MantisBT - ParaView |
| View Issue Details |
| 0014565 | ParaView | (No Category) | public | 2014-02-11 12:26 | 2014-08-29 11:00 |
| Reporter | David C. Lonie | |
| Assigned To | David C. Lonie | |
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | git-master | |
| Target Version | 4.2 | Fixed in Version | 4.2 | |
| Project | Sandia |
| Topic Name | 14565-composite-queries |
| Type | incorrect functionality |
| Summary | 0014565: Python Calculator and Extract Selection broken for composite datasets |
| Description | To reproduce with Find Data:
1) Open can.ex2, enable EQPS array, advance to some interesting time (frame ~20 or so).
2) Open Find Data dialog
3) Search cells for query "EQPS == max(EQPS)"
Expected: The cell(s) with the maximum EQPS value should be highlighted.
Result: The query is run independently on each block of the dataset, and the cell(s) with the block's maximum EQPS value is highlighted.
To reproduce with python filter:
1) Same as above.
2) Add a python calculator
3) Evaluate an expression such as "EQPS + max(EQPS)"
Expected: A result array shifted by the composite maximum EQPS value should be added to the dataset.
Result: Each block is shifted independently by its maximum. |
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | | child of | 0013794 | closed | David C. Lonie | Remote server, find max error |
| Attached Files | |
| Issue History |
| 2014-02-11 12:26 | David C. Lonie | New Issue | |
| 2014-02-11 12:26 | David C. Lonie | Assigned To | => David C. Lonie |
| 2014-02-11 12:26 | David C. Lonie | Relationship added | child of 0013794 |
| 2014-02-11 12:42 | David C. Lonie | Topic Name | => 14565-composite-queries |
| 2014-02-11 12:42 | David C. Lonie | Note Added: 0032307 | |
| 2014-02-11 12:42 | David C. Lonie | Status | backlog => gatekeeper review |
| 2014-02-11 12:42 | David C. Lonie | Fixed in Version | => git-next |
| 2014-02-11 12:42 | David C. Lonie | Resolution | open => fixed |
| 2014-02-11 13:40 | David C. Lonie | Note Added: 0032308 | |
| 2014-02-11 13:40 | David C. Lonie | Status | gatekeeper review => active development |
| 2014-02-19 09:05 | David C. Lonie | Note Added: 0032350 | |
| 2014-02-19 09:05 | David C. Lonie | Status | active development => gatekeeper review |
| 2014-02-23 09:58 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-02-23 09:59 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-02-23 09:59 | Utkarsh Ayachit | Note Added: 0032388 | |
| 2014-02-24 13:03 | Utkarsh Ayachit | Note Added: 0032402 | |
| 2014-02-24 13:03 | Utkarsh Ayachit | Status | customer review => todo |
| 2014-03-03 14:44 | David C. Lonie | Note Added: 0032445 | |
| 2014-03-03 15:11 | David C. Lonie | Status | todo => closed |
| 2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
(0032307)
David C. Lonie
2014-02-11 12:42
Added python objects to treat composite dataset arrays as a single array. |
(0032308)
David C. Lonie
2014-02-11 13:40
Warnings/failures on dashboard |
(0032350)
David C. Lonie
2014-02-19 09:05
Tests are passing on 'next' dashboards, should be good to go. |
(0032388)
Utkarsh Ayachit
2014-02-23 09:59
SUMMARY
Topics merged into master:
14412-select-translucent-actors
14455-save-screenshot-semicolon
14539-can-crash
14558-disconnect-cleanup
(VTK) 14565-composite-queries
14585_XMLWriters_64bit_default
ParallelPythonImport_mpi4py
catalyst-web-improvement
cleanup_CoProcessing
fix-rendering-edition
fix-sciberquest-installdir
fix_multiview_widget
pvweb-widget-catalyst
(0032402)
Utkarsh Ayachit
2014-02-24 13:03
Reopening due to a parallel bug. To reproduce do the following steps:
+ Run pvserver in parallel with 3 procs:
mpirun -np 3 ./bin/pvserver
+ Connect to this pvserver using ParaView
+ Open can.ex2, check all variables, uncheck "Apply displacements", apply
+ Create D3 filter, apply. Color by "vtkProcessId" -- data partitioned among 3 procs.
+ Now open the Find Data dialog and try the query "EQPS[:,0] == max(EQPS)".
timestep 0: everything is fine (all cells have EQPS==0 so everything is highlighted).
timestep 1: incorrect -- if you look at the spreadsheet shown in the Find Data dialog, cells have EQPS = 0, 0.0013.., and 0.86.... That's not right.
(0032445)
David C. Lonie
2014-03-03 14:44
Applying the patch for 0013794 and using "global_max" instead of "max" works as expected. |
