| 0014889 | ParaView | (No Category) | public | 2014-07-26 11:55 | 2015-01-11 08:16 | ||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 4.2 | |||||||
| Summary | 0014889: Warning messages from pqDisplayColorWidget on state loading | ||||||||
| Description | + Create Sphere, Apply + Color by "Normals", Component "Y". + Hide the Sphere + Save XML state. Now "Reset Session" or restart ParaView and then load the XML state. If you select "Sphere0" in the Pipeline Browser, you'll get following messages: ( 0 , "Normals" ) is not an array shown in the pqDisplayColorWidget currently. Will add a new entry for it ( 0 , "Normals" ) is not an array shown in the pqDisplayColorWidget currently. Will add a new entry for it That incorrect. What's expected is as follows: Since the Sphere pipeline hasn;t executed, it's expected that ParaView doesn't know what this array "Normals" is. But the pqDisplayColorWidget should silently add that to the combo-box and show it. Since ParaView doesn't know about the array, it doesn't know how many components it has at this time. So it's expected that the component selection combo-box is empty. Now when you turn on "visibility" of the Sphere, the source executes and ParaView will know what this "Normals" array is (along with other potential options). The UI should then update to show the selection of components available and currently selected component (which in this case is "Y"). | ||||||||
| Project | TBD | ||||||||
| Topic Name | 14888_fix_state_loading_for_domains | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0033102) Utkarsh Ayachit (administrator) 2014-07-26 12:16 |
commit 48d829b7d8b18c7cd28d6338bb42c80610a1ba38 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Jul 26 11:48:42 2014 -0400 BUG 0014889. Fixed pqDisplayColorWidget for values not in domain. Fixed pqDisplayColorWidget to properly handle the case when the values for the SMProperty are not in the domain. This change also ensures that whenever the domain is updated with relevant information, the UI will also update to show most up-to-date information about component available, and the selected component. Also added a test (LoadPartiallyUpdatedStateFiles) which tests both, BUG 0014888 and BUG 0014889. Change-Id: Id0488f0e024b7580aea5ef687f4efcd486ced400 |
(0033105) Sebastien Jourdain (manager) 2014-07-27 11:50 |
SUMMARY --------------------------------------------- Topics merged into master: 14888_fix_state_loading_for_domains (VTK) pvweb-visualizer-widgets --------------------------------------------- Topics reverted from next: widen_properties_panel |
(0033164) Alan Scott (manager) 2014-07-30 21:49 |
Tested remote server, Linux, master. |
| Notes |
| Issue History | |||
| 2014-07-26 11:55 | Utkarsh Ayachit | New Issue | |
| 2014-07-26 12:15 | Utkarsh Ayachit | Relationship added | related to 0014888 |
| 2014-07-26 12:16 | Utkarsh Ayachit | Topic Name | => 14888_fix_state_loading_for_domains |
| 2014-07-26 12:16 | Utkarsh Ayachit | Note Added: 0033102 | |
| 2014-07-26 12:16 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2014-07-26 12:16 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2014-07-26 12:16 | Utkarsh Ayachit | Resolution | open => fixed |
| 2014-07-26 12:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2014-07-27 11:50 | Sebastien Jourdain | Status | gatekeeper review => customer review |
| 2014-07-27 11:50 | Sebastien Jourdain | Note Added: 0033105 | |
| 2014-07-30 21:49 | Alan Scott | Note Added: 0033164 | |
| 2014-07-30 21:49 | Alan Scott | Status | customer review => closed |
| 2014-07-31 09:20 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| 2015-01-11 08:16 | Sebastiennn Jourdain | Source_changeset_attached | => ParaView master 4e0fffc3 |
| 2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 48d829b7 |
| Issue History |
