MantisBT - ParaView |
| View Issue Details |
| 0014685 | ParaView | (No Category) | public | 2014-04-11 20:29 | 2014-08-29 11:00 |
| Reporter | Alan Scott | |
| Assigned To | Cory Quammen | |
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | git-master | |
| Target Version | 4.2 | Fixed in Version | 4.2 | |
| Project | Sandia |
| Topic Name | 14679_color_legend_bugs |
| Type | usability |
| Summary | 0014685: color legend turn min/max off |
| Description | The color legend is too horizontally wide, with the min and max value on the left side of the color bar and the tick marks on the right. This can be changed by deleting the min/max value entirely by going to the Edit Color Legend Properties panel and deselecting Draw Annotation.
Please turn the Draw Annotation off by default. However, make this setting be "sticky" in the ParaView configuration between sessions.
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | | child of | 0014679 | closed | Cory Quammen | color legend master bug |
| Attached Files | colorLegendScreenshot.png (59,856) 2014-04-11 20:30 https://www.vtk.org/Bug/file/9633/colorLegendScreenshot.png
| Issue History |
| 2014-04-11 20:29 | Alan Scott | New Issue | |
| 2014-04-11 20:30 | Alan Scott | File Added: colorLegendScreenshot.png | |
| 2014-04-11 20:30 | Alan Scott | Relationship added | child of 0014679 |
| 2014-04-12 22:07 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-05-12 11:29 | Utkarsh Ayachit | Assigned To | => Cory Quammen |
| 2014-05-29 12:33 | Cory Quammen | Topic Name | => 14679_color_legend_bugs |
| 2014-05-29 12:33 | Cory Quammen | Note Added: 0032679 | |
| 2014-05-29 12:33 | Cory Quammen | Status | backlog => gatekeeper review |
| 2014-05-29 12:33 | Cory Quammen | Fixed in Version | => git-next |
| 2014-05-29 12:33 | Cory Quammen | Resolution | open => fixed |
| 2014-05-30 08:13 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-05-30 08:14 | Utkarsh Ayachit | Note Added: 0032693 | |
| 2014-05-30 08:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-05-30 22:11 | Alan Scott | Note Added: 0032702 | |
| 2014-06-10 14:47 | Cory Quammen | Note Added: 0032824 | |
| 2014-06-10 21:13 | Alan Scott | Note Added: 0032825 | |
| 2014-06-10 21:13 | Alan Scott | Status | customer review => closed |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
(0032679)
Cory Quammen
2014-05-29 12:33
To test:
- Create cylinder source
- Change coloring to TCoords. The color legend should appear with no min/max shown
- Click the Edit Color Map button
- In the Color Map Editor, click the "Edit color legend properties" button
- Click the "Add Range Annotations" button.
- Click Apply. The color legend should show the min/max. |
(0032693)
Utkarsh Ayachit
2014-05-30 08:14
SUMMARY
Topics merged into master:
14734-GoodDefaultSizeForpqProxyWidgetDialog
cleanup-cmake
fix_assembly_render_view
fix_fragment_large_scale
fix_plugin_loading_order
fix_qt_modules
remove-unused-directory
Topics reverted from next:
14673_fix_follow_data
(0032702)
Alan Scott
2014-05-30 22:11
Not yet sticky. I believe Cory said that he is working on this. Don't close until sticky. |
(0032824)
Cory Quammen
2014-06-10 14:47
Alan,
The "sticky" feature is now in master (see related bug http://www.paraview.org/Bug/view.php?id=14762 [^])
commit 6b645ec33fe0485e3408ec55d1977d73cd2d679e
Author: Cory Quammen <cory.quammen@kitware.com>
Date: Thu Jun 5 14:01:55 2014 -0400
Add buttons to pqProxyWidgetDialog
Added a button to save currently applied settings as property defaults
and a button to restore the application defaults.
Removed QDialogButtonBox and replaced with simple QPushButtons.
Updated tests that involve the pqProxyWidgetDialog.
Change-Id: Iedc7684af5741b0854470ace3dcb459e5d523999
To test:
1. Add Cylinder source
2. Change variable to color by to TCoords
3. Click Edit Color Map tool button
4. Click "Edit color legend properties" in the Color Map Editor
5. Uncheck the "Draw Annotations" checkbox.
6. Click "Apply".
7. Click the disk icon with the down arrow. This saves the settings as the new defaults.
8. Click OK to close the "Edit Color Legend Parameters" dialog
9. Create a Plane source
10. Change variable to color by TextureCoordinates
11. Click "Edit color legend properties" in the Color Map Editor
12. Note that the "Draw Annotations" is off.
13. Close ParaView.
14. Repeat steps 9-12 one time.
15. Note that the "Draw Annotations" is off. |
(0032825)
Alan Scott
2014-06-10 21:13
Very nice.
Tested remote server, Linux, master. |
