| 0014565 | ParaView | (No Category) | public | 2014-02-11 12:26 | 2014-08-29 11:00 | ||||
| Reporter | David C. Lonie | ||||||||
| Assigned To | David C. Lonie | ||||||||
| Product Version | git-master | ||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0014565: Python Calculator and Extract Selection broken for composite datasets | ||||||||
| Description | To reproduce with Find Data: 1) Open can.ex2, enable EQPS array, advance to some interesting time (frame ~20 or so). 2) Open Find Data dialog 3) Search cells for query "EQPS == max(EQPS)" Expected: The cell(s) with the maximum EQPS value should be highlighted. Result: The query is run independently on each block of the dataset, and the cell(s) with the block's maximum EQPS value is highlighted. To reproduce with python filter: 1) Same as above. 2) Add a python calculator 3) Evaluate an expression such as "EQPS + max(EQPS)" Expected: A result array shifted by the composite maximum EQPS value should be added to the dataset. Result: Each block is shifted independently by its maximum. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 14565-composite-queries | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0032307) David C. Lonie (developer) 2014-02-11 12:42 |
Added python objects to treat composite dataset arrays as a single array. |
(0032308) David C. Lonie (developer) 2014-02-11 13:40 |
Warnings/failures on dashboard |
(0032350) David C. Lonie (developer) 2014-02-19 09:05 |
Tests are passing on 'next' dashboards, should be good to go. |
(0032388) Utkarsh Ayachit (administrator) 2014-02-23 09:59 |
SUMMARY --------------------------------------------- Topics merged into master: 14412-select-translucent-actors 14455-save-screenshot-semicolon 14539-can-crash 14558-disconnect-cleanup (VTK) 14565-composite-queries 14585_XMLWriters_64bit_default ParallelPythonImport_mpi4py catalyst-web-improvement cleanup_CoProcessing fix-rendering-edition fix-sciberquest-installdir fix_multiview_widget pvweb-widget-catalyst |
(0032402) Utkarsh Ayachit (administrator) 2014-02-24 13:03 |
Reopening due to a parallel bug. To reproduce do the following steps: + Run pvserver in parallel with 3 procs: mpirun -np 3 ./bin/pvserver + Connect to this pvserver using ParaView + Open can.ex2, check all variables, uncheck "Apply displacements", apply + Create D3 filter, apply. Color by "vtkProcessId" -- data partitioned among 3 procs. + Now open the Find Data dialog and try the query "EQPS[:,0] == max(EQPS)". timestep 0: everything is fine (all cells have EQPS==0 so everything is highlighted). timestep 1: incorrect -- if you look at the spreadsheet shown in the Find Data dialog, cells have EQPS = 0, 0.0013.., and 0.86.... That's not right. |
(0032445) David C. Lonie (developer) 2014-03-03 14:44 |
Applying the patch for 0013794 and using "global_max" instead of "max" works as expected. |
| Notes |
| Issue History | |||
| 2014-02-11 12:26 | David C. Lonie | New Issue | |
| 2014-02-11 12:26 | David C. Lonie | Assigned To | => David C. Lonie |
| 2014-02-11 12:26 | David C. Lonie | Relationship added | child of 0013794 |
| 2014-02-11 12:42 | David C. Lonie | Topic Name | => 14565-composite-queries |
| 2014-02-11 12:42 | David C. Lonie | Note Added: 0032307 | |
| 2014-02-11 12:42 | David C. Lonie | Status | backlog => gatekeeper review |
| 2014-02-11 12:42 | David C. Lonie | Fixed in Version | => git-next |
| 2014-02-11 12:42 | David C. Lonie | Resolution | open => fixed |
| 2014-02-11 13:40 | David C. Lonie | Note Added: 0032308 | |
| 2014-02-11 13:40 | David C. Lonie | Status | gatekeeper review => active development |
| 2014-02-19 09:05 | David C. Lonie | Note Added: 0032350 | |
| 2014-02-19 09:05 | David C. Lonie | Status | active development => gatekeeper review |
| 2014-02-23 09:58 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-02-23 09:59 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-02-23 09:59 | Utkarsh Ayachit | Note Added: 0032388 | |
| 2014-02-24 13:03 | Utkarsh Ayachit | Note Added: 0032402 | |
| 2014-02-24 13:03 | Utkarsh Ayachit | Status | customer review => todo |
| 2014-03-03 14:44 | David C. Lonie | Note Added: 0032445 | |
| 2014-03-03 15:11 | David C. Lonie | Status | todo => closed |
| 2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| Issue History |
