| 0014888 | ParaView | (No Category) | public | 2014-07-25 15:49 | 2015-01-11 08:16 | ||||
| Product Version | git-master | ||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0014888: Error output load state, visibility | ||||||||
| Description | There is an error output that occurs on load state, with some objects being loaded without visibility. Easy to replicate, as follows: Local server, master, Linux. 1. start client 2. create plane and sphere w/ defaults 3. make sphere invisible 4. save state 5. delete all 6. load state 7. make sphere visible You get the following: ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 324 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 336 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 312 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 324 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 336 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 312 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 324 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 336 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 312 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 324 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 336 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 312 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 14888_fix_state_loading_for_domains | ||||||||
| Attached Files | |||||||||
| Relationships | |||||||||||
| Relationships |
| Notes | |
(0033103) Utkarsh Ayachit (administrator) 2014-07-26 12:16 |
commit cf306d20ca46fb14e538d77f17bb1a8d903aab52 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Jul 26 11:12:10 2014 -0400 BUG 0014888: Fix state loading errors. BUG 0014888 was showing up for the following reasons: The saved XML state had save values for the "ColorArrayName" property's domain for the Sphere's representation. When the state was loaded, since vtkSMStringListDomain overloaded the LoadState() method, it read the values from the XML state. Now, since the state didn't save information about array association, when the state was loaded, naturally, vtkSMArrayListDomain subclass for this domain didn't have sufficient state and hence when UI tried to get information about the arrays, it raised errors. The problem stemmed from the fact that we shouldn't be reloading state for domains from XML (except ProxyListDomain). Domain values are either compile time (specified in server manager configuration XML) or run time (determined by run time data values). For both cases, loading from XML state doesn't help at all. Fixed this and update vtkSMDomain to have documentation to keep developers from overriding LoadState() accidentally. Change-Id: I729df876c3762b2a05d8f95a1f8a20ed97359a7d |
(0033104) Sebastien Jourdain (manager) 2014-07-27 11:50 |
SUMMARY --------------------------------------------- Topics merged into master: 14888_fix_state_loading_for_domains (VTK) pvweb-visualizer-widgets --------------------------------------------- Topics reverted from next: widen_properties_panel |
(0033108) Alan Scott (manager) 2014-07-28 15:49 |
Tested master, Linux, remote server. |
| Notes |
| Issue History | |||
| 2014-07-25 15:49 | Alan Scott | New Issue | |
| 2014-07-25 15:50 | Alan Scott | Relationship added | related to 0014834 |
| 2014-07-25 16:00 | Alan Scott | Target Version | => 4.2 |
| 2014-07-26 12:15 | Utkarsh Ayachit | Relationship added | related to 0014889 |
| 2014-07-26 12:16 | Utkarsh Ayachit | Topic Name | => 14888_fix_state_loading_for_domains |
| 2014-07-26 12:16 | Utkarsh Ayachit | Note Added: 0033103 | |
| 2014-07-26 12:16 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2014-07-26 12:16 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2014-07-26 12:16 | Utkarsh Ayachit | Resolution | open => fixed |
| 2014-07-26 12:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2014-07-27 11:50 | Sebastien Jourdain | Status | gatekeeper review => customer review |
| 2014-07-27 11:50 | Sebastien Jourdain | Note Added: 0033104 | |
| 2014-07-28 15:49 | Alan Scott | Note Added: 0033108 | |
| 2014-07-28 15:49 | Alan Scott | Status | customer review => closed |
| 2014-07-31 09:19 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| 2015-01-11 08:16 | Sebastiennn Jourdain | Source_changeset_attached | => ParaView master 4e0fffc3 |
| 2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 48d829b7 |
| 2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master cf306d20 |
| Issue History |
