| 0012360 | ParaView | (No Category) | public | 2011-07-12 11:41 | 2012-02-08 17:24 | ||||
| Reporter | Burlen | ||||||||
| Product Version | 3.10 | ||||||||
| Target Version | Fixed in Version | 3.12 | |||||||
| Summary | 0012360: Plugin load order hides Surface LIC attributes in python | ||||||||
| Description | From a python script, the order in which the plugins are loaded affects the presence of LIC attributes. If the LIC plugin is loaded before other plugins the attributes are present. If it is loaded after then it's attributes aren't present. The following python script illustrates the issue when run with pvbatch # -*- coding: utf-8 -*- try: paraview.simple except: from paraview.simple import * paraview.simple._DisableFirstRenderCameraReset() slacPluginPath = '/work/ext/ParaView/PV3-3.10.0/bin/libSLACTools.so' licPluginPath = '/work/ext/ParaView/PV3-3.10.0/bin/libSurfaceLIC.so' showBug = 1 if (showBug): LoadPlugin(slacPluginPath, False, globals()) LoadPlugin(slacPluginPath, False, globals()) LoadPlugin(licPluginPath, False, globals()) LoadPlugin(licPluginPath, True, globals()) else: LoadPlugin(licPluginPath, False, globals()) LoadPlugin(licPluginPath,True,globals()) LoadPlugin(slacPluginPath, False, globals()) LoadPlugin(slacPluginPath, False, globals()) Cone() rep = Show() rep.LICStepSize = 12 | ||||||||
| Project | TBD | ||||||||
| Topic Name | 12360_fix_plugins_in_python | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0027190) Sebastien Jourdain (manager) 2011-08-01 18:11 |
Did not try, that specific code to highlight this issue. But this should be solved in the topic. |
(0027236) Utkarsh Ayachit (administrator) 2011-08-04 18:08 |
Developer note: Issue slated for gatekeeper review on Aug 7, 2 PM EDT. |
(0027261) David Partyka (developer) 2011-08-05 10:52 |
Couldn't get script to run but verified from the gui by loading SurfaceLIC plugin. |
(0027276) Utkarsh Ayachit (administrator) 2011-08-05 15:55 |
Merged into master (if applicable) |
(0027469) Utkarsh Ayachit (administrator) 2011-09-12 10:16 |
Still doesn't work. Reopening. |
(0027470) Utkarsh Ayachit (administrator) 2011-09-12 10:48 |
commit 86b4b7a7e149bd11506da39458dfcdd5e4ee215a Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Sep 12 10:21:22 2011 -0400 BUG 0012415: Plugins updating proxy definitions didn't work from pvpython. Things worked as expected when new proxy definitions were added, but when a proxy defintion was updated, the Python Proxy object didn't not reflect the properties. The problem was that the prototypes created by servermanager.py were never cleaned up even when definitions were updated. Fixed by fixing vtkSIProxyDefinitionManager to fire events in a more well defined manner. Then fixing vtkSMProxyManager to use those events to clean u any obsolete prototype instantiations. Now the python code correctly sees th new prototype and updates the Python Proxies accordingly. |
(0027471) Utkarsh Ayachit (administrator) 2011-09-12 10:48 |
commit 0e4f9e2d3e9cc7e16eebe5718a5d2e507fe2acf2 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Sep 12 10:45:20 2011 -0400 Added a test (Plugins-ServerManagerPython) to test plugin loading in Python. |
(0028140) Utkarsh Ayachit (administrator) 2012-02-08 17:24 |
Closing bugs sitting in "customer review" for a long time. |
| Notes |
| Issue History | |||
| 2011-07-12 11:41 | Burlen | New Issue | |
| 2011-07-27 21:08 | Utkarsh Ayachit | Relationship added | related to 0012415 |
| 2011-08-01 18:10 | Sebastien Jourdain | Assigned To | => Sebastiennn Jourdain |
| 2011-08-01 18:10 | Sebastien Jourdain | Status | backlog => todo |
| 2011-08-01 18:10 | Sebastien Jourdain | Status | todo => active development |
| 2011-08-01 18:11 | Sebastien Jourdain | Topic Name | => 12415-representation-plugin |
| 2011-08-01 18:11 | Sebastien Jourdain | Note Added: 0027190 | |
| 2011-08-01 18:11 | Sebastien Jourdain | Status | active development => gatekeeper review |
| 2011-08-01 18:11 | Sebastien Jourdain | Resolution | open => fixed |
| 2011-08-04 18:08 | Utkarsh Ayachit | Note Added: 0027236 | |
| 2011-08-05 10:52 | David Partyka | Note Added: 0027261 | |
| 2011-08-05 15:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2011-08-05 15:55 | Utkarsh Ayachit | Note Added: 0027276 | |
| 2011-08-12 23:40 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
| 2011-09-12 10:16 | Utkarsh Ayachit | Note Added: 0027469 | |
| 2011-09-12 10:16 | Utkarsh Ayachit | Status | customer review => backlog |
| 2011-09-12 10:16 | Utkarsh Ayachit | Resolution | fixed => reopened |
| 2011-09-12 10:48 | Utkarsh Ayachit | Topic Name | 12415-representation-plugin => 12360_fix_plugins_in_python |
| 2011-09-12 10:48 | Utkarsh Ayachit | Note Added: 0027470 | |
| 2011-09-12 10:48 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2011-09-12 10:48 | Utkarsh Ayachit | Fixed in Version | 3.12 => git-next |
| 2011-09-12 10:48 | Utkarsh Ayachit | Resolution | reopened => fixed |
| 2011-09-12 10:48 | Utkarsh Ayachit | Assigned To | Sebastiennn Jourdain => Utkarsh Ayachit |
| 2011-09-12 10:48 | Utkarsh Ayachit | Note Added: 0027471 | |
| 2011-09-16 14:35 | David Partyka | Status | gatekeeper review => customer review |
| 2011-11-11 17:08 | Utkarsh Ayachit | Fixed in Version | git-next => 3.12 |
| 2012-02-08 17:24 | Utkarsh Ayachit | Status | customer review => closed |
| 2012-02-08 17:24 | Utkarsh Ayachit | Note Added: 0028140 | |
| Issue History |
