| 0006695 | ParaView | (No Category) | public | 2008-04-01 12:04 | 2009-05-13 13:46 | ||||
| Reporter | Ken Moreland | ||||||||
| Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
| Product Version | |||||||||
| Target Version | 3.6 | Fixed in Version | |||||||
| Summary | 0006695: Change "foreground" color | ||||||||
| Description | You can change the background color on a view (at least a 3D view) but not the "foreground" color. Instead, ParaView implicitly assumes that all foreground elements, things like text and lines in 3D widgets and outlines, should be white. If the user wants a white background, then these foreground elements are invisible until their color is changed one-by-one. 3D views should have add added concept of a "foreground" color. These foreground elements should, by default, follow the foreground color. This means that if the foreground color is changed, the color of all the text, for example, should also change (unless the user set it to something else). | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||||||||||||||||||||||
| Relationships |
| Notes | |
(0012021) Ken Moreland (manager) 2008-05-20 09:26 |
You should also be able to save the foreground color between sessions in the same way that the background color is saved. |
(0015386) Utkarsh Ayachit (administrator) 2009-02-25 14:18 |
Adding notion of "global properties" which can be edited from application settings. Solid color etc. can be set as one of the global properties and then when one changes the global properties, it changes all objects that are linked to it. Currently only colors are provided as global properties but can be extended to other types such as line thickness etc. /cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorButton.cxx,v <-- Qt/Components/pqStandardColorButton.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorButton.h,v <-- Qt/Components/pqStandardColorButton.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorLinkAdaptor.cxx,v <-- Qt/Components/pqStandardColorLinkAdaptor.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorLinkAdaptor.h,v <-- Qt/Components/pqStandardColorLinkAdaptor.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- Qt/Components/CMakeLists.txt new revision: 1.158; previous revision: 1.157 /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationOptions.cxx,v <-- Qt/Components/pqApplicationOptions.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationOptions.h,v <-- Qt/Components/pqApplicationOptions.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.cxx,v <-- Qt/Components/pqDisplayProxyEditor.cxx new revision: 1.71; previous revision: 1.70 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMGlobalPropertiesLinkUndoElement.cxx,v <-- Servers/ServerManager/vtkSMGlobalPropertiesLinkUndoElement.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMGlobalPropertiesLinkUndoElement.h,v <-- Servers/ServerManager/vtkSMGlobalPropertiesLinkUndoElement.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMGlobalPropertiesManager.cxx,v <-- Servers/ServerManager/vtkSMGlobalPropertiesManager.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMGlobalPropertiesManager.h,v <-- Servers/ServerManager/vtkSMGlobalPropertiesManager.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/CMakeLists.txt,v <-- Servers/ServerManager/CMakeLists.txt new revision: 1.234; previous revision: 1.233 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxy.h,v <-- Servers/ServerManager/vtkSMProxy.h new revision: 1.95; previous revision: 1.94 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManager.cxx,v <-- Servers/ServerManager/vtkSMProxyManager.cxx new revision: 1.79; previous revision: 1.78 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManager.h,v <-- Servers/ServerManager/vtkSMProxyManager.h new revision: 1.53; previous revision: 1.52 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManagerInternals.h,v <-- Servers/ServerManager/vtkSMProxyManagerInternals.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMStateLoader.cxx,v <-- Servers/ServerManager/vtkSMStateLoader.cxx new revision: 1.32; previous revision: 1.31 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMStateLoader.h,v <-- Servers/ServerManager/vtkSMStateLoader.h new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMUndoRedoStateLoader.cxx,v <-- Servers/ServerManager/vtkSMUndoRedoStateLoader.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMUndoStackBuilder.cxx,v <-- Servers/ServerManager/vtkSMUndoStackBuilder.