int vtkSMGL2PSExporterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMGL2PSExporterProxy::IsA ( const char *  type)
static vtkSMGL2PSExporterProxy* vtkSMGL2PSExporterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMGL2PSExporterProxy::PrintSelf ( ostream &  os,
Reimplemented from vtkSMExporterProxy.
◆ CanExport()
bool vtkSMGL2PSExporterProxy::CanExport ( vtkSMProxy *  )
Default implementation return true if the view is a render view or a context view.
Implements vtkSMExporterProxy.
◆ Write()
void vtkSMGL2PSExporterProxy::Write ( )
◆ ReadXMLAttributes()
int vtkSMGL2PSExporterProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
vtkPVXMLElement *  element
◆ ViewType
int vtkSMGL2PSExporterProxy::ViewType
Definition at line 54 of file vtkSMGL2PSExporterProxy.h.
