MantisBT - ParaView
View Issue Details
0007174ParaView(No Category)public2008-06-08 14:272009-05-13 13:59
Berk Geveci
Utkarsh Ayachit
highminoralways
closedfixed
3.43.4
0007174: Selection does not work in parallel if compositing is off
Since selection requires compositing, it should try to use it even if the user turned it off. If ParaView detected that compositing is not available (i.e. vtkPVDisplayInformation reports no display with CanOpenDisplay false), it should report an error to the user.
No tags attached.
related to 0006539closed Utkarsh Ayachit Disable selection GUI when not appropriate
Issue History
2008-06-08 14:27Berk GeveciNew Issue
2008-06-08 14:27Berk GeveciStatusbacklog => tabled
2008-06-08 14:27Berk GeveciAssigned To => Utkarsh Ayachit
2008-06-11 08:50Utkarsh AyachitRelationship addedrelated to 0006539
2008-06-11 08:53Utkarsh AyachitStatustabled => @80@
2008-06-11 08:53Utkarsh AyachitResolutionopen => fixed
2008-06-11 08:53Utkarsh AyachitNote Added: 0012316
2008-06-17 15:53Alan ScottStatus@80@ => closed
2008-06-17 15:53Alan ScottNote Added: 0012380
2009-05-13 13:58Utkarsh AyachitTarget Version => 3.4
2009-05-13 13:59Utkarsh AyachitFixed in Version => 3.4
2011-06-16 13:10Zack GalbreathCategory => (No Category)
Notes
(0012316)
Utkarsh Ayachit
2008-06-11 08:53
Unless limited by hardware i.e DISPLAY setting or color depth etc., selection will always automatically result in a remote render. Hence, even if the user manually disabled remote rendering, we'd still be able to do remote renders for sake of selection.
For now, I am simply raising vtkErrorMacro() errors if remote rendering is not possible due to DISPLAY issues etc. When BUG 0006539 is fixed, the selection toolbar buttons will be disabled when selection is not possible at all.
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderViewProxy.cxx,v <-- Servers/ServerManager/vtkSMRenderViewProxy.cxx
new revision: 1.70; previous revision: 1.69
(0012380)
Alan Scott
2008-06-17 15:53
Tested client/server