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMUndoStackBuilder.h,v <-- Servers/ServerManager/vtkSMUndoStackBuilder.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Applications/Client/CMakeLists.txt,v <-- Applications/Client/CMakeLists.txt new revision: 1.200; previous revision: 1.199 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqApplicationOptions.ui,v <-- Qt/Components/Resources/UI/pqApplicationOptions.ui new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqDisplayProxyEditor.ui,v <-- Qt/Components/Resources/UI/pqDisplayProxyEditor.ui new revision: 1.38; previous revision: 1.37 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- Qt/Core/pqApplicationCore.cxx new revision: 1.89; previous revision: 1.88 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.h,v <-- Qt/Core/pqApplicationCore.h new revision: 1.39; previous revision: 1.38 /cvsroot/ParaView3/ParaView3/Qt/Core/pqLinksModel.cxx,v <-- Qt/Core/pqLinksModel.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- Qt/Core/pqPipelineRepresentation.cxx new revision: 1.38; previous revision: 1.37 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewBase.cxx,v <-- Qt/Core/pqRenderViewBase.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServerManagerObserver.cxx,v <-- Qt/Core/pqServerManagerObserver.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqColorChooserButton.cxx,v <-- Qt/Widgets/pqColorChooserButton.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqColorChooserButton.h,v <-- Qt/Widgets/pqColorChooserButton.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- Servers/ServerManager/Resources/utilities.xml |
(0015402) Alan Scott (manager) 2009-02-25 20:23 |
WWWow, this is fantastic!! One setting that was missed, that is very important, is the Color Legend. I cannot see how to change it through the new global settings panel, and when I manually change it to black, and even hit the "make default" button, it goes back to white. |
(0015423) Utkarsh Ayachit (administrator) 2009-02-26 10:13 |
Legend text colors are by default linked with global "Text" color. Fixing the color editor dialog to allow the user to choose the global property linking. /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- Qt/Components/pqColorScaleEditor.cxx new revision: 1.51; previous revision: 1.50 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqColorScaleDialog.ui,v <-- Qt/Components/Resources/UI/pqColorScaleDialog.ui new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarBarRepresentation.cxx,v <-- Qt/Core/pqScalarBarRepresentation.cxx new revision: 1.9; previous revision: 1.8 |
(0015443) Alan Scott (manager) 2009-02-26 19:44 |
Tested client/ remote server. |
| Notes |
| Issue History | |||
| 2008-04-01 12:04 | Ken Moreland | New Issue | |
| 2008-04-10 17:58 | Ken Moreland | Category | Development => 3.6 |
| 2008-05-16 10:08 | Ken Moreland | Relationship added | related to 0006774 |
| 2008-05-20 09:26 | Ken Moreland | Note Added: 0012021 | |
| 2008-05-20 09:26 | Ken Moreland | Relationship added | related to 0007038 |
| 2008-11-10 18:20 | Utkarsh Ayachit | Relationship added | related to 0006816 |
| 2008-11-10 18:20 | Utkarsh Ayachit | Status | backlog => tabled |
| 2008-11-10 18:20 | Utkarsh Ayachit | Assigned To | => Zhanping Liu |
| 2008-12-15 18:12 | Ken Moreland | Relationship added | related to 0008289 |
| 2009-02-17 14:08 | Ken Moreland | Category | 3.6 => Pending |
| 2009-02-20 10:49 | Ken Moreland | Assigned To | Zhanping Liu => Utkarsh Ayachit |
| 2009-02-20 10:49 | Ken Moreland | Category | Pending => 3.6 |
| 2009-02-20 12:59 | Utkarsh Ayachit | Relationship added | related to 0007492 |
| 2009-02-25 14:18 | Utkarsh Ayachit | Note Added: 0015386 | |
| 2009-02-25 14:18 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2009-02-25 14:18 | Utkarsh Ayachit | Resolution | open => fixed |
| 2009-02-25 20:23 | Alan Scott | Note Added: 0015402 | |
| 2009-02-25 20:23 | Alan Scott | Status | @80@ => @20@ |
| 2009-02-25 20:23 | Alan Scott | Resolution | fixed => reopened |
| 2009-02-26 10:13 | Utkarsh Ayachit | Note Added: 0015423 | |
| 2009-02-26 10:13 | Utkarsh Ayachit | Status | @20@ => @80@ |
| 2009-02-26 10:13 | Utkarsh Ayachit | Resolution | reopened => fixed |
| 2009-02-26 19:44 | Alan Scott | Note Added: 0015443 | |
| 2009-02-26 19:44 | Alan Scott | Status | @80@ => closed |
| 2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
