| 0014685 | ParaView | (No Category) | public | 2014-04-11 20:29 | 2014-08-29 11:00 | ||||
| Assigned To | Cory Quammen | ||||||||
| Product Version | git-master | ||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0014685: color legend turn min/max off | ||||||||
| Description | The color legend is too horizontally wide, with the min and max value on the left side of the color bar and the tick marks on the right. This can be changed by deleting the min/max value entirely by going to the Edit Color Legend Properties panel and deselecting Draw Annotation. Please turn the Draw Annotation off by default. However, make this setting be "sticky" in the ParaView configuration between sessions. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 14679_color_legend_bugs | ||||||||
| Type | usability | ||||||||
| Attached Files | ![]() | ||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0032679) Cory Quammen (developer) 2014-05-29 12:33 |
To test: - Create cylinder source - Change coloring to TCoords. The color legend should appear with no min/max shown - Click the Edit Color Map button - In the Color Map Editor, click the "Edit color legend properties" button - Click the "Add Range Annotations" button. - Click Apply. The color legend should show the min/max. |
(0032693) Utkarsh Ayachit (administrator) 2014-05-30 08:14 |
SUMMARY --------------------------------------------- Topics merged into master: 14679_color_legend_bugs 14734-GoodDefaultSizeForpqProxyWidgetDialog cleanup-cmake fix_assembly_render_view fix_fragment_large_scale fix_plugin_loading_order fix_qt_modules remove-unused-directory --------------------------------------------- Topics reverted from next: 14673_fix_follow_data |
(0032702) Alan Scott (manager) 2014-05-30 22:11 |
Not yet sticky. I believe Cory said that he is working on this. Don't close until sticky. |
(0032824) Cory Quammen (developer) 2014-06-10 14:47 |
Alan, The "sticky" feature is now in master (see related bug http://www.paraview.org/Bug/view.php?id=14762 [^]) commit 6b645ec33fe0485e3408ec55d1977d73cd2d679e Author: Cory Quammen <cory.quammen@kitware.com> Date: Thu Jun 5 14:01:55 2014 -0400 Add buttons to pqProxyWidgetDialog Added a button to save currently applied settings as property defaults and a button to restore the application defaults. Removed QDialogButtonBox and replaced with simple QPushButtons. Updated tests that involve the pqProxyWidgetDialog. Change-Id: Iedc7684af5741b0854470ace3dcb459e5d523999 To test: 1. Add Cylinder source 2. Change variable to color by to TCoords 3. Click Edit Color Map tool button 4. Click "Edit color legend properties" in the Color Map Editor 5. Uncheck the "Draw Annotations" checkbox. 6. Click "Apply". 7. Click the disk icon with the down arrow. This saves the settings as the new defaults. 8. Click OK to close the "Edit Color Legend Parameters" dialog 9. Create a Plane source 10. Change variable to color by TextureCoordinates 11. Click "Edit color legend properties" in the Color Map Editor 12. Note that the "Draw Annotations" is off. 13. Close ParaView. 14. Repeat steps 9-12 one time. 15. Note that the "Draw Annotations" is off. |
(0032825) Alan Scott (manager) 2014-06-10 21:13 |
Very nice. Tested remote server, Linux, master. |
| Notes |
| Issue History | |||
| 2014-04-11 20:29 | Alan Scott | New Issue | |
| 2014-04-11 20:30 | Alan Scott | File Added: colorLegendScreenshot.png | |
| 2014-04-11 20:30 | Alan Scott | Relationship added | child of 0014679 |
| 2014-04-12 22:07 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-05-12 11:29 | Utkarsh Ayachit | Assigned To | => Cory Quammen |
| 2014-05-29 12:33 | Cory Quammen | Topic Name | => 14679_color_legend_bugs |
| 2014-05-29 12:33 | Cory Quammen | Note Added: 0032679 | |
| 2014-05-29 12:33 | Cory Quammen | Status | backlog => gatekeeper review |
| 2014-05-29 12:33 | Cory Quammen | Fixed in Version | => git-next |
| 2014-05-29 12:33 | Cory Quammen | Resolution | open => fixed |
| 2014-05-30 08:13 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-05-30 08:14 | Utkarsh Ayachit | Note Added: 0032693 | |
| 2014-05-30 08:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-05-30 22:11 | Alan Scott | Note Added: 0032702 | |
| 2014-06-10 14:47 | Cory Quammen | Note Added: 0032824 | |
| 2014-06-10 21:13 | Alan Scott | Note Added: 0032825 | |
| 2014-06-10 21:13 | Alan Scott | Status | customer review => closed |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| Issue History |
