| 0007174 | ParaView | (No Category) | public | 2008-06-08 14:27 | 2009-05-13 13:59 | ||||
| Reporter | Berk Geveci | ||||||||
| Priority | high | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | ||||||
| Summary | 0007174: Selection does not work in parallel if compositing is off | ||||||||
| Description | Since selection requires compositing, it should try to use it even if the user turned it off. If ParaView detected that compositing is not available (i.e. vtkPVDisplayInformation reports no display with CanOpenDisplay false), it should report an error to the user. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0012316) Utkarsh Ayachit (administrator) 2008-06-11 08:53 |
Unless limited by hardware i.e DISPLAY setting or color depth etc., selection will always automatically result in a remote render. Hence, even if the user manually disabled remote rendering, we'd still be able to do remote renders for sake of selection. For now, I am simply raising vtkErrorMacro() errors if remote rendering is not possible due to DISPLAY issues etc. When BUG 0006539 is fixed, the selection toolbar buttons will be disabled when selection is not possible at all. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderViewProxy.cxx,v <-- Servers/ServerManager/vtkSMRenderViewProxy.cxx new revision: 1.70; previous revision: 1.69 |
(0012380) Alan Scott (manager) 2008-06-17 15:53 |
Tested client/server |
| Notes |
| Issue History | |||
| 2008-06-08 14:27 | Berk Geveci | New Issue | |
| 2008-06-08 14:27 | Berk Geveci | Status | backlog => tabled |
| 2008-06-08 14:27 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
| 2008-06-11 08:50 | Utkarsh Ayachit | Relationship added | related to 0006539 |
| 2008-06-11 08:53 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-06-11 08:53 | Utkarsh Ayachit | Resolution | open => fixed |
| 2008-06-11 08:53 | Utkarsh Ayachit | Note Added: 0012316 | |
| 2008-06-17 15:53 | Alan Scott | Status | @80@ => closed |
| 2008-06-17 15:53 | Alan Scott | Note Added: 0012380 | |
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 |
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
