MantisBT - ParaView | ||||||||||
| View Issue Details | ||||||||||
| ID | Project | Category | View Status | Date Submitted | Last Update | |||||
| 0007110 | ParaView | (No Category) | public | 2008-05-28 08:44 | 2009-05-13 13:59 | |||||
| Reporter | Ken Moreland | |||||||||
| Assigned To | Utkarsh Ayachit | |||||||||
| Priority | normal | Severity | minor | Reproducibility | have not tried | |||||
| Status | closed | Resolution | fixed | |||||||
| Platform | OS | OS Version | ||||||||
| Product Version | ||||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | |||||||
| Project | ||||||||||
| Topic Name | ||||||||||
| Type | ||||||||||
| Summary | 0007110: Component selector on toolbar does not change color range | |||||||||
| Description | When you are viewing a vector as colors on a surface and change the component that you are showing from the toolbar or display panel, the range of colors is not properly updated. To replicate: 1. Load disk_out_ref. Turn on all variables. 2. Select V as the scalars to color by (component=Magnitude). 3. Turn on the color bar visibility. Note the range (0:22.4). 4. Change the component of the vector to 0 using either the toolbar or the display panel. The range changes to -19.95:22.42. 5. Change the component back to Magnitude. The range remains at -19.95:22.42. If you go to the color scale editor dialog box and change the component from there, the range updates properly. | |||||||||
| Steps To Reproduce | ||||||||||
| Additional Information | ||||||||||
| Tags | No tags attached. | |||||||||
| Relationships |
| Attached Files | ||||||||||
| Issue History | ||||||||||
| Date Modified | Username | Field | Change | |||||||
| 2008-05-28 08:44 | Ken Moreland | New Issue | ||||||||
| 2008-05-28 08:44 | Ken Moreland | Status | backlog => tabled | |||||||
| 2008-05-28 08:44 | Ken Moreland | Assigned To | => Utkarsh Ayachit | |||||||
| 2008-05-28 08:45 | Ken Moreland | Relationship added | related to 0007109 | |||||||
| 2008-06-19 16:31 | Utkarsh Ayachit | Status | tabled => @80@ | |||||||
| 2008-06-19 16:31 | Utkarsh Ayachit | Resolution | open => fixed | |||||||
| 2008-06-19 16:32 | Utkarsh Ayachit | Note Added: 0012425 | ||||||||
| 2008-06-23 21:13 | Alan Scott | Status | @80@ => closed | |||||||
| 2008-06-23 21:13 | Alan Scott | Note Added: 0012486 | ||||||||
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 | |||||||
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 | |||||||
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) | |||||||
| Notes | |||||
