(0015386)
Utkarsh Ayachit
2009-02-25 14:18
Adding notion of "global properties" which can be edited
from application settings. Solid color etc. can be set as one of the global
properties and then when one changes the global properties, it changes all
objects that are linked to it. Currently only colors are provided as global
properties but can be extended to other types such as line thickness etc.
/cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorButton.cxx,v <-- Qt/Components/pqStandardColorButton.cxx
initial revision: 1.1
/cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorButton.h,v <-- Qt/Components/pqStandardColorButton.h
/cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorLinkAdaptor.cxx,v <-- Qt/Components/pqStandardColorLinkAdaptor.cxx
/cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorLinkAdaptor.h,v <-- Qt/Components/pqStandardColorLinkAdaptor.h
/cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- Qt/Components/CMakeLists.txt
new revision: 1.158; previous revision: 1.157
/cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationOptions.cxx,v <-- Qt/Components/pqApplicationOptions.cxx
new revision: 1.8; previous revision: 1.7
/cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationOptions.h,v <-- Qt/Components/pqApplicationOptions.h
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.cxx,v <-- Qt/Components/pqDisplayProxyEditor.cxx
new revision: 1.71; previous revision: 1.70
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMGlobalPropertiesLinkUndoElement.cxx,v <-- Servers/ServerManager/vtkSMGlobalPropertiesLinkUndoElement.cxx
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMGlobalPropertiesLinkUndoElement.h,v <-- Servers/ServerManager/vtkSMGlobalPropertiesLinkUndoElement.h
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMGlobalPropertiesManager.cxx,v <-- Servers/ServerManager/vtkSMGlobalPropertiesManager.cxx
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMGlobalPropertiesManager.h,v <-- Servers/ServerManager/vtkSMGlobalPropertiesManager.h
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/CMakeLists.txt,v <-- Servers/ServerManager/CMakeLists.txt
new revision: 1.234; previous revision: 1.233
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxy.h,v <-- Servers/ServerManager/vtkSMProxy.h
new revision: 1.95; previous revision: 1.94
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManager.cxx,v <-- Servers/ServerManager/vtkSMProxyManager.cxx
new revision: 1.79; previous revision: 1.78
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManager.h,v <-- Servers/ServerManager/vtkSMProxyManager.h
new revision: 1.53; previous revision: 1.52
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxyManagerInternals.h,v <-- Servers/ServerManager/vtkSMProxyManagerInternals.h
new revision: 1.13; previous revision: 1.12
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMStateLoader.cxx,v <-- Servers/ServerManager/vtkSMStateLoader.cxx
new revision: 1.32; previous revision: 1.31
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMStateLoader.h,v <-- Servers/ServerManager/vtkSMStateLoader.h
new revision: 1.22; previous revision: 1.21
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMUndoRedoStateLoader.cxx,v <-- Servers/ServerManager/vtkSMUndoRedoStateLoader.cxx
new revision: 1.5; previous revision: 1.4
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMUndoStackBuilder.cxx,v <-- Servers/ServerManager/vtkSMUndoStackBuilder.cxx
new revision: 1.2; previous revision: 1.1
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMUndoStackBuilder.h,v <-- Servers/ServerManager/vtkSMUndoStackBuilder.h
/cvsroot/ParaView3/ParaView3/Applications/Client/CMakeLists.txt,v <-- Applications/Client/CMakeLists.txt
new revision: 1.200; previous revision: 1.199
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqApplicationOptions.ui,v <-- Qt/Components/Resources/UI/pqApplicationOptions.ui
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqDisplayProxyEditor.ui,v <-- Qt/Components/Resources/UI/pqDisplayProxyEditor.ui
new revision: 1.38; previous revision: 1.37
/cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- Qt/Core/pqApplicationCore.cxx
new revision: 1.89; previous revision: 1.88
/cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.h,v <-- Qt/Core/pqApplicationCore.h
new revision: 1.39; previous revision: 1.38
/cvsroot/ParaView3/ParaView3/Qt/Core/pqLinksModel.cxx,v <-- Qt/Core/pqLinksModel.cxx
new revision: 1.20; previous revision: 1.19
/cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- Qt/Core/pqPipelineRepresentation.cxx
/cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewBase.cxx,v <-- Qt/Core/pqRenderViewBase.cxx
/cvsroot/ParaView3/ParaView3/Qt/Core/pqServerManagerObserver.cxx,v <-- Qt/Core/pqServerManagerObserver.cxx
/cvsroot/ParaView3/ParaView3/Qt/Widgets/pqColorChooserButton.cxx,v <-- Qt/Widgets/pqColorChooserButton.cxx
/cvsroot/ParaView3/ParaView3/Qt/Widgets/pqColorChooserButton.h,v <-- Qt/Widgets/pqColorChooserButton.h
new revision: 1.4; previous revision: 1.3
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- Servers/ServerManager/Resources/utilities.xml |
(0015402)
Alan Scott
2009-02-25 20:23
WWWow, this is fantastic!!
One setting that was missed, that is very important, is the Color Legend. I cannot see how to change it through the new global settings panel, and when I manually change it to black, and even hit the "make default" button, it goes back to white. |
(0015423)
Utkarsh Ayachit
2009-02-26 10:13
Legend text colors are by default linked with global
"Text" color. Fixing the color editor dialog to allow the user to choose the
global property linking.
/cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- Qt/Components/pqColorScaleEditor.cxx
new revision: 1.51; previous revision: 1.50
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqColorScaleDialog.ui,v <-- Qt/Components/Resources/UI/pqColorScaleDialog.ui
new revision: 1.16; previous revision: 1.15
/cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarBarRepresentation.cxx,v <-- Qt/Core/pqScalarBarRepresentation.cxx
new revision: 1.9; previous revision: 1.8 |
