| 0007110 | ParaView | (No Category) | public | 2008-05-28 08:44 | 2009-05-13 13:59 | ||||
| Reporter | Ken Moreland | ||||||||
| Product Version | |||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | ||||||
| Summary | 0007110: Component selector on toolbar does not change color range | ||||||||
| Description | When you are viewing a vector as colors on a surface and change the component that you are showing from the toolbar or display panel, the range of colors is not properly updated. To replicate: 1. Load disk_out_ref. Turn on all variables. 2. Select V as the scalars to color by (component=Magnitude). 3. Turn on the color bar visibility. Note the range (0:22.4). 4. Change the component of the vector to 0 using either the toolbar or the display panel. The range changes to -19.95:22.42. 5. Change the component back to Magnitude. The range remains at -19.95:22.42. If you go to the color scale editor dialog box and change the component from there, the range updates properly. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0012425) Utkarsh Ayachit (administrator) 2008-06-19 16:31 |
Fixed BUG 0007110 and BUG 0007109. The component selector on the toolbar now affects the scalar bar titles as well as lut ranges correctly. /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- Qt/Components/pqColorScaleEditor.cxx new revision: 1.46; previous revision: 1.45 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.cxx,v <-- Qt/Components/pqDisplayColorWidget.cxx new revision: 1.32; previous revision: 1.31 /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarBarRepresentation.cxx,v <-- Qt/Core/pqScalarBarRepresentation.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarsToColors.cxx,v <-- Qt/Core/pqScalarsToColors.cxx new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarsToColors.h,v <-- Qt/Core/pqScalarsToColors.h new revision: 1.15; previous revision: 1.14 |
(0012486) Alan Scott (manager) 2008-06-23 21:13 |
Tested client/server |
| Notes |
| Issue History | |||
| 2008-05-28 08:44 | Ken Moreland | New Issue | |
| 2008-05-28 08:44 | Ken Moreland | Status | backlog => tabled |
| 2008-05-28 08:44 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
| 2008-05-28 08:45 | Ken Moreland | Relationship added | related to 0007109 |
| 2008-06-19 16:31 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-06-19 16:31 | Utkarsh Ayachit | Resolution | open => fixed |
| 2008-06-19 16:32 | Utkarsh Ayachit | Note Added: 0012425 | |
| 2008-06-23 21:13 | Alan Scott | Status | @80@ => closed |
| 2008-06-23 21:13 | Alan Scott | Note Added: 0012486 | |
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 |
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
