MantisBT - ParaView | ||||||||||
| View Issue Details | ||||||||||
| ID | Project | Category | View Status | Date Submitted | Last Update | |||||
| 0012360 | ParaView | (No Category) | public | 2011-07-12 11:41 | 2012-02-08 17:24 | |||||
| Reporter | Burlen | |||||||||
| Assigned To | Utkarsh Ayachit | |||||||||
| Priority | normal | Severity | minor | Reproducibility | have not tried | |||||
| Status | closed | Resolution | fixed | |||||||
| Platform | OS | OS Version | ||||||||
| Product Version | 3.10 | |||||||||
| Target Version | Fixed in Version | 3.12 | ||||||||
| Project | TBD | |||||||||
| Topic Name | 12360_fix_plugins_in_python | |||||||||
| Type | incorrect functionality | |||||||||
| Summary | 0012360: Plugin load order hides Surface LIC attributes in python | |||||||||
| Description | From a python script, the order in which the plugins are loaded affects the presence of LIC attributes. If the LIC plugin is loaded before other plugins the attributes are present. If it is loaded after then it's attributes aren't present. The following python script illustrates the issue when run with pvbatch # -*- coding: utf-8 -*- try: paraview.simple except: from paraview.simple import * paraview.simple._DisableFirstRenderCameraReset() slacPluginPath = '/work/ext/ParaView/PV3-3.10.0/bin/libSLACTools.so' licPluginPath = '/work/ext/ParaView/PV3-3.10.0/bin/libSurfaceLIC.so' showBug = 1 if (showBug): LoadPlugin(slacPluginPath, False, globals()) LoadPlugin(slacPluginPath, False, globals()) LoadPlugin(licPluginPath, False, globals()) LoadPlugin(licPluginPath, True, globals()) else: LoadPlugin(licPluginPath, False, globals()) LoadPlugin(licPluginPath,True,globals()) LoadPlugin(slacPluginPath, False, globals()) LoadPlugin(slacPluginPath, False, globals()) Cone() rep = Show() rep.LICStepSize = 12 | |||||||||
| Steps To Reproduce | ||||||||||
| Additional Information | ||||||||||
| Tags | No tags attached. | |||||||||
| Relationships |
| Attached Files | ||||||||||
| Issue History | ||||||||||
| Date Modified | Username | Field | Change | |||||||
| 2011-07-12 11:41 | Burlen | New Issue | ||||||||
| 2011-07-27 21:08 | Utkarsh Ayachit | Relationship added | related to 0012415 | |||||||
| 2011-08-01 18:10 | Sebastien Jourdain | Assigned To | => Sebastiennn Jourdain | |||||||
| 2011-08-01 18:10 | Sebastien Jourdain | Status | backlog => todo | |||||||
| 2011-08-01 18:10 | Sebastien Jourdain | Status | todo => active development | |||||||
| 2011-08-01 18:11 | Sebastien Jourdain | Topic Name | => 12415-representation-plugin | |||||||
| 2011-08-01 18:11 | Sebastien Jourdain | Note Added: 0027190 | ||||||||
| 2011-08-01 18:11 | Sebastien Jourdain | Status | active development => gatekeeper review | |||||||
| 2011-08-01 18:11 | Sebastien Jourdain | Resolution | open => fixed | |||||||
| 2011-08-04 18:08 | Utkarsh Ayachit | Note Added: 0027236 | ||||||||
| 2011-08-05 10:52 | David Partyka | Note Added: 0027261 | ||||||||
| 2011-08-05 15:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review | |||||||
| 2011-08-05 15:55 | Utkarsh Ayachit | Note Added: 0027276 | ||||||||
| 2011-08-12 23:40 | Utkarsh Ayachit | Fixed in Version | => 3.12 | |||||||
| 2011-09-12 10:16 | Utkarsh Ayachit | Note Added: 0027469 | ||||||||
| 2011-09-12 10:16 | Utkarsh Ayachit | Status | customer review => backlog | |||||||
| 2011-09-12 10:16 | Utkarsh Ayachit | Resolution | fixed => reopened | |||||||
| 2011-09-12 10:48 | Utkarsh Ayachit | Topic Name | 12415-representation-plugin => 12360_fix_plugins_in_python | |||||||
| 2011-09-12 10:48 | Utkarsh Ayachit | Note Added: 0027470 | ||||||||
| 2011-09-12 10:48 | Utkarsh Ayachit | Status | backlog => gatekeeper review | |||||||
| 2011-09-12 10:48 | Utkarsh Ayachit | Fixed in Version | 3.12 => git-next | |||||||
| 2011-09-12 10:48 | Utkarsh Ayachit | Resolution | reopened => fixed | |||||||
| 2011-09-12 10:48 | Utkarsh Ayachit | Assigned To | Sebastiennn Jourdain => Utkarsh Ayachit | |||||||
| 2011-09-12 10:48 | Utkarsh Ayachit | Note Added: 0027471 | ||||||||
| 2011-09-16 14:35 | David Partyka | Status | gatekeeper review => customer review | |||||||
| 2011-11-11 17:08 | Utkarsh Ayachit | Fixed in Version | git-next => 3.12 | |||||||
| 2012-02-08 17:24 | Utkarsh Ayachit | Status | customer review => closed | |||||||
| 2012-02-08 17:24 | Utkarsh Ayachit | Note Added: 0028140 | ||||||||
| Notes | |||||
